margarit2001 Postat Mai 15, 2004 Partajează Postat Mai 15, 2004 ce parere aveti de amplificatoare hibride??? cele cu etajul de intrare cu lampi si cel de iesire cu mosfeturi se aud bine?rau? in comparatie cu un amplificator audio numai cu lampi merita facut? ceva de genu : http://digilander.libero.it/essentialau ... d_home.htm Link spre comentariu
Electron Postat Mai 16, 2004 Partajează Postat Mai 16, 2004 Asta-i link-ul meu! Ti-as fi spus cum se aude daca as fi avut ECC 88 care e un tub pt. tensiuni anodice mici. Dar asa pot sa dau cu presupusul: am mai spus si o spun din nou, MOS-urile se comporta asemanator cu tuburile trioda fiind comandate in tensiune, nu in curent ca bipolarele. Probabil ca o sa se auda asemanator cu amplificatoarele pe tuburi, dar o sa ai deriva termica (ca la orice tranzistor), o sa ai stabilitate mai mica etc., ceea ce la tuburi nu se intampla. Vezi ca in Tehnium a fost prezentat un amplificator in clasa A cu MOSFET care se aude ca unul cu tuburi. Hai sa-ti mau dau ceva link-uri: http://www.bonavolta.ch/hobby/en/audio/irf150.htm http://www.bonavolta.ch/hobby/en/audio/pacific.htm http://www.bonavolta.ch/hobby/en/audio/abtine.htm Link spre comentariu
Electron Postat Mai 16, 2004 Partajează Postat Mai 16, 2004 Uite rezultatul:"The results The HYBRID power amplifier offers a flat response over the entire audio frequency range. Even with inefficient speakers you can appreciate the clarity and detailed musicality of the HYBRID, especially when a CD player is directly connected to it. The power amplifier with one output device provides up to 20W RMS with a THD under 1%, but it will works better with a second output stage in parallel.I have had the opportunity to appreciate some of the best Class-A amplifiers in the market and I recognize that the HYBRID emanates the same fragrance and a sensation of freshness when listening quality music materials. It is a clear demonstration that you can enjoy good sound quality without scarifying a large amount of money." Link spre comentariu
Guest1 Postat Mai 18, 2004 Partajează Postat Mai 18, 2004 Din cauza derivei termice a tranzistoarelor, eu prefer sa am la intrare FET sau MOSFET si pe iesire tuburi. Link spre comentariu
margarit2001 Postat Mai 19, 2004 Autor Partajează Postat Mai 19, 2004 apropo:nu mai luati in considerare hibridul care l-am dat ca link ca oricum nu mergel-am testat de vreo doua orisi de fiecare data bubuie mosurile;) Link spre comentariu
Electron Postat Mai 19, 2004 Partajează Postat Mai 19, 2004 Poate ai stricat MOS-urile cand le-ai lipit si de asta nu-ti merg. Sunt foarte sensibile la sarcini electrostatice. Foloseste un letcon cu impamantare si tine terminalele scurtcircuitate pana dupa ce le lipesti, iar dupa aceea le deconectezi.Ai ECC 88????? Link spre comentariu
margarit2001 Postat Mai 19, 2004 Autor Partajează Postat Mai 19, 2004 nu am stricat mossurile - am luat toate masurile de protectie se intampla ceva de genu:fac montaju,verific de nu stiu cate ori sa vad daca e bine-si nu numai yo(montaju l-am facut fizic de 2 ori)cand cuplez alimentarea am un curent de mers in gol 4A apoi in scurt timp imi bubuie mossfeturile(si cu un zgomot imens) nus ce sa mai fac Link spre comentariu
margarit2001 Postat Mai 21, 2004 Autor Partajează Postat Mai 21, 2004 am folosit tubul ala din schema ecc88ce trebuia sa folosesc altul sau ce?sau schema are vreo "chichita" de nu stiu eu de ea ? ;) Link spre comentariu
Vizitator Andrei_T Postat Mai 21, 2004 Partajează Postat Mai 21, 2004 Ai pus radiator la FET-uri? Link spre comentariu
Electron Postat Mai 21, 2004 Partajează Postat Mai 21, 2004 Deci ai ECC 88, un tub pe care il caut eu de mult :? Nu stiu ce ar putea avea, nu am construit amplificatorul. Poate tensiunea de alimentare...sau poate rezistoarele din portile tranzistoarelor finale au fost prea mari, nu stiu ce sa zic...Curentul de repaos l-ai reglat? Sau ai facut toate reglajele de care se vorbeste in link-ul ala? Oricum, eu iti propun sa construiesti amplificatorul din Tehnium de care ti-am zis. Daca te apuci de el sa-mi dai de veste si mie. Pa! Link spre comentariu
margarit2001 Postat Mai 21, 2004 Autor Partajează Postat Mai 21, 2004 HA HA HA cum naiba sa nu pun radiatoare??? ;>si am facut si toate reglajele de care vorbea tipu pe paginasi degeaba :(pt. electron : eu l-as face si pe ala care zici tu insa nu am acces la tehniumeu nu am decat vreo 10 reviste + 2 almanahuri tehnium si nu contin ce zici tudaca poti sa ma ajuti si pe mine cu o schema ar fi sper Link spre comentariu
Electron Postat Mai 22, 2004 Partajează Postat Mai 22, 2004 Cu schema aia te-as putea ajuta doar daca as scana-o, dar nu stiu daca pot sa o si pun pe site. Sa vad si cand am timp... Link spre comentariu
margarit2001 Postat Mai 22, 2004 Autor Partajează Postat Mai 22, 2004 pai poti sa scanezi poza si daca nu ai unde sa o pui o pun euplssssssss Link spre comentariu
Electron Postat Septembrie 16, 2004 Partajează Postat Septembrie 16, 2004 Uite ca mi-am adus aminte de schema asta si ma gandesc ca e prost conceputa. Mai ales cablajul, e jalnic. Link spre comentariu
