ceas cu lcd 16x2
bogdan546
Am realizat acest proiect si l-am modificat un pic, dar as fi dorit sa pot fixa alarma fara sa fiu nevoit sa trec prin toate setarile( salvarea in memorie se face la final)   Pentru a testa mai multe variante am simulat in proteus  si am atasat mai jos simularea . As fi recunoscator daca ma poate ajuta cineva .
/*  Digital Clock with Alarm Function
 *  More info: http://www.ardumotive.com/
 *  Dev: Michalis Vasilakis Data: 19/11/2016 Ver: 1.0
 *  Display 16x2:         Setup:            Setup Alarm
 *  |HH:MM:SS|* HH:MM|  |    >HH :>MM    | |   Set Alarm    |
 *  |DD/MM/YY|  ALARM|  |>DD />MM />YYYY | |   >HH :>MM     |
//Libraries
#include <Wire.h>
#include "RTClib.h"
#include <LiquidCrystal.h>
#include <EEPROM.h>
#include "ClosedCube_HDC1080.h"
ClosedCube_HDC1080 hdc1080;
//Connections and constants
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);//LiquidCrystal lcd(8,7,6,5,4,3); //LCD
RTC_DS1307 rtc; //DS1307 i2c
char daysOfTheWeek[7][12] = {"Sunday","Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
const int btSet = A0;
const int btAdj = A1;
const int btAlarm = A2;
const int buzzer = 8;
//const int shakeSensor = A3;
int temp = 0;
long interval = 300;
int melody[] = { 600, 800, 1000,1200 };
//Variables
int DD,MM,YY,H,M,S,set_state, adjust_state, alarm_state,AH,AM, shake_state;
int shakeTimes=0;
int i =0;
int btnCount = 0;
String sDD;
String sMM;
String sYY;
String sH;
String sM;
String sS;
String aH="12";
String aM="00";
String alarm = "     ";
String stemp ;
String shdt;
String shdh;
String sdegreeChar;
long previousMillis = 0;
//Boolean flags
boolean setupScreen = false;
boolean alarmON=false;
boolean turnItOn = false;
void setup() {
  //Init RTC and LCD library items
  rtc.begin();
  lcd.begin(16,2);
  hdc1080.begin(0x40);
  //Set outputs/inputs
  pinMode(btSet,INPUT_PULLUP);
  pinMode(btAdj,INPUT_PULLUP);
  pinMode(btAlarm, INPUT_PULLUP);
  pinMode(buzzer, OUTPUT);
  //Check if RTC has a valid time/date, if not set it to 00:00:00 01/01/2018.
  //This will run only at first time or if the coin battery is low.
  if (! rtc.isrunning()) {
    Serial.println("RTC is NOT running!");
    // This line sets the RTC with an explicit date & time, for example to set
    // January 1, 2018 at 00:00am you would call:
    rtc.adjust(DateTime(2021, 12, 01, 00, 00, 0));
  delay(100);
  //Read alarm time from EEPROM memmory
  AH=EEPROM.read(0);
  AM=EEPROM.read(1);
  //Check if the numbers that you read are valid. (Hours:0-23 and Minutes: 0-59)
  if (AH>23){
    AH=0;
  if (AM>59){
    AM=0;
void loop() {
  temp = analogRead(A6);
  temp = temp * 0.48828125;
  stemp = temp;
  shdt = hdc1080.readTemperature();
  shdh = hdc1080.readHumidity();
  sdegreeChar = String(char(223));
  readBtns();       //Read buttons
  getTimeDate();    //Read time and date from RTC
  if (!setupScreen){
    lcdPrint();     //Normanlly print the current time/date/alarm to the LCD
    if (alarmON){
     callAlarm();   // and check the alarm if set on
  else{
    timeSetup();    //If button set is pressed then call the time setup function
/*************** Functions ****************/
//Read buttons state
void readBtns(){
  set_state = digitalRead(btSet);
  adjust_state = digitalRead(btAdj);
  alarm_state = digitalRead(btAlarm);
  if(!setupScreen){
    if (alarm_state==LOW){
      if (alarmON){
        alarm="     ";
        alarmON=false;
      else{
        alarm="ALARM";
        alarmON=true;
      delay(500);
  if (set_state==LOW){
    if(btnCount<7){
      btnCount++;
      setupScreen = true;
        if(btnCount==1){
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.print("------SET------");
          lcd.setCursor(0,1);
          lcd.print("-TIME and DATE-");
          delay(2000);
          lcd.clear();
    else{
      lcd.clear();
      rtc.adjust(DateTime(YY, MM, DD, H, M, 0)); //Save time and date to RTC IC
      EEPROM.write(0, AH);  //Save the alarm hours to EEPROM 0
      EEPROM.write(1, AM);  //Save the alarm minuted to EEPROM 1
      lcd.print("Saving....");
      delay(2000);
      lcd.clear();
      btnCount=0;
    delay(500);
//Read time and date from rtc ic
void getTimeDate(){
  if (!setupScreen){
    DateTime now = rtc.now();
    DD = now.day();
    MM = now.month();
    YY = now.year();
    H = now.hour();
    M = now.minute();
    S = now.second();
  //Make some fixes...
  if (DD<10){ sDD = '0' + String(DD); } else { sDD = DD; }
  if (MM<10){ sMM = '0' + String(MM); } else { sMM = MM; }
  sYY=YY-2000;
  if (H<10){ sH = '0' + String(H); } else { sH = H; }
  if (M<10){ sM = '0' + String(M); } else { sM = M; }
  if (S<10){ sS = '0' + String(S); } else { sS = S; }
  if (AH<10){ aH = '0' + String(AH); } else { aH = AH; }
  if (AM<10){ aM = '0' + String(AM); }  else { aM = AM; }
//Print values to the display
void lcdPrint(){
  //String line1 = sH+":"+sM+":"+sS+" | "+aH+":"+aM;
  String line1 = sH+":"+sM+":"+sS+"|"+stemp+""+sdegreeChar+"C"+shdh+"%";//+stemp;
  String line2 = sDD+"/"+sMM+"/"+sYY +"|"+aH+":"+aM+""+alarm;
  lcd.setCursor(0,0);//First row
  lcd.print(line1);
  //lcd.setCursor(11,0);
  //lcd.write(223);
  //lcd.print("C");
  lcd.setCursor(0,1); //Second row
  lcd.print(line2);
//Setup screen
void timeSetup(){
  int up_state = adjust_state;
  int down_state = alarm_state;
  if(btnCount<=5){
    if (btnCount==1){         //Set Hour
      lcd.setCursor(4,0);
      lcd.print(">");
      if (up_state == LOW){   //Up button +
        if (H<23){
          H++;
        else {
          H=0;
        delay(350);
      if (down_state == LOW){ //Down button -
        if (H>0){
          H--;
        else {
          H=23;
        delay(350);
    else if (btnCount==2){      //Set  Minutes
      lcd.setCursor(4,0);
      lcd.print(" ");
      lcd.setCursor(9,0);
      lcd.print(">");
        if (M<59){
          M++;
        else {
          M=0;
        delay(350);
        if (M>0){
          M--;
        else {
          M=59;
        delay(350);
    else if (btnCount==3){      //Set Day
      lcd.setCursor(9,0);
      lcd.print(" ");
      lcd.setCursor(0,1);
      lcd.print(">");
        if (DD<31){
          DD++;
        else {
          DD=1;
        delay(350);
        if (DD>1){
          DD--;
        else {
          DD=31;
        delay(350);
    else if (btnCount==4){      //Set Month
      lcd.setCursor(0,1);
      lcd.print(" ");
      lcd.setCursor(5,1);
      lcd.print(">");
        if (MM<12){
          MM++;
        else {
          MM=1;
        delay(350);
        if (MM>1){
          MM--;
        else {
          MM=12;
        delay(350);
    else if (btnCount==5){      //Set Year
      lcd.setCursor(5,1);
      lcd.print(" ");
      lcd.setCursor(10,1);
      lcd.print(">");
        if (YY<2999){
          YY++;
        else {
          YY=2000;
        delay(350);
        if (YY>2018){
          YY--;
        else {
          YY=2999;
        delay(350);
    lcd.setCursor(5,0);
    lcd.print(sH);
    lcd.setCursor(8,0);
    lcd.print(":");
    lcd.setCursor(10,0);
    lcd.print(sM);
    lcd.setCursor(1,1);
    lcd.print(sDD);
    lcd.setCursor(4,1);
    lcd.print("/");
    lcd.setCursor(6,1);
    lcd.print(sMM);
    lcd.setCursor(9,1);
    lcd.print("/");
    lcd.setCursor(11,1);
    lcd.print(sYY);
  else{
    setAlarmTime();
//Set alarm time
void setAlarmTime(){
  String line2;
  lcd.setCursor(0,0);
  lcd.print("SET  ALARM TIME");
  if (btnCount==6){             //Set alarm Hour
      if (AH<23){
        AH++;
      else {
        AH=0;
      delay(350);
      if (AH>0){
        AH--;
      else {
        AH=23;
      delay(350);
    line2 = "    >"+aH+" : "+aM+"    ";
  else if (btnCount==7){        //Set alarm Minutes
      if (AM<59){
        AM++;
      else {
        AM=0;
      delay(350);
      if (AM>0){
        AM--;
      else {
        AM=59;
      delay(350);
    line2 = "     "+aH+" :>"+aM+"    ";
  lcd.setCursor(0,1);
  lcd.print(line2);
void callAlarm(){
  if (aM==sM && aH==sH && S>=0 && S<=2){
    turnItOn = true;
  if(alarm_state==LOW || shakeTimes>=6 || (M==(AM+5))){
    turnItOn = false;
    alarmON=true;
    delay(500);
//if(analogRead(shakeSensor)>200){
  // shakeTimes++;
   // Serial.print(shakeTimes);
   // delay(50);
  if (turnItOn){digitalWrite(buzzer, HIGH);
delay (500);
digitalWrite(buzzer, LOW);
}else{digitalWrite(buzzer, LOW);}
delay(100);
    /*unsigned long currentMillis = millis();
    if(currentMillis - previousMillis > interval) {
      previousMillis = currentMillis;
      tone(buzzer,melody[i],100);
      i++;
      if(i>3){i=0; };
  else{
    noTone(buzzer);
    shakeTimes=0;
Arduino Nano 3.pdsprj
Editat de bogdan546
  • Răspunsuri 5
  • bogdan546
  • Liviu M
  • XAN77
Zile populare
Dacă puneai și hexu poate puteam simula măcar de curiozitate. Pe de altă parte de ce te deranjează că ai ceva de defilat prin meniu până la reglarea alarmei? Bănuiesc că nu o setezi zilnic la ore diferite. Având fizic 4 butoane, parcă atâtea am văzut în proteus, îți poți regândi partea de reglaje cum vrei tu, inclusiv funcții noi la combinații neortodoxe  ale acelor butoane adică 2 apăsate simultan.
Ca sa setezi alarma inainte de timp, cred ca e suficient sa schimbi ordinea if-urilor (apelezi setAlarmTime() la if(btnCount==1) si pentru timp folosesti btnCount == 2..7), dar salvarea in EEPROM tot la sfarsit va fi, dupa ce ai parcurs tot meniul.
Pe de alta parte, chiar functioneaza setarea minutelor pentru alarma? Ca mie mi se pare ca n-ar trebui.
Pe de o parte ai
    if(btnCount<7){
      btnCount++;
    else{
      btnCount=0;
adica btnCount ia valori in intervalul 0 .. 6, pe de alta parte ai:
care n-ar trebui sa fie niciodata adevarat.
Am inteles ce si de ce vrei, da' mi se pare complicat, practic trebuie schimbata complet structura programului...
Oricum, mai sus am gresit, la setat alarma ai nevoie de doua valori pentru btnCount, asa ca potrivit ceasul va incepe de la 3. Sau de la 4 daca folosesti 3 pentru salvat alarmele.
