Vizitator Postat Decembrie 19, 2021 Partajează Postat Decembrie 19, 2021 Comanda minima 30 lei, ce apare colorat este rezervat 1. difuzor subwoofer, functional dar suspensia este ciupita intr-un loc 20 lei https://ibb.co/rfTZTf5 https://ibb.co/LvJXVm0 2. difuzoare bas...unul are o bucata lipsa dar merge. 20 lei https://ibb.co/YBxhXD1 https://ibb.co/j3zBT7X 3. cutie cu condensatori electrolitici recuperati valori peste 2200uF----25 lei https://ibb.co/zSX87dR 4. perechi de condensatori electrolitici recuperati valori peste 2200uF 25 lei toate https://ibb.co/NVdkCNB 5. perechi de condensatori electrolitici recuperati valori peste 2200uF 5 lei perechea https://ibb.co/kSLT6Q4 6. lot de becuri vechi recuperate si verificate (chiar si cel mai negru functioneaza) 25 lei numai impreuna https://ibb.co/jMMRh3P 7. traf mare capsulat 12v 17a 60 lei https://ibb.co/F3RLN4S 8. doza pick-up audiotechnica plus headshell saba 100 lei, nu are ac. https://ibb.co/Zck2Q1X https://ibb.co/QD0Yq4Z https://ibb.co/M6dQ4bB https://ibb.co/DR6ybFx 9. reglete cu montare in pcb 10 lei toate https://ibb.co/mcpYV2K 10. doua doze pickup philips cu ac ok, 50 lei bucata https://ibb.co/rpSv9XD https://ibb.co/7g53zpN 11. balamale pickup 5 lei https://ibb.co/rtXZctN 12. motor pick-up 10 lei https://ibb.co/FKXPJXc https://ibb.co/TT19j2T 13. lot motorase recuperate din pickup-uri 15 lei https://ibb.co/XVzFq0F 14. cd-player sony mecanica cu kss150a laser ok, 30 lei, placa electronica 15 lei https://ibb.co/f9Vz7NT https://ibb.co/zQ9QyKX https://ibb.co/pz81hZt 15. cd-changer pioneer mecanica neverificata, avea cablul taiat si nu m-am mai chinuit sa-l schimb 15 lei placa electronica 15 lei, magazie 20 lei https://ibb.co/30jVHdG https://ibb.co/4MhHF8S https://ibb.co/cFvxMhF 16. picioruse aparate 5 lei setul https://ibb.co/6XzKv85 https://ibb.co/QXBv2sb Link spre comentariu
carageae Postat Decembrie 19, 2021 Partajează Postat Decembrie 19, 2021 13, motorase pickup dc le vreau eu. Stii cumva si tensiunile, sau scrie pe ele? Era fain daca aveai si regulatoare sau sunt interne? Link spre comentariu
Vizitator Postat Decembrie 19, 2021 Partajează Postat Decembrie 19, 2021 12v si 9v, unele au regulatoarele inauntru se vad gaurile de la semireglabili. Link spre comentariu
petrebuse Postat Decembrie 19, 2021 Partajează Postat Decembrie 19, 2021 Dozele sund GP215? Le vreau eu. Link spre comentariu
Vizitator Postat Decembrie 19, 2021 Partajează Postat Decembrie 19, 2021 Daca va referiti la dozele Philips, da scrie pe ele 215 KH....discutam prin MP Link spre comentariu
Tanase Ion Postat Decembrie 20, 2021 Partajează Postat Decembrie 20, 2021 Buna ziua, cand mai gasiti vumetre cu leduri si cu ac de ori ce fel si oricate vor fi va rog sa mi le rezervati plus borne cu surub ptr iesiri de difuzoare, va multumesc anticipat cu stima si respect o zi buna Link spre comentariu
sonic11 Postat Decembrie 20, 2021 Partajează Postat Decembrie 20, 2021 Salut. De vumetre cu ac as fi si eu interesat Link spre comentariu
Vizitator Postat Decembrie 22, 2021 Partajează Postat Decembrie 22, 2021 Comanda minima 30 lei, ce apare colorat este rezervat 1. colectie de tranzistori japonezi de mica si medie putere(2sa, 2sb, 2sc, 2sd si 2sk), adunati si sortati in peste 25 de ani,las pozele sa vorbeasca, sunt 6 cutii, in ultima, cea fara poza sunt 2sk, bc-uri, 2n-uri care se dau cadou la cine cumpara toata colectia. Pot garanta ca 99% din tranzistori sunt buni. As prefera sa o vand intreaga cu 1250 lei. https://ibb.co/3MRRxL6 https://ibb.co/44fQfGP https://ibb.co/1ZWPnGw https://ibb.co/KXZz3Zk https://ibb.co/ccYC9mM https://ibb.co/0tpC18p https://ibb.co/6HP50x3 https://ibb.co/LNkqbW9 https://ibb.co/PjbRV6D https://ibb.co/tsyNyR2 https://ibb.co/2v87Kzq https://ibb.co/JR8vSj7 https://ibb.co/Db4fVJR 2. difuzoare bas...unul are o bucata lipsa dar merge. 20 lei https://ibb.co/YBxhXD1 https://ibb.co/j3zBT7X 3. cutie cu condensatori electrolitici recuperati valori peste 2200uF----25 lei https://ibb.co/zSX87dR 4. perechi de condensatori electrolitici recuperati valori peste 2200uF 25 lei toate https://ibb.co/NVdkCNB 5. perechi de condensatori electrolitici recuperati valori peste 2200uF 5 lei perechea https://ibb.co/kSLT6Q4 6. lot de becuri vechi recuperate si verificate (chiar si cel mai negru functioneaza) 25 lei numai impreuna https://ibb.co/jMMRh3P 7. traf mare capsulat 12v 17a 60 lei https://ibb.co/F3RLN4S 8. doza pick-up audiotechnica plus headshell saba 100 lei, nu are ac. https://ibb.co/Zck2Q1X https://ibb.co/QD0Yq4Z https://ibb.co/M6dQ4bB https://ibb.co/DR6ybFx 9. reglete cu montare in pcb 10 lei toate https://ibb.co/mcpYV2K 10. doua doze pickup philips cu ac ok, 50 lei bucata https://ibb.co/rpSv9XD https://ibb.co/7g53zpN 11. balamale pickup 5 lei https://ibb.co/rtXZctN 12. motor pick-up 10 lei https://ibb.co/FKXPJXc https://ibb.co/TT19j2T 13. lot motorase recuperate din pickup-uri 15 lei https://ibb.co/XVzFq0F 14. cd-player sony mecanica cu kss150a laser ok, 30 lei, placa electronica 15 lei https://ibb.co/f9Vz7NT https://ibb.co/zQ9QyKX https://ibb.co/pz81hZt 15. cd-changer pioneer mecanica neverificata, avea cablul taiat si nu m-am mai chinuit sa-l schimb 15 lei placa electronica 15 lei, magazie 20 lei https://ibb.co/30jVHdG https://ibb.co/4MhHF8S https://ibb.co/cFvxMhF 16. picioruse aparate 5 lei setul https://ibb.co/6XzKv85 https://ibb.co/QXBv2sb Link spre comentariu
Tanase Ion Postat Decembrie 23, 2021 Partajează Postat Decembrie 23, 2021 Rezervatimi punctul16 picioruse aparate si cand o sa mai aveti cum v-am rugat sa-mi rezervati ori cel fel de vumetre cu leduri si cu ac, multumesc anticipat cu stima si respect sarbatori fericite si astept in mp sa ma anuntati ce ati mai gasit Link spre comentariu
grosu99 Postat Decembrie 23, 2021 Partajează Postat Decembrie 23, 2021 1 oră în urmă, Tanase Ion a spus: Rezervatimi punctul16 picioruse aparate si cand o sa mai aveti cum v-am rugat sa-mi rezervati ori cel fel de vumetre cu leduri si cu ac, multumesc anticipat cu stima si respect sarbatori fericite si astept in mp sa ma anuntati ce ati mai gasit Stati la pinda si daca prindeti ceva.... Link spre comentariu
Vizitator Postat Decembrie 27, 2021 Partajează Postat Decembrie 27, 2021 (editat) adaug amplificator nordmende 17. traf alimentare 2x37v +2x12v 30 lei https://ibb.co/yWxfrPw 18. placa de baza completa, finali ok dar nu sunt originalii amplificatorului 35 lei https://ibb.co/52gPt60 https://ibb.co/CtP3gGx 19. vumetru cu leduri 25 lei https://ibb.co/nPsBZTr 20. lot butoane aluminiu 15 lei, picioruse 5 lei, potentiometru volum cu loudness 10 lei, borne difuzoare 5 lei https://ibb.co/2KzWVkW 21. preamplificator phono 15 lei, modul cu comutatoare cu panglica 10 lei https://ibb.co/S3Xsyyd Editat Decembrie 27, 2021 de fluffy37 Link spre comentariu
Tanase Ion Postat Decembrie 27, 2021 Partajează Postat Decembrie 27, 2021 (editat) Vumetru cu leduri de la punctul19 si punctele 20 si 21 va rog rezervate la mine si punctul 16 rezervat anterior Editat Decembrie 27, 2021 de Tanase Ion Link spre comentariu
Vizitator Postat Decembrie 27, 2021 Partajează Postat Decembrie 27, 2021 Acum 29 minute, Tanase Ion a spus: Vumetru cu leduri de la punctul19 si punctele 20 si 21 va rog rezervate la mine si punctul 16 rezervat anterior Punctul 20 complet? Link spre comentariu
Tanase Ion Postat Decembrie 27, 2021 Partajează Postat Decembrie 27, 2021 Acum 2 ore, fluffy37 a spus: Punctul 20 complet? Da tot punctul 20 Link spre comentariu
