enafelice Postat Septembrie 28, 2022 Partajează Postat Septembrie 28, 2022 Sharp LC-24LD171k,adus din Anglia,fabricat in Polonia.Nu receptioneaza nici-un program.Cauta numai digital.L-am resetat din meniu si la pornire are numai UK si Irlanda.Nu am reusit sa intru in service mod.Am incercar Input si vol_,menu si input,ma rog toete combinatiile de pe pupitru si am introdus tv in priza,asteptind sa apara K in stinga sus.NimicCredeti ca se mai poate seta ceva din service sau il asteapta casarea. Link spre comentariu
iuliantv Postat Septembrie 28, 2022 Partajează Postat Septembrie 28, 2022 conform manualului stie doar dvb-t si dvb-t2 deci ar trebui un soft usb sau un dump Item 24” LCD COLOUR TV Model: LC-24LD171K LCD screen size (diagonal) 24” / 60 cm Number of dots 3,147,264 dots (1360 x 768 x 3 dots) Video Colour System PAL/SECAM/NTSC 3.58/NTSC 4.43/PAL 60 TV Function TV-Standard Digital DVB-T, DVB-T2 Receiving Channel VHF/UHF DVB-T: E5-E69 TV-Tuning System Auto Preset 1599 ch, Auto Label, Auto Sort Audio amplifier 3 W x 2 Speaker (mm) 100(H) x 27(W) x 27(D) Rear ANTENNA UHF/VHF 75 : SCART SCART (AV input, Y/C input, RGB input, TV output ) ETHERNET Network connector CVBS/COMPONENT CVBS/Y/Pb(Cb)/Pr(Cr), RCA pin (L/R) Digital Audio out Optical Digital audio output x 1 (PCM) HDMI 1 Digital video and audio input, ARC HDMI 2 Digital video and audio input HEADPHONE Ø 3.5mm jack (Audio output) Side C. I. (Common Interface) EN50221, R206001, CI Plus specification USB Software update, multi-media play OSD Language English, German, French, Italian, Dutch, Spanish, Greek, Portuguese, Swedish, Finnish, Russian, Polish, Turkish, Hungarian, Czech, Slovak, Danish, Norwegian, Estonian, Latvian, Lithuanian, Slovenian, B Link spre comentariu
iuliantv Postat Septembrie 28, 2022 Partajează Postat Septembrie 28, 2022 pentru service incercati MENU 1147 MENU 1999 BACK 062596 INFO (I+) Link spre comentariu
Costica Tv Postat Septembrie 29, 2022 Partajează Postat Septembrie 29, 2022 (editat) Acum 16 ore, enafelice a spus: Sharp LC-24LD171k,adus din Anglia,fabricat in Polonia.Nu receptioneaza nici-un program.Cauta numai digital.L-am resetat din meniu si la pornire are numai UK si Irlanda.Nu am reusit sa intru in service mod.Am incercar Input si vol_,menu si input,ma rog toete combinatiile de pe pupitru si am introdus tv in priza,asteptind sa apara K in stinga sus.NimicCredeti ca se mai poate seta ceva din service sau il asteapta casarea. Cu un dump potrivit tv-ul se poate transforma usor intrunul care sa receptioneze si programele digitale pe cablu (DVB-C), dar degeaba daca nu ai postat seria placi de baza, asta da dovada de lipsa de interes din partea ta..., macar spune ce flash are pe placa ca sunt 2 variante, una e cu flash spi MX25L128 si alta e cu flash nand tsop48 Din service nu se poate seta nimic pentru receptia DVB-C decat prin schimbarea softului din flash !! Editat Septembrie 29, 2022 de Costica Tv Link spre comentariu
iuliantv Postat Septembrie 29, 2022 Partajează Postat Septembrie 29, 2022 (editat) sa fim seriosi nu orice tv dvbt poate fi transformat in dvb-c sau analog,doar cu un soft Editat Septembrie 29, 2022 de iuliantv Link spre comentariu
Costica Tv Postat Septembrie 29, 2022 Partajează Postat Septembrie 29, 2022 (editat) Acum 2 ore, iuliantv a spus: sa fim seriosi nu orice tv dvbt poate fi transformat in dvb-c sau analog,doar cu un soft Daca nu ma documentam nu mai postam asa de dragul de a posta, important este sa spuna ce flash are ca sunt 2 variante cu flash spi si nand tsop48, placa fiind 715G6826-M0E-000-004T.... Cu nand tsop48 Cu flash spi Editat Septembrie 29, 2022 de Costica Tv Link spre comentariu
enafelice Postat Octombrie 1, 2022 Autor Partajează Postat Octombrie 1, 2022 MB este de tipul 715G6826-M01-000-004T si este cu memorie NAND tsop48 placa pare identica cu prima postata de catre dl Costica Link spre comentariu
Costica Tv Postat Octombrie 1, 2022 Partajează Postat Octombrie 1, 2022 (editat) Acum 2 ore, enafelice a spus: MB este de tipul 715G6826-M01-000-004T si este cu memorie NAND tsop48 placa pare identica cu prima postata de catre dl Costica Daca vrei sa faci tv-ul sa receptioneze analog+dvb-c, faci exact cum iti spun eu, faci rost (din recuperari sau cumperi) de un flash spi 25Q128 (are multi inlocuitori), il scrii cu dumpul de jos, apoi dai nandul tsop48 jos de pe placa si lipesti flashul spi 25Q128 in locatia si pozitia destinata de fabricant Vad ca tipul de display n-ai vrut sal postezi... https://remont-aud.net/dump/lcd_pdp_tv/blaupunkt/blaupunkt_bla_236_152r_gb_3b_hbku_eu_shassi_main_board_715g6826_m0e_000_004t/380-1-0-85369 https://mediamarkt.pl/rtv-i-telewizory/telewizor-blaupunkt-bla-236-152r-gb-3b-hbku-eu Editat Octombrie 1, 2022 de Costica Tv Link spre comentariu
enafelice Postat Octombrie 2, 2022 Autor Partajează Postat Octombrie 2, 2022 Multumesc Dl Costica.Am descarcat fisierul sa caut miine o memo si va comnic rezultatul Link spre comentariu
enafelice Postat Octombrie 13, 2022 Autor Partajează Postat Octombrie 13, 2022 Revin,am reusit sa gasesc o memorie 25Q128,am inscris-o co CH 341,am primit confirmarea ca este inscrisa corect,am dat jos memoria NAND si in locul ei am pus in locul destinat memoria spi 25Q128 si nu a functionat(ledul verde/rosu stins).Am dat memo jos si am reinscs-o si la fel.Pentru ca am ramas dator cu ecranul acesta este identic cu cel descarcat adica TPM236H3-BJ1L01 RevC3 Link spre comentariu
iuliantv Postat Octombrie 13, 2022 Partajează Postat Octombrie 13, 2022 (editat) era de asteptat sa nu meargå nu sånt chiar nebuni sa puna nad in loc de un chior de spi, da e corect ca e in functie de soft,dar eu unul cred ca au si procesoare diferite acele placi si hardware trebuie sa fie ceva ce sa permita spi in loc de nand,ceva componente smd legate de acest spi ce nu sånt montate,ceva rezistente,s.au masurat ceva tesiiuni pe spi,? ceva date,ceva tensiuni ,a,r trebui sa fie cel pun 3 pini cu 3v2 Editat Octombrie 13, 2022 de iuliantv Link spre comentariu
enafelice Postat Octombrie 13, 2022 Autor Partajează Postat Octombrie 13, 2022 da exista tensiuni pe spi,da cel putin 3 tens de 3,2v. Link spre comentariu
