Jimmy Postat Decembrie 6, 2007 Partajează Postat Decembrie 6, 2007 am cateva lampi exact asa: http://www.licht-123.de/xtcommerce/prod ... L-40-.html sau aici: http://www.thomann.de/es/philips_cdmr_70w830_40.htm tot ce zice gogu despre ele ii: Philips CDM-R 70W/830 40° flood, Metal-Halide-Lamp for E-27 socket, 70 watts, 3000 Kalvin, 40° aveti vreo idee cum pot sa le aprind? :P Link spre comentariu
Dr.L Postat Decembrie 6, 2007 Partajează Postat Decembrie 6, 2007 CDM-R lamps have to be used incombination with a ballast and anignitor or a suitable fullyelectronic ballast, like the PhilipsPrimaVision range. http://www.lighting.philips.com/in_en/a ... _cdm_r.pdfHID-PrimaVision electronic ballastsfor CDM 35, 70 and 150W lamps http://www.lighting.philips.com/in_en/a ... 0_150w.pdfhttp://www.lighting.philips.com/in_en/a ... mh_cdm.pdfle-am luat de aici: http://www.lighting.philips.com/in_en/a ... es&lang=en Link spre comentariu
