Bryant11 Postat Ianuarie 18, 2022 Partajează Postat Ianuarie 18, 2022 I wonder if TDA7498 class D amp could be used as a substitute for a dead STK power module running at 39 Volt. If I remember well a class D amp needs the grounds of the output channels to be separated. One shared output ground, like in a standard amp chassis, may kill the class D amp. Anybody? Link spre comentariu
modoran Postat Ianuarie 18, 2022 Partajează Postat Ianuarie 18, 2022 Only BTL power amps needs outputs tied not to ground, which unfornutately is the case of TDA7498 chip. Not every class D amps requires that. Link spre comentariu
