Masurare debit, temperatura si COP
Cortex
Salutare, inca din primul rand  vreau sa va spun ca e primul meu program pe care il fac si tot o data prima oara cand pun  mana pe un IDE :nas:, evident inspiratii din diverse videouri, deci nu dati cu paru' prea tare:rade:
Am un UNO legat la un lcd 16x2 cu care ( vreau sa ) monitorizez temperaturi si waterflow ( cu YF-S201), ce imi da mie cu virgula, nu intepreteaza corect puterea de iesire respectiv COP ( coeficinet de putere ), daca printez pe lcd "delta", nu il intepreteaza cu virgula si de aici ( cred eu) ca e eroarea ( daca conteaza... am construit o pompa de caldura si vreau sa o monitorizez pt a ii gasi punctele optime de functionare) . Multumiri in avans !
//config lcd16x2
#include <LiquidCrystal.h>
const int rs = 13, en = 12, d4 = 11, d5 = 10, d6 = 9, d7 = 8;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
volatile int flow_frequency;
float vol = 0.0,l_minute;
float volt = 0.3; //read voltage
float amp = 0.2; //read amps to pin 2
float temp1 = 0.0; // read adc to pin 0
float temp2 = 0.1; //read adc to pin 1
unsigned char flowsensor = 2; // pin 2 in, pwm
unsigned long currentTime;
unsigned long cloopTime;
void flow () // Interrupt function
   flow_frequency++;
void setup()
   pinMode(flowsensor, INPUT);
   digitalWrite(flowsensor, HIGH); // Optional Internal Pull-Up
   lcd.begin(16, 2);
   attachInterrupt(digitalPinToInterrupt(flowsensor), flow, RISING); // Setup Interrupt
   lcd.clear();
   lcd.setCursor(0,0);
   lcd.print("HeatPump Monitor");
   lcd.setCursor(0,1);
   lcd.print(" Water-to-Water ");
   delay(3000);
   currentTime = millis();
   cloopTime = currentTime;
void loop ()
  int volt = analogRead(A3); //read voltage in DC
  int amp = analogRead(A2); //read amps
  int temp1 = analogRead(A0); //read temp T1
  int temp2 = analogRead(A1); //read temp T2
  float volt_1 = (volt * 5.25) / 1023.0;
  float amp_1 = (amp * 5.25) / 1023.0;
  float temp_1 = (temp1 * 5.25) / 1024.0*100;
  float temp_2 = (temp2 * 5.25) / 1024.0*100;
  float power_in = (volt_1 * amp_1);
  float delta = (temp2 - temp1) /2;
  float power_out = (500 * (temp2 -temp1) * 1.16) * 0.001;  // acel 500 e debitul pompei L/h
  float COP = (power_out / power_in);
   if(currentTime >= (cloopTime + 1000))   // 0..to 1000mS = 0..to 1sec
    cloopTime = currentTime; // Updates cloopTime
      // Pulse frequency (Hz) = 7.5Q, Q is flow rate in L/min.
      l_minute = (flow_frequency / 6.45); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print(l_minute); //value in L/M
      l_minute = l_minute/60;
      lcd.setCursor(11,0);
      lcd.print(temp_1);
      lcd.setCursor(11,1);
      lcd.print(temp_2);
      lcd.setCursor(6,0);
      lcd.print(power_in);
      lcd.setCursor(6,1);
      lcd.print(delta);
     // lcd.print(power_out);
      lcd.setCursor(0,1);
      lcd.print(COP);
      flow_frequency = 0; // Reset Counter
  • Răspunsuri 15
Incearca cu varianta asta:
int ADC_raw = 0;
int vol = 0.0;//l_minute;
int volt = 0.0; //read voltage
int amp = 0.0; //read amps to pin 2
int temp1 = 0.0; // read adc to pin 0
int temp2 = 0.0; //read adc to pin 1
float ampf = 0.0;
float voltf = 0.0;
float temp1f = 0.0; // read adc to pin 0
float temp2f = 0.0; //read adc to pin 1
float power_in = 0.0;
float delta = 0.0;
float power_out = 0.0;
float COP = 0.0;
unsigned long Lminute;
   flow_frequency++;
void setup()
   lcd.begin(16, 2);
   lcd.clear();
   lcd.setCursor(0,0);
   lcd.setCursor(0,1);
   delay(3000);
        lcd.clear();
void loop ()
  ADC_raw = analogRead(A3); //read voltage in DC
  voltf = (ADC_raw * 5.25) / 1024.0;
  ampf = (amp * 5.25) / 1024.0;
  temp1f = (temp1 * 5.25) / 1024.0*100;
  temp2f = (temp2 * 5.25) / 1024.0*100;
  power_in = (voltf * ampf);
      Lminute = (flow_frequency / 6.45); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
      lcd.setCursor(0,0);
      lcd.print(Lminute); //value in L/M
      Lminute = Lminute/60;
      lcd.setCursor(3,0);
      lcd.print(temp1f);
      lcd.print(temp2f);
      lcd.setCursor(0,1);
      lcd.setCursor(3,1);
      lcd.print(delta);
      lcd.print(COP);
Si dovada functionarii, ca program. NU stiu cum vrei sa fie afisate valorile, dar ar trebui sa fie pe acolo. Te mai joci tu la partea de afisare.
Mulțumesc domul Nico, cum ajunga acasa il si pun la treaba, de afisat ..ma mulțumesc sa am valorile pe lcd, vroiam  sa fac cu scris( mai multe  ecrane)  insa ma depaseste momentan.
Am in drum un grafic 128x64,  acolo o sa desenez schema de princiupiu a pompei cu valori aferente senzorilor, astfel va fi mai intuitiv
Salut, am bagat programelul, insa mai am ceva probleme legt de afisare/intepretare, in sensul ca la pornire, daca afiseaza o valoare peste ce-a citita, ultima cifra ramane afisata si nu dispare,
Nu stiu cum sa setez lungimea efectiva a valorii:26
De exemplu as vrea asa
Temp1   27.3
Temp2   20.9
L/h 542
Power_in 1.2  (  sau 1200)
P_out  5.6    ( sau 5600)
COP  3.41
Acum 51 minute, mihaicozac a spus:
Ai nevoie de un lcd.clear()
Pff...cat de simplu era...eu il pusesem la sfarsit si nu apuca sa afiseze...porma l--am pus la inceput..la fel....acum l-am pus dupa calcul debit si merge perfect :aplauze
Am mai invatat ceva  .Multumesc !
Cum as putea implementa sa masoare COP in timp real ? actual debitul apei din formula este setat la 500 L/h ,,insa as vrea sa ia valoarea masurata de senzorul de debit care variaza in functie de...tevi...robineti...etc
  delta = (temp2 - temp1);
  power_out = (500 * delta * 1.16*0.001)/2;  // acel 500 e debitul pompei L/h
  COP = (power_out / power_in)*1000;
 mai pun o data tot codul pentru a fi mai usor de intepretat.
volatile float flow_frequency;
int ADC_raw = 0;
int vol = 0.0;  //l_minute;
float ampf = 0.0;
float voltf = 0.0;
int power_in = 0.0;
float delta = 0.0;
float COP = 0.00;
   flow_frequency++;
void setup()
   lcd.begin(16, 2);
   lcd.clear();
   lcd.setCursor(0,0);
   lcd.setCursor(0,1);
   delay(3000);
        lcd.clear();
void loop ()
  voltf = (ADC_raw * 5.110) / 1023.0;
  ampf = (amp * 5.110) / 1023.0;
  temp1f = (temp1 * 5.12) / 1023.0*100;
  temp2f = (temp2 * 5.12) / 1023.0*100;
  power_in = (voltf * ampf)*100;
  COP = (power_out / power_in)*1000;  // Putere afisata in kw
      Lminute = (flow_frequency / 10.3)*100; // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
      lcd.clear();  // asta imi lipsea mai devreme :))
      lcd.setCursor(0,0);
      lcd.print(Lminute);   // value in L/h
      Lminute = Lminute;    // sau Lminute = Lminunte/60
      lcd.print(temp1f);
      lcd.print(temp2f);
      lcd.setCursor(0,1);
      lcd.print(COP);
     // lcd.setCursor(3,0);
     // lcd.print(delta);
      lcd.setCursor(6,1);
      lcd.setCursor(5,0);
Te rog sa folosesti butonul "<>" din editor pentru a insera cod!
Scuze,nu stiam de "<>". Chiar vroiam sa intreb cum fac sa arate ca un cod postat,acum stiu ,multan'!
Am pus sa calculeze  Lminute*delta*1.16 chiar inainte de afisare power_out ...e aporape ok insa cand valorile tind spre zero, se muta virgula aia de apar cifre suprapuse ( ca ma limiteaza lcd-ul ) de nu mai intelegi nimic.
Gen 0.0023. As fi preferat sa ramana 0.01,mai studiez problema. Va mulțumesc de ajutor !
am incercat
float COP_f = Lminute * delta * 1.16;
COP_f = constrain (COP_f, 0.01, 5.00);
e la fel,
Cop poate fi si subunitar ( daca depasesc temepraturile de lucru ale freonului ,,am doar cosum in compresor,,,,freonul nu mai face nimic la peste 60 C
Sau mai e varianta sa ii inversez sensul, sa pun pompa pe "racire" astfel am cop cu "minus" fiind acelasi lucru
Salutare din nou, mi-a sosit un lcd 128x64, deoarece inca imi prind urechile, apelez la d-voastra in a ma lumina cum sa afisez valorile, si poate chiar cum pot creea un desen care sa ramana si in jurul lui sa am valorile. Multumesc frumos
#include <U8glib.h>
U8GLIB_ST7920_128X64_1X u8g(13, 11, 10);
float ampf = 0.0;
float voltf = 0.0;
int power_in = 0.0;
float delta = 0.0;
float COP = 0.00;
   flow_frequency++;
void draw(void){
  u8g.setFont(u8g_font_5x8);     //probe fonturi
  u8g.drawStr(30, 20, "Font 5x8");
  u8g.setFont(u8g_font_unifont);
  u8g.drawStr(30, 40, "unifont8");
  u8g.setFont(u8g_font_9x15);
  u8g.drawStr(30, 55, "font9x15");
void setup(void) {
void loop (){
  voltf = (volt * 5.110) / 1023.0;
  u8g.firstPage();
  do{
    draw();
  }while(u8g.nextPage() );
Hai ca l-am biruit..doar n-o fi nava extraterestra :rade:
#include "U8glib.h"
float ampf = 0.0;
float voltf = 0.0;
float delta = 0.0;  //(temp2f-temp1f)
int power_in = 0.0;
int power_out = 0.0;
float COP = 0.00;
void draw(void) {
                 // graphic commands to redraw the complete screen should be placed here
                //astea raman afisate
//u8g.setFont(u8g_font_5x8);//setare font
  u8g.setFont(u8g_font_6x10);
  u8g.drawStr( 00, 7, "*Heat Pump Monitoring*");
  u8g.drawStr( 00, 16, "Kw in   :");
  u8g.drawStr( 00, 25, "Kw out  :");
  u8g.drawStr( 00, 34, "COP     :");
  u8g.drawStr( 00, 43, "Temp in :");
  u8g.drawStr( 00, 52, "Temp out:");
  u8g.drawStr( 00, 61, "L/h     :");
   flow_frequency++;
void setup(void) {
void loop ()
{  //de aici incep citire valori
      Lminute = (flow_frequency / 10.3)*100;  //10.3...in functie de durata rularii programului
  voltf = (volt * 5.112) / 1023.0; // 5.12 tensiunea reala la pinul Vref
  ampf = (amp * 5.112) / 1023.0;
  temp1f = (temp1 * 5.12) / 1023.0;
  temp2f = (temp2 * 5.12) / 1023.0;
  power_out = (delta * 1.16);  // formula completa este L/h x delta x 1.16
  COP = (power_out / power_in);  // Putere afisata in kw
 u8g.firstPage();
  do{
    draw(); //de aici incepe afisarea valorilor setate
   u8g.setPrintPos(58, 16);  u8g.print(power_in);
   u8g.setPrintPos(58, 25);  u8g.print(power_out);
   u8g.setPrintPos(58, 34);  u8g.print(COP);
   u8g.setPrintPos(58, 43);  u8g.print(temp1f);
   u8g.setPrintPos(58, 52);  u8g.print(temp2f);
   u8g.setPrintPos(58, 61);  u8g.print(Lminute);
https://postimg.cc/fkDyLDYX
Editat de Cortex
