Agilent 5519A Laser Head
iuliantv
nu cunosc puterea de ,,emisie,,momentan pretul este fix 4700 lei(e la jumatate din pretul pietei a aceluiasi produs sh stare ,,emisie,, scazutå)
trimit in tara doar cu plata avans in cont a transportului tur retur 100lei
poze reale,mai putin poza din topicce e reprezentativå
rog si ofer seriozitate,se vinde doar ce se vede in poze,fara alte accesorii
stare buna aspect,an 2006
am si un mic bonus
pozele din link reale
https://postimg.cc/gallery/QTSQSX0
Agilent 5519A Laser Head and Receiver
Feature:
The HP 5519A laser head, which is a component of the HP 5529A dynamic calibrator system, incorporates a helium-neon laser with a beam diameter of 6 mm (0.24 in). It has a wavelength accuracy of ±0.1 ppm (±0.02 ppm if calibrated to MIL-STD 45662). The HP 5519A uses HP's two-frequency laser technique that virtually eliminates the problems common to other laser designs, which result from beam intensity changes . The laser head uses a proven long-life laser tube.
The HP 5519A is configured with appropriate optics and system electronics to build a laser calibration system that meets the unique physical layout and measurement requirements of individual applications. The laser accuracy is ideal for machine calibration applications.
Helium-neon Two Frequency. Laser
Fast Warmup
Highly-Accurate
Measurement Accuracy: 0.0000001%
Editat de iuliantv
  • Răspunsuri 8
  • iuliantv
    9
