dbx Postat Octombrie 9, 2022 Partajează Postat Octombrie 9, 2022 1. Carcasa (!) Akasa Miditower ATX AK-ZEN-01 Carcasa ATX midi tower, fara sursa, full SECC, 6 bay-uri 3.5, 4 bay-uri 5.25, 2 fan-uri 120 mm preinstalate, conectori USB (2 buc.) si audio, ideala pentru sisteme mainstream, culoare neagra PCI backplate: 7 Numar ventilatoare: 2 x 120 (1- Fata , 1 - Spate) Deschidere laterala: Da Format: ATX Numar locase fixe externe: 2 x 3.5" 4 x 5.25" Numar locase fixe interne: 4 x 3.5" Dimensiuni (W x H x D mm): 450 x 200 x 500 Pret: 99 lei + transport (platit anticipat in cont) , sau predare personala. 2. Sursa Corsair VS450 450W, PFC Activ Putere sursa (W): 450 Numar ventilatoare: 1 x 120 mm Alimentare: 200 - 240 V Caracteristici speciale Protectie: OPP Protectie: OVP Protectie: SCP Protectie: OCP Protectie: OTP Protectie: UVP Conectori: 1 x ATX 1 x EPS 2 x PCI-E 4 x SATA 4 x 4 Pin 4 x HDD 2 x Floppy 4pin Sursa modulara: Nu Format: ATX Rail: 1 x 12 V Altele: MTBF: 100000 ore PFC Activ Dimensiuni (W x H x D mm): 150 x 86 x 140 Pret: 99 lei + transport (platit anticipat in cont) , sau predare personala. Link spre comentariu
dbx Postat Octombrie 14, 2022 Autor Partajează Postat Octombrie 14, 2022 3. Se adauga: PDA Mio P560, 400MHz, GPS Specificatii Mio P560 Procesor Samsung 2443 – 400Mhz GPS Chipset 20-channel SiRFstarIII TMC Optional Memorie interna 512MB pana la 4GB Memorie / RAM 64MB Memory Slot SD/MMC Display 3.5″ Resolution 320 x 240 Battery Capacity 1350mAh Autonomie 4.5hrs Bluetooth V2.0 WiFi 802.11b+g USB V2.0 Microfon Yes (Built-in) Speaker Yes (Built-in) Earphone Jack 2.5mm Adancime 17.8mm (0.6″) Latime 72mm (2.9″) Inaltime 115 (4.6″) Greutate 170g Pret: 199 lei + transport (platit in avans) Link spre comentariu
dbx Postat Noiembrie 23, 2022 Autor Partajează Postat Noiembrie 23, 2022 PDA Mio P560 pachet complet! Link spre comentariu
