Piese electronice noi si recuperate,de tot felul
bozenai
  • Răspunsuri 530
  • bozenai
    326
  • Tanase Ion
    28
  • grosu99
    23
  • sonic11
    16
Modificari preturi:
-1) ICT-15(dioda supresoare ESD) x 8buc;1lei/buc;
-2) 1.5KE400A(dioda supresoare de tensiune tranzitorie unidirectionala) x 12buc;5lei toate;
-3) 1N6275A(dioda supresoare de tensiune tranzitorie) x 4buc;2lei toate;
-4) BYT11/1000(dioda redresoare rapida) x 12buc;5lei toate;
-5) BYW100/200(dioda redresoare de recuperare rapida de mare eficienta) x 14buc;5lei toate;
-6) U8100(dioda rectificatoare ultrarapida;8A/1000V) x 4buc;7lei;
https://postimg.cc/nsxnCZTK
-traf E10;sectiune 6.4cm2;tensiune secundar 10.2V+10.2V;sirma secundar aproximativ 0.8mm;12lei;
https://postimg.cc/gallery/F4wCr7Q
- traf toroidal(detalii in poze) x 3buc;25lei/buc;
https://postimg.cc/gallery/jCS74pZ
- L296(regulator de comutare de curent mare,input 50V;output 5.1-40V/4A); x 4buc;15lei/buc;
https://postimg.cc/14Qz7kFN
- 10000uF/35V x 4buc;10lei;
https://postimg.cc/1f5PFsxs
-condensatori 50uF/350V/385V(Elyt) x 3buc;10lei toti;
https://postimg.cc/vc3D80wJ
- 2900uF/250VDC/max 300V;MALLORY(made in USA) x 2buc;20lei/buc;
-2000uF/350V;S+M(made in Germany) x 7buc:15lei/buc
https://postimg.cc/HJGYfBKs
-48000uF/40VDC(SPRAGUE POWERLYTIC) x 1buc;30lei/buc;
https://postimg.cc/v1YT9W0z
-1) relee 12V;0.5lei/buc:
SRUDH-SS-112D1;1buc;
KAM-S-112C;1buc;
S3-12;3buc;
SRD-12VDC-SL-C;2buc;
833m-1C-C;1buc;
833HM-1C-C;1buc;
4117-U-Z;1buc;
SAR1 2A 1215;1buc;
KI-S-212M;1buc;
G5PA-1-M;1buc;
MPJ-112-A-2;1buc;
JZC-36F-2buc;
SDT-SS-112DM;1buc;
JZC-33F;5buc;
OJE-SS-112DM;3buc;
MPD-S-112-A;1buc;
SJ-S-112DM;1buc;
GJ-SM-105LM;1buc;
A1-S-112DA;1buc;
SHS-4110;1buc;
FRS1B-5;1buc;
RAS-1210;1buc;
RH-12V;1buc.
-2) relee 24V;0.5lei/buc:
G5LE-1-VD;2buc;
S3-24;2buc;
HJR-3FF-S-Z;1buc;
JS1-24V;1buc;
VE 24RE-K;2buc.
https://postimg.cc/kBBmftcT
- 1) relee 12V x 20buc;0.5lei/buc:
- 2) pus buton cu retinere x 2buc;2lei amindoua;
-3) doua difuzoare piezo;2lei/buc;
-4) mufe cu fire;4pini;'x 8buc;10lei toate;
https://postimg.cc/v4X5bBkx
-5 Tranzistori BD647(8A;62.5W;recuperati,masurati fiecare in parte) x 54buc;4buc/3lei;
https://postimg.cc/VrFJtTSf
- potentiometrii bobinati;unul de 25ohmi/0.5W si unul de 50ohmi/0.5W;4lei;
https://postimg.cc/gallery/DFdKbY8
-TIP32B(Italy) x 11buc;1leu/buc;
-TIP122(Texas Instruments) x 66buc;4buc/3lei;
-condensatori cu tantal 33uF/35CD x 40buc;4buc/3lei;
https://postimg.cc/YLq6YD6w
-Punte redresoare cu diode de putere + radiatoare.Diodele sunt KU 1490 x 4buc si doua radiatoare profil H cu L-20cm;l-8.2cm si h-10cm.Diodele 60lei toate si radiatoarele 15lei/buc.
https://postimg.cc/gallery/LqyCXQh
-4) Punte redresoare
25A(KBPC2504W)x2buc,,3lei amindoua;
https://postimg.cc/56LHQhZs
-1) relee marca TTI;SD-1CH(12V:12A/250VAC) x 8buc;1leu/buc;
-3)relee JQX-102F x 2buc;2lei amindoua;
https://postimg.cc/Wt1y68wQ
-46buc integrate FCJ101,am gasit ca este echivalent cu 7440N;
-9buc integrate FCH191,am gasit ca este echivalent cu 4473;
-1buc x BA723C
-2buc x 3PM4;
-1buc x BD139;
-1buc x BF459 si ce se mai vede in poze;8lei
https://postimg.cc/gallery/7P8z5t0
-2) releu RES64A x4buc(noi);2lei/buc;
-3) releu RES47 x3buc(noi);3lei/buc;
-4)releu RES43 x1buc(noi);3lei;
https://postimg.cc/jWDNn0Jj
-4) comutator 6x12pozitii;8lei;
-5) comutator 2x12pozitii;5lei;
https://postimg.cc/zymrWTMY
-ASZ18 x2buc+radiator;5lei;
https://postimg.cc/gallery/zqvhzbQ
Urmatoarele de mai jos sunt din radio-casetofonul rusesc TENTO:
-1)partea de preamplificare si inregistrare,10lei ambele;
-2)partea de amplificare,10lei;
-3)partea de radio,10lei ambele;
-5)partea de alimentare,10lei;
https://postimg.cc/jD2kdWmL
https://postimg.cc/fJ2BFzyZ;
Va salut!
Rezerv eu totul de la Tento. Imi plac condensatoarele sovietice ;)
Lasam coletul deschis.
Multumesc pentru intelegere.
Se adauga la vinzare:
-Sasiu televizor TEMP;80lei;
https://postimg.cc/gallery/r4Wt67L
-difuzoarele din televizorul TEMP;30lei ambale;
https://postimg.cc/gallery/JGnsSY5
-1) traful de cadre din tv TEMP;30lei;
-2) traful de iesire din tv TEMP;30lei
https://postimg.cc/phSgrwJV
-1) diode schotky PBYR745/7.5A(recuperate si masurate) x 10buc;1leubuc;
-2) inductor 100uH/5.4A(1410454;ecupereti) x 3buc;5lei/buc;
-3) inductor 2x2.7mH/4A(CMV 04;recupereti) x 4buc;3lei/buc;
-4) intrerupator termic unipolar cu apasare pentru resetare 1410-L210-L2F1-S02(3.15A/250VCA;50VCC(recupereti) x 3buc;10lei/buc;
-5) rezistente putere 5% x 3buc(2bucx3k3 si1bucx51ohm);4lei toate;
-6) 10000uF/35V(SAMWHA;recupereti si masurati) x 4buc;3lei/buc;
-7) suporti sigurante(recupereti) x 15buc;1leu/buc;
https://postimg.cc/JGJJ0j5j
-1) punte redresoare GBU6D 6A/200V(recuperete si masurete) x 4buc;1leu/buc;
- 2) condensatori 91pF/5%;3buc/1leu;
https://postimg.cc/N5MmtLNw
S-a vindut:
-integratele L296.
-20xbd647, 20x tip122 și asz18
-cele trei relee noi RES47
-1buc x BA723C
-2buc x 3PM4;
-1buc x BD139;
Restul valabile.
Se vinde:
-1) traf E10,sectiune 4cm2 x 1buc;pentru tole(are primarul intrerupt)
-2) traf E10;sectiune 4cm2 x 1buc(are intrefier)30lei ambele
https://postimg.cc/TKx7wjKs
-rezistenta putere 30k x 1buc;2lei;
Sa vindut:
Restul valabile.
Poza cu rezistenta de putere:
https://postimg.cc/LgKP4TxQ
