Ce parere aveti despre anxietatea oamenilor contemporani ?
  • Răspunsuri 1,2k
Acum 10 ore, doru3160 a spus:
Sa plateasca cei care au semnat contractele
Glumiti. Erau niste securisti intarziati , ajutati de fostii lor elevi . Cum sa dea comisioanele inapoi ? Pai degeaba au murit ei la revolutie ?  Putin respect, daca se poate, pentru patriotii adevarati . Ce daca au jucat la Caritas si "au  castigat de 8 ori" , vreti sa moara de foame ? Noroc ca le mai pica ceva din preturile astea la energie, combustibili, etc . ca erau vai de rucul lor ...
  doru3160.Ai dreptate,S300 provine din epoca sovietică,fabricată la Leningrad...
 Candace Owens,de la Fox News, a reacţionat la "iniţiativa" lui Zelea de-a declanşa al treilea război mondial catalogãndu-l "jegos","cacat",ş.a.m.d...
https://www.google.com/amp/s/publicnewstime.com/news/world/candace-owens-slams-zelensky-as-fraud-after-missile-hits-poland/
Editat de BRANCA
Rachetele sol aer se pot folosi foarte bine si in relatia sol-sol. Si mai e o chestie, toate rachetele, daca rateaza tinta, nu pica când ramân fara combustibil, ci se autodistrug! Cred ca intelegeti ratiunea. Daca nu ar fi fost asa ceva, prin anii 70, ar fi fost o catastrofa in Mamaia!
July 14, 2022: Ukraine claims Russia is using 1.8-ton S300 (SA-10) SAM (surface to air missiles) as SSMs (surface to surface missiles). The allegation was based on Belarus revealing that they had recently tested S300s acting as SSMs. The S300 was known to have been designed with SSM capability. That means one of launch options includes SSM mode. There are two major limitations to using a SAM as an SSM. One is accuracy at longer ranges. Russian SAMs are guided to the target using a ground-based targeting radar that guides the S300 to aerial targets up to 150 kilometers away. SAMs are programmed to self-destruct if they miss their target so that the missile and its small (100-200 kg) warhead does not land on friendly territory. Used as an SSM the self-destruct is disabled and the guidance system aims the missile at a ground location, but less accurately than against aerial targets. Russia has apparently modified the SSM option to include a GPS option that directs the SAM to a specific ground location. The GPS option works, but not as accurately as expected. Ukraine believes that the Russians are running out of SSM missiles and using S300s as SSMs because there is not much need for their SAM capabilities, especially with the more recent and capable S400 now available.
Acum 5 ore, Sharky a spus:
https://youtu.be/4dISgCPeg64
Legebeteii ne mananca...pana unde merge prostia.
Noroc ca noi inca avem urma de decenta.
Sunt valuri astea. Cu timpu o sa vezi ca abominatiile astea o sa dispara asa cum au si aparut.Asa au fost toate
Ultimu val a fost cu pandemia si azi constati ca tot ce se intampla rau pe planeta e doar din cauza razboiului lu putin si de pandemie nu se mai spune absolut nimic
