Hyundai 32HYN7710BF (Vestel 17MB181TC) - eroare la upgradare
rusu
Hyundai 32HYN7710BF (10134531, 8719839)
17MB181TC
VES315UNGH-L3-N92 (PT320CT01-4)
Defect:
La comanda de pornire, televizorul afiseaza marca si apoi restarteaza.
Am incercat sa-l upgradez. Am folosit software compatibil (placa, ecran).
Porneste procedul de upgrade dar la 28% apare un mesaj de eroare.
Am incercat cu mai multe stick-uri, toate verificate anterior pe televizoare Vestel.
Presupun ca ar putea exista si un defect hard.
A mai intalnit cineva aceasta manifestare.
Solutii?
Editat de rusu
corectare
  • Răspunsuri 22
  • Florinel TV
    6
  • r2005rom
    5
  • rusu
  • iuliantv
as zice ca mesajul de erroare e de incompatibilitate software,sau memoria(emmc,nand) in care se scrie firmware-ul e defecta fizica(ceva bad-uri) dar daca are si vre-un spi ceva,merita incercat schimbarea lui fizica cu dumpul potrivit
  • 8 luni mai târziu...
La 18.09.2022 la 10:49, rusu a spus:
Da, cam asa este.
Daca are cineva nevoie de soft, sunt pe receptie.
pentru un main vestel 17mb171 panel VES315WNGH-2D-N51 android aveti ceva soft
multumesc , cu stima!
Member
City & State: AQ
My Country: Italia
I'm a: Knowledge Seeker
Default Re: Hitachi 43HAE4251 - Vestel 17MB171 - Displays logo and reboots
Ok, I solved it.
A friend gave me the firmware for another motherboard 17MB170 and it worked, the brand logo is not Hitachi anymore, now is Regal, bit that is not a problem.
Also had to change a setting on the factory menu, the screen was displaying some vertical lines and dots: SSC adjust-> LVDS to off
Here is the file:
LINK REMOVED AT POSTER'S REQUEST
For this 17MB171 it has to be renamed "upgrade_loader_no_tvcertificate.pkg" for the TV to find it.
Hope can be useful to someone else.
Acum 9 minute, iuliantv a spus:
Member
City & State: AQ
My Country: Italia
Ok, I solved it.
Here is the file:
link???
1 oră în urmă, r2005rom a spus:
link???
stiu ca nu mai e LINK activ,dar am postat doar sa va faceti o idee ce denumire are fisierul,sau cum trebuie redenumit,si ca idee omul a folosit soft de 17mb170 pe 17mb171,in caz ca poate gasiti mai usor pentru 17mb170,eu unul am cautat,nu am gasit de nici unele
Acum 3 ore, r2005rom a spus:
Am asa dump emmc pentru acest main daca vrei si ai cu ce scrie emmc
Nokia HNE32GV210 MB.17MB171 panel PT320AT02-2-XC-4 eMMC KLM8G1GETF-B041
Acum 47 minute, Florinel TV a spus:
am RT809H,
tv. JVC LT32VAH3000  ,main 17mb171, panel ves315WNGH-2D-N51, EMMC KLM8G1GETF
manifestare . pleaca din stand-by si se opreste in home cu apps deschise ,apoi dupa cateva minute
trece in stand-by.de altfel se si opreste in stand-by din unicul buton de pe bord, nu asculta de telecomanda originala deloc.
aparent lucreaza dar pana la un punct!!!!
daca aveti soft va rog... bineinteles si conexiunea pe placa
va multumesc! cu stima!
salut! multumesc pt. suport , am rezolvat in final cam asa.....
dupa mult timp in care nu am reusit sa ma conectez cu rt-ul la emmc(schimbat setari,schimbat cablu usb,incercat cu mai multe variante de soft rt809h,fire mai scurte,alimentare 12v externa, cu 3.3v si 1,8v din placa sau extern nimic!!!!!m-a disperat!!!!!)
in final am tatonat pinii de conexiune, CMD SI D0 sunt ok dar CLK e cu o rezistenta smd mai sus(urmatoarea spre procesor)
a mers bine cu primul bin cel de 32inch, partea proasta e ca telecomanda pt. nokia e radio nu ir,dar am folosit pe porturile usb tastatura si mouse fiind android nativ macar atat sa stie.
ce am salvat eu din jvc este corupt, are crc failed multe!!!!! dar se pare ca emmc e ok.
la aceste modele nu se poate salva in mod traditional profile cu toate ca in menu service are optiunea usb operation
menu service tot 4725 dar asa :( menu , advanced,ok si 4725)
aici are si modelul de telecomanda dar nu se poate modifica
Editat de r2005rom
Acum 21 minute, Florinel TV a spus:
Am gresit eu cand am pus sageata pe CLK , dar bine ca sa rezolvat, am sa remediez problema, multumesc pt atentionare
suntem oameni,nu roboti!
