ERIC OBENG Postat August 12, 2022 Partajează Postat August 12, 2022 Plz sir I really need ur help, I have sony kd 55x8505c bootloop problem, can someone help me to get the emmc file thanks Link spre comentariu
saud52 Postat Septembrie 11, 2022 Partajează Postat Septembrie 11, 2022 La 12.08.2022 la 13:14, gigione01 a spus: Dear Sir This link does not exist or has expired. Link spre comentariu
saud52 Postat Septembrie 11, 2022 Partajează Postat Septembrie 11, 2022 Dear Sir This link does not exist or has expired. Link spre comentariu
iuliantv Postat Septembrie 11, 2022 Partajează Postat Septembrie 11, 2022 Acum 11 ore, saud52 a spus: Dear Sir This link does not exist or has expired. try again, it's still active Link spre comentariu
saud52 Postat Septembrie 13, 2022 Partajează Postat Septembrie 13, 2022 Dear Sir! I tried as you told me but it doesn't work at all ! When I try to download, I get this answer:"Link not found" and "This link does not exist or has expired." This link has expired - http://s.go.ro/jk8qrjjo Please give me the correct link and permission to download it! Thank you Link spre comentariu
saud52 Postat Septembrie 13, 2022 Partajează Postat Septembrie 13, 2022 I have a problem with bootloop - restarting TV Sony Android, model: KD-55X8509C X8509C, motherboard 1-894-596-22, eMMC H26M52103FMR. I need a proper eMMC dump for my TV. I have RT809H programmer, can this software be written with this programmer? Thank you, Friendly greetings Link spre comentariu
iuliantv Postat Septembrie 13, 2022 Partajează Postat Septembrie 13, 2022 (editat) Acum 8 ore, saud52 a spus: Dear Sir! I tried as you told me but it doesn't work at all ! When I try to download, I get this answer:"Link not found" and "This link does not exist or has expired." This link has expired - http://s.go.ro/jk8qrjjo Please give me the correct link and permission to download it! Thank you the last post in this link is the active link, the link posted by gigione01, if you follow the whole topic, there is a link in the last post. it's true that it wasn't active when you first posted it, but I reactivated it https://files.fm/u/v8bj86j7p Editat Septembrie 13, 2022 de iuliantv Link spre comentariu
saud52 Postat Septembrie 15, 2022 Partajează Postat Septembrie 15, 2022 Drag prieten! Vă mulțumesc că mi-ați trimis acest link. Am descărcat acest software. Am scris software-ul pe care mi l-ai trimis folosind programatorul RT809H prin ISP conector. Am reușit să scriu eMMC, dar televizorul meu Sony nu a mai dat niciun semn de viață după aceea. Acum televizorul meu nu mai merge deloc, display-ul este complet negru si nu exista modul standby si nici nu raspunde la comenzile manuale sau la comenzile cu telecomanda! Televizorul meu este acum complet mort! Ce să fac? ai o solutie? Vă rog să mă ajutați! Salutări prietenoase Saud Link spre comentariu
validae Postat Septembrie 15, 2022 Partajează Postat Septembrie 15, 2022 Bănuiesc că nu ați putut citi și salva continutul original înainte de a rescrie....fiindcă altfel ați fi putut rescrie dumpul original la loc.. Link spre comentariu
iuliantv Postat Septembrie 15, 2022 Partajează Postat Septembrie 15, 2022 as far as I know, the rt809h doesn't write these EMMCs correctly in the board, I don't know if they write correctly even with bga adapter, easy jtag, maybe tnm5000 or the newer tnm7000 versions.... Link spre comentariu
saud52 Postat Septembrie 16, 2022 Partajează Postat Septembrie 16, 2022 Acum 19 ore, validae a spus: Dear Sir ! Thank You for your reply! I saved the old Dump and read with My RT809H Programmer. I wrote back this software, but I have the same result! My Sony TV is completely dead, doesn't have sign of life, there's no st-by or read to commands! You are completely right as to this chinese shit from the programmer! RT809H is a very bad programmer and I don't recommend it nobody buy it ! That shit can't correctly read and writes to the Emmc dumps for Sony and Panasonic Android TVs. The RT809H Programmer is unusable for these TVs. I don't know exactly what It Is problem but and think It's a bad Ifix program? And Finally My advice on the all colleagues on this portal : Not buy RT809H programmer, don't throw yours money Into the wind, the Chinese company Ifix Is unable to make a good programmer ! Friendly greetings, Saud Dear Sir ! Thank You for your reply! I saved the old Dump and read with My RT809H Programmer. I wrote back this software, but I have the same result! My Sony TV is completely dead, doesn't have sign of life, there's no st-by or read to commands! You are completely right as to this chinese shit from the programmer! RT809H is a very bad programmer and I don't recommend it nobody buy it ! That shit can't correctly read and writes to the Emmc dumps for Sony and Panasonic Android TVs. The RT809H Programmer is unusable for these TVs. I don't know exactly what It Is problem but and think It's a bad Ifix program? And Finally My advice on the all colleagues on this portal : Not buy RT809H programmer, don't throw yours money Into the wind, the Chinese company Ifix Is unable to make a good programmer ! Friendly greetings, Saud Link spre comentariu
codrut Postat Septembrie 16, 2022 Partajează Postat Septembrie 16, 2022 The physical EMMC must also be changed. It is written with easy jtag plus. Link spre comentariu
Florinel TV Postat Septembrie 18, 2022 Partajează Postat Septembrie 18, 2022 La 16.09.2022 la 9:31, saud52 a spus: Stimate domn ! Vă mulțumesc pentru răspunsul dumneavoastră! Am salvat vechiul Dump și am citit cu My RT809H Programmer. Am scris înapoi acest software, dar am același rezultat! Televizorul meu Sony este complet mort, nu are semne de viață, nu există comenzi st-by sau citire! Ai perfectă dreptate în privința acestui rahat chinezesc de la programator! RT809H este un programator foarte prost și nu-l recomand nimeni să-l cumpere! Rahatul ăla nu poate citi și scrie corect în depozitele Emmc pentru televizoarele Android Sony și Panasonic. Programatorul RT809H este inutilizabil pentru aceste televizoare. Nu știu exact care este problema, dar și cred că este un program Ifix prost? Și în sfârșit Sfatul meu pentru toți colegii de pe acest portal: Nu cumpărați programator RT809H, nu vă aruncați banii în vânt, compania chineză Ifix nu poate face un programator bun! Salutări prietenoase, Ce versiune ai instalata pentru RT809H Link spre comentariu
Florinel TV Postat Septembrie 18, 2022 Partajează Postat Septembrie 18, 2022 La 16.09.2022 la 9:31, saud52 a spus: Stimate domn ! Vă mulțumesc pentru răspunsul dumneavoastră! Am salvat vechiul Dump și am citit cu My RT809H Programmer. Am scris înapoi acest software, dar am același rezultat! Televizorul meu Sony este complet mort, nu are semne de viață, nu există comenzi st-by sau citire! Ai perfectă dreptate în privința acestui rahat chinezesc de la programator! RT809H este un programator foarte prost și nu-l recomand nimeni să-l cumpere! Rahatul ăla nu poate citi și scrie corect în depozitele Emmc pentru televizoarele Android Sony și Panasonic. Programatorul RT809H este inutilizabil pentru aceste televizoare. Nu știu exact care este problema, dar și cred că este un program Ifix prost? Și în sfârșit Sfatul meu pentru toți colegii de pe acest portal: Nu cumpărați programator RT809H, nu vă aruncați banii în vânt, compania chineză Ifix nu poate face un programator bun! Salutări prietenoase, Nu va merge cu RT809H ca nu este dumpul salvat cu RT809H, acest programator salveaza altfel dumpul fata de JTAG, uite mai jos cum le salveaza pe alea de 15Gb de la sony EMMC_AUTO_ISP_1228\EMMC_AUTO_ISP_1228.BIN EMMC_AUTO_ISP_1228\EMMC_AUTO_ISP_1228.BIN.BOOT1 EMMC_AUTO_ISP_1228\EMMC_AUTO_ISP_1228.BIN.BOOT2 EMMC_AUTO_ISP_1228\EMMC_AUTO_ISP_1228.BIN.EXT_CSD EMMC_AUTO_ISP_1228\EMMC_AUTO_ISP_1228.BIN.part1 EMMC_AUTO_ISP_1228\EMMC_AUTO_ISP_1228.BIN.part2 EMMC_AUTO_ISP_1228\EMMC_AUTO_ISP_1228.BIN.part3 EMMC_AUTO_ISP_1228\EMMC_AUTO_ISP_1228.BIN.RPMB Link spre comentariu
