CADASEDA Postat Noiembrie 10, 2021 Partajează Postat Noiembrie 10, 2021 vand osciloscop digital 4 canale RIGOL DS1054Z Osciloscop digital 4 canale full option 1 700 lei Descriere 50MHz Bandwidth, 4 channels. 1G Sa/s Real-time Sample Rate. 12Mpts (Std.) and 24Mpts (Opt.) Memory Depth. Innovative "UltraVision" technology. Up to 30,000wfms/s Waveform Capture Rate. 7 Inch WVGA (800x480), multiple intensity levels waveform display. Model DS1054Z Bandwidth 50 MHz Analog Channels 4 Sample Rate 1GSa/s (Single-channel), 500MSa/s(Dual-channel), 250MSa/s(Fulll-channel) Max Memory Depth 12Mpts(standard) Max. Waveform Capture rate Up to 30,000 wfms/s Real Time waveform Record and Replay Up to 60, 000 Frames(Opt.) Std. Probes RP2200 150MHz BW Passive Probe:4 sets promotie !!! Optine gratis optiuni software in valoare de € 730 (TVA inclus) la achizitionarea unui osciloscop din seria DS1000Z/MSO1000Z ! Optiunile sunt: SD-DS1000Z Serial Decoder AT-DS1000Z Advanced Trigger MEM-DS1000Z Memory Option REC-DS1000Z Record-Module! Link spre comentariu
CADASEDA Postat Decembrie 2, 2021 Autor Partajează Postat Decembrie 2, 2021 pret negociabil Link spre comentariu
CADASEDA Postat Ianuarie 11, 2022 Autor Partajează Postat Ianuarie 11, 2022 vandut. se poate inchide. Link spre comentariu
