muratguldu Postat Iunie 2, 2022 Partajează Postat Iunie 2, 2022 hi im tv repair engineer i got in shop sony kdl-49x8509c i need a emmc dump i looked everywhere i cant find does anyone got files for this tv it also same is KD-55X8005C KD-49X8309C KD-49X8305C thank you Bună, sunt inginer de reparații tv. Am găsit în magazin Sony kdl-49x8509c. Am nevoie de un dump Emmc. Am căutat peste tot, nu găsesc. Are cineva fișiere pentru acest televizor. La fel este și KD-55X8005C KD-49X8309C KD-49X8305C. Mulțumesc. Link spre comentariu
Florinel TV Postat Iunie 2, 2022 Partajează Postat Iunie 2, 2022 (editat) First it says which mainboard has TV and which panel, then it says which programmer you use, and after all this we will help you Editat Iunie 2, 2022 de Florinel TV Link spre comentariu
muratguldu Postat Iunie 3, 2022 Autor Partajează Postat Iunie 3, 2022 motherboard 894-59512 (189459512) panel syv4941 model 49x8509c emmc H26M52103FMR thank you Link spre comentariu
Florinel TV Postat Iunie 3, 2022 Partajează Postat Iunie 3, 2022 Acum 9 ore, muratguldu a spus: motherboard 894-59512 (189459512) Poate 1-894-596-22 Link spre comentariu
muratguldu Postat Iunie 4, 2022 Autor Partajează Postat Iunie 4, 2022 no its 894-59512 like this one https://www.tvparts.co.uk/lcd-tv-spares/main-pcb-lcd/sony-2/1-894-595-12-189459512-main-pcb-for-sony-kd-55x8005c Link spre comentariu
Florinel TV Postat Iunie 4, 2022 Partajează Postat Iunie 4, 2022 I'm sorry, for this TV model I don't have a dump, maybe he has a colleague and he will help you, wait a minute Link spre comentariu
vizicon Postat Iunie 5, 2022 Partajează Postat Iunie 5, 2022 I found it in the computer, I can't say it's OK, I didn't have a chance to check it. I'm trying to see where I can load it because it's quite large 1.31GB. Link spre comentariu
tehtronics Postat Iunie 5, 2022 Partajează Postat Iunie 5, 2022 (editat) @vizicon Ex. https://wetransfer.com/ Editat Iunie 5, 2022 de tehtronics Link spre comentariu
muratguldu Postat Iunie 5, 2022 Autor Partajează Postat Iunie 5, 2022 Thank you ill try it Monday Link spre comentariu
vizicon Postat Iunie 8, 2022 Partajează Postat Iunie 8, 2022 La 05.06.2022 la 12:40, muratguldu a spus: Thank you ill try it Monday Nu am primit un răspuns daca soft emmc este bun si cum expira in 16 .06 , poate alți colegi îl doresc in arhiva . https://www.transfernow.net/dl/20220606cRQKmq5B Link spre comentariu
muratguldu Postat Iunie 8, 2022 Autor Partajează Postat Iunie 8, 2022 functioneaza multumesc mult Link spre comentariu
blado Postat Decembrie 7, 2023 Partajează Postat Decembrie 7, 2023 Bună ziua, poate cineva să încarce din nou fișierul de emmc dump. Mulțumesc! Link spre comentariu
