techs Postat August 6, 2022 Partajează Postat August 6, 2022 Disponibile la vanzare: - Carcase pentru amplificatoare audio din tabla de 1,5mm. Dimensiuni 20,5x17x8,5cm, masca frontala 21,3x9cm, 1,7Kg--35 lei/buc. https://ibb.co/album/X7jDgK -Amplificatoare audio cu TDA2050, corector ton cu TL072, functionale--15 lei/buc https://ibb.co/album/xq4qmz -Transformator 2x18V, 30VA--20 lei/buc https://ibb.co/album/pvg1T5 -Transformator toroidal 2x14V/6A, dimensiune 105x45mm--65 lei/buc https://ibb.co/album/5Ky3Pb -Transformator toroidal 2x14V/6A, dimensiune 108x45mm--65 lei/buc https://ibb.co/album/qLDhhS -SatFinder --20 lei/buc https://ibb.co/album/v4yCrX -Mini GlueGun Bosch PKP-15E, nefolosit, se da impreuna cu 30 rezerve plastic--45 lei https://ibb.co/album/vh55xj -Amplificator subwoofer + crossover MIVOC WA110, neverificat--25 lei https://ibb.co/album/Pxv3M0 -Alimentator laptop Dell DA130PE1 , 19,5V / 6,7A--40 lei https://ibb.co/album/H7y8D9 -Alimentator Xbox A10-120P1A, 12V / 9,6A - 25 lei https://ibb.co/album/rx0HzM -Freza Proxxon IBS/E, motorul defect, fara mandrina. Am cumparat-o cu regulatorul de turatie defect, dupa ce l-am reparat am vazut ca e defect si motorul, estetic arata f bine--25 lei. https://ibb.co/album/ccXNM8 -Radiatoare aluminiu 65x50x20mm, nefolosite, cred ca sunt fabricate de ABL Heatsink--4 lei/buc https://ibb.co/album/23Bgns -Multimetru analogic Honor TE-1410, functional, nu are urme de folosite--45 lei https://ibb.co/album/1r1zhF Nu trimit colete cu valoare sub 50 lei. Dacă vă interesează ceva din anunț postați aici (pe forum) intenția de a cumpăra, detaliile le stabilim pe PM. Mulțumesc! Link spre comentariu
imre1968 Postat August 6, 2022 Partajează Postat August 6, 2022 Ma intereseaza : Radiatoare aluminiu 65x50x20mm = 10-20 bucati Transformator toroidal 2x14V/6A, dimensiune 105x45mm--65 lei/buc https://ibb.co/album/5Ky3Pb = 2 buc Link spre comentariu
techs Postat August 6, 2022 Autor Partajează Postat August 6, 2022 Acum 5 minute, imre1968 a spus: Ma intereseaza : Radiatoare aluminiu 65x50x20mm = 10-20 bucati Transformator toroidal 2x14V/6A, dimensiune 105x45mm--65 lei/buc https://ibb.co/album/5Ky3Pb = 2 buc ok, continuam discutia pe PM. Multumesc! Link spre comentariu
grosu99 Postat August 6, 2022 Partajează Postat August 6, 2022 (editat) Transformator 2x18V, 30VA--20 lei/buc 4 buc Freza Proxxon IBS/E 25 lei vorbim maine dimineata Editat August 6, 2022 de grosu99 Link spre comentariu
Tanase Ion Postat August 6, 2022 Partajează Postat August 6, 2022 Rezervatimi va rog o carcasa de amplificator de aici Carcase pentru amplificatoare audio din tabla de 1,5mm. Dimensiuni 20,5x17x8,5cm, masca frontala 21,3x9cm, 1,7Kg--35 lei/buc. https://ibb.co/album/X7jDgK Si mai asteptam ce mai o sa.puneti la vanzare Link spre comentariu
hixpp02 Postat August 7, 2022 Partajează Postat August 7, 2022 Doresc eu cealaltă cutie de amplificator și alimentatorul de la Xbox a10, dacă au mai rămas 5 buc radiatoare de 65x50x20mm. Multumesc. Link spre comentariu
yo7but Postat August 7, 2022 Partajează Postat August 7, 2022 Cumpar : "Transformator toroidal 2x14V/6A, dimensiune 108x45mm--65 lei/buc"= 1 buc. Adresa pe mp. Link spre comentariu
Tanase Ion Postat August 7, 2022 Partajează Postat August 7, 2022 (editat) Acum 13 ore, Tanase Ion a spus: Rezervatimi va rog o carcasa de amplificator de aici Carcase pentru amplificatoare audio din tabla de 1,5mm. Dimensiuni 20,5x17x8,5cm, masca frontala 21,3x9cm, 1,7Kg--35 lei/buc. https://ibb.co/album/X7jDgK Si mai asteptam ce mai o sa.puneti la vanzare Amplificatoare audio cu TDA2050, corector ton cu TL072, functionale--15 lei/buc https://ibb.co/album/xq4qmz adaugati si 2buc corector cu tot cu butoane Editat August 7, 2022 de Tanase Ion Link spre comentariu
SOLDAN CONSTANTIN Postat August 7, 2022 Partajează Postat August 7, 2022 Va salut, cumpăr : Multimetru analogic Honor TE-1410, functional, nu are urme de folosite--45 lei cu stima Soldan. Link spre comentariu
GMCD Postat August 7, 2022 Partajează Postat August 7, 2022 Doresc sa cumpar: -Amplificatoare audio cu TDA2050, corector ton cu TL072, functionale--15 lei/buc https://ibb.co/album/xq4qmz - 2 buc. -Amplificator subwoofer + crossover MIVOC WA110, neverificat--25 lei https://ibb.co/album/Pxv3M0 Daca urmeaza sa mai puneti la vanzare si alte produse, atunci va rog ca pe acestea sa le rezervati si pe masura ce veti mai adauga si altele, sa va anunt ce mai doresc sa iau. Va multumesc! Link spre comentariu
techs Postat August 7, 2022 Autor Partajează Postat August 7, 2022 Se adauga la vanzare: -Placa cu componente--25 lei/buc https://ibb.co/album/hBqbbC -Casti audio Koss UR5, nefolosite. Trei sunt sigilate doar ca lipsesc buretii de rezerva--10 lei/buc https://ibb.co/album/wh9GCC -Surse de tensiune MEAN WELL 24V/3,2A-- 25 lei/buc. https://ibb.co/album/TYtjQ0 -Sterilizatoare UV Samsung, nefolosite, impecabil finisate, face si incarcare wireless. In pachet este doar cablu USB-C, incarcatorul nu este inclus. Mai am unul identic pe care l-am folosit pentru stergere memorii EPROM (timp necesar 25 min), se pot pune 4 memorii in fata celor doua lampi UV--45 lei/buc https://ibb.co/album/7NX2KV - Aparat de curatare cu ultrasunete, dimensiune cuva 15x12,5mm--50 lei https://ibb.co/album/41CxPB -Transformator toroidal 2 x 29V/2A, dimensiune 9x6cm--40 lei https://ibb.co/album/7Npp1X Din anuntul anterior sunt disponibile: - Carcase pentru amplificatoare audio din tabla de 1,5mm. Dimensiuni 20,5x17x8,5cm, masca frontala 21,3x9cm, 1,7Kg--35 lei/buc., mai este 1 buc. https://ibb.co/album/X7jDgK -Transformator toroidal 2x14V/6A, dimensiune 108x45mm--65 lei/buc https://ibb.co/album/qLDhhS -SatFinder --20 lei/buc https://ibb.co/album/v4yCrX -Mini GlueGun Bosch PKP-15E, nefolosit, se da impreuna cu 30 rezerve plastic--40 lei https://ibb.co/album/vh55xj -Alimentator laptop Dell DA130PE1 , 19,5V / 6,7A--35 lei https://ibb.co/album/H7y8D9 Nu trimit colete cu valoare sub 50 lei. Dacă vă interesează ceva din anunț postați aici (pe forum) intenția de a cumpăra, detaliile le stabilim pe PM. Mulțumesc! Link spre comentariu
laur+ Postat August 8, 2022 Partajează Postat August 8, 2022 (editat) Vreau eu ultima carcasa de amplificator. Vorbim în mp. Editat August 8, 2022 de laur+ Link spre comentariu
22euu Postat August 8, 2022 Partajează Postat August 8, 2022 Buna ziua, - Aparat de curatare cu ultrasunete, dimensiune cuva 15x12,5mm--50 lei https://ibb.co/album/41CxPB -Mini GlueGun Bosch PKP-15E, nefolosit, se da impreuna cu 30 rezerve plastic--40 lei https://ibb.co/album/vh55xj Multumesc. Link spre comentariu
iuliantv Postat August 8, 2022 Partajează Postat August 8, 2022 (editat) vreau eu ,daca este ok Alimentator laptop Dell DA130PE1 , 19,5V / 6,7A--35 lei https://ibb.co/album/H7y8D9 Transformator toroidal 2 x 29V/2A, dimensiune 9x6cm--40 lei https://ibb.co/album/7Npp1X Editat August 8, 2022 de iuliantv Link spre comentariu
rosmarin Postat August 8, 2022 Partajează Postat August 8, 2022 Buna seara As dori un transformator toroidal de 2x14v in secundar la 6A .Rog daca aveti ,un semn.Multumesc ! Link spre comentariu
