Vizitator Postat Decembrie 12, 2021 Partajează Postat Decembrie 12, 2021 (editat) Comanda minima 30 lei, ce apare colorat este rezervat, amplificatorul se retrage de la vanzare, suna prea bine. 1. difuzor subwoofer, functional dar suspensia este ciupita intr-un loc 20 lei https://ibb.co/rfTZTf5 https://ibb.co/LvJXVm0 2. difuzoare bas...unul are o bucata lipsa dar merge. 20 lei https://ibb.co/YBxhXD1 https://ibb.co/j3zBT7X 3. cutie cu condensatori electrolitici recuperati valori peste 2200uF----25 lei https://ibb.co/zSX87dR 4. perechi de condensatori electrolitici recuperati valori peste 2200uF 25 lei toate https://ibb.co/NVdkCNB 5. perechi de condensatori electrolitici recuperati valori peste 2200uF 5 lei perechea https://ibb.co/kSLT6Q4 6. lot de becuri vechi recuperate si verificate (chiar si cel mai negru functioneaza) 25 lei numai impreuna https://ibb.co/jMMRh3P 7. traf mare si greu,2x33v, 2x20v 30 lei https://ibb.co/9gbmPVB 8. traf mare capsulat 12v 17a 60 lei https://ibb.co/F3RLN4S 9. lot 3 trafo, vezi tensiuni in poza 25 lei https://ibb.co/tY4S9pq 10. doza pick-up audiotechnica plus headshell saba 100 lei, nu are ac. https://ibb.co/Zck2Q1X https://ibb.co/QD0Yq4Z https://ibb.co/M6dQ4bB https://ibb.co/DR6ybFx 11. reglete cu montare in pcb 10 lei toate https://ibb.co/mcpYV2K 12. doua doze pickup philips cu ac ok, 50 lei bucata https://ibb.co/rpSv9XD https://ibb.co/7g53zpN combina veche siemens 13. trafo alimentare 20 lei, mecanica completa deck 10 lei https://ibb.co/VNzrs5m https://ibb.co/64MKZF2 14. etaj final finali ok dar nu sunt originali 30 lei https://ibb.co/vQK3NNy https://ibb.co/mtWwktD 15. module radio plus ce se mai vede in poza 35 lei https://ibb.co/PGRyDYN 16. module casetofon plus ce se vede in poza 25 lei https://ibb.co/kqN7jsY 17. butoane 10 lei,indicator 5 lei, modul senzori 15 lei https://ibb.co/PYxHmNK 18. vumetre cu ace 20 lei https://ibb.co/ctFnfTd combina sony 19. mecanica cd cu kss-240 ok, 30 lei https://ibb.co/t8w42RV https://ibb.co/8r4cB0r 20. restul de module 20 lei toate https://ibb.co/tb2jFMj 21. picioruse aparate 5 lei setul https://ibb.co/XFgpGyX combina veche europhon 22. trafo alimentare 15 lei, mecanica deck 10 lei https://ibb.co/4FkL6fN https://ibb.co/JyDK0P8 23. modul radio 20 lei https://ibb.co/x790sY7 24.modul deck plus etaj final 30lei https://ibb.co/rMGQ1hc https://ibb.co/d2T8WfG combina veche siemens 25. traf alimentare 15 lei, mecanica deck 10 lei, butoane 5 lei toate, picioruse 5 lei tot setul https://ibb.co/rQF1zTR https://ibb.co/3vqkYWZ 26. egalizator 10 lei, restul de potentiometre 15 lei toate, indicator 5 lei https://ibb.co/X2F5XGr 27. modul radio si etaj final 35 lei https://ibb.co/DM6hFnw https://ibb.co/c1nGdYd 28. balamale pickup 5 lei, borne difuzor 5 lei https://ibb.co/rtXZctN radio cu lampi radione jupiter w--------------tot continutul 150 lei sau 29. traf alimentare 30 lei, traf iesire 25 lei https://ibb.co/r23QFtM https://ibb.co/hYTyDNK 30. bobine 20 lei toate https://ibb.co/PxphGr2 https://ibb.co/0jdt0GY 31. variabil 20 lei, lot butoane 15 lei https://ibb.co/w0nmCLv https://ibb.co/DtgbxxC 32. lot lampi (numai impreuna,nu dau la bucata) 70 lei https://ibb.co/PW8JmnL 33. difuzoare 30 lei impreuna https://ibb.co/VQJc8vG https://ibb.co/0tM1xxg 34. 3 trafo retea din amplificatoare, cel de 2x55v costa 80 lei, cel negru 25 , cel mic 20 lei https://ibb.co/qp5YWwZ https://ibb.co/5546Fc8 35. 2 trafo retea din amplificatoare, 40 lei cel mare, 25 lei cel mic https://ibb.co/KXrFsqF Editat Decembrie 12, 2021 de fluffy37 Link spre comentariu
adynel Postat Decembrie 12, 2021 Partajează Postat Decembrie 12, 2021 Trafo de 2x55v îl cumpăr eu. Link spre comentariu
carageae Postat Decembrie 12, 2021 Partajează Postat Decembrie 12, 2021 De la 34 vreau eu cel mic si de la 35 ambele. Link spre comentariu
Vizitator Postat Decembrie 13, 2021 Partajează Postat Decembrie 13, 2021 (editat) Am rezervat trafurile cerute. Adaug radio grundig rtv-360 sau 380, nu mai stiu exact, variabil blocat, era functional in rest. 36. traf alimentare 20 lei, butoane 5 lei, indicator 5 lei https://ibb.co/cwBTSZX https://ibb.co/ryzbz5T 37. module radio 25 lei toate https://ibb.co/HNTRkCD 38. etaj final cu AD-uri 25 lei https://ibb.co/dtG3zSQ https://ibb.co/8BRKQ7T 39. placa de baza 20 lei https://ibb.co/rbmpPYf https://ibb.co/HBtrxtC Editat Decembrie 13, 2021 de fluffy37 Link spre comentariu
hamatdumitru Postat Decembrie 13, 2021 Partajează Postat Decembrie 13, 2021 Rog eu: 38. etaj final cu AD-uri 25 lei Link spre comentariu
Tanase Ion Postat Decembrie 13, 2021 Partajează Postat Decembrie 13, 2021 (editat) Rezervatimi butoanele si indicatorul de la punctul 36 plus cele rezervate deja Editat Decembrie 13, 2021 de Tanase Ion Link spre comentariu
carageae Postat Decembrie 13, 2021 Partajează Postat Decembrie 13, 2021 Traful de alimentare Grundig de la 36 il vreau eu daca mai este Link spre comentariu
Vittorino Postat Decembrie 13, 2021 Partajează Postat Decembrie 13, 2021 Va salut! Adaugati la mine: 37. module radio 25 lei toate https://ibb.co/HNTRkCD 39. placa de baza 20 lei https://ibb.co/rbmpPYf https://ibb.co/HBtrxtC Multumesc mult. Link spre comentariu
Vizitator Postat Decembrie 14, 2021 Partajează Postat Decembrie 14, 2021 Comanda minima 30 lei, ce apare colorat este rezervat, amplificatorul se retrage de la vanzare, suna prea bine. 1. difuzor subwoofer, functional dar suspensia este ciupita intr-un loc 20 lei https://ibb.co/rfTZTf5 https://ibb.co/LvJXVm0 2. difuzoare bas...unul are o bucata lipsa dar merge. 20 lei https://ibb.co/YBxhXD1 https://ibb.co/j3zBT7X 3. cutie cu condensatori electrolitici recuperati valori peste 2200uF----25 lei https://ibb.co/zSX87dR 4. perechi de condensatori electrolitici recuperati valori peste 2200uF 25 lei toate https://ibb.co/NVdkCNB 5. perechi de condensatori electrolitici recuperati valori peste 2200uF 5 lei perechea https://ibb.co/kSLT6Q4 6. lot de becuri vechi recuperate si verificate (chiar si cel mai negru functioneaza) 25 lei numai impreuna https://ibb.co/jMMRh3P 7. traf mare si greu,2x33v, 2x20v 30 lei https://ibb.co/9gbmPVB 8. traf mare capsulat 12v 17a 60 lei https://ibb.co/F3RLN4S 9. lot 3 trafo, vezi tensiuni in poza 25 lei https://ibb.co/tY4S9pq 10. doza pick-up audiotechnica plus headshell saba 100 lei, nu are ac. https://ibb.co/Zck2Q1X https://ibb.co/QD0Yq4Z https://ibb.co/M6dQ4bB https://ibb.co/DR6ybFx 11. reglete cu montare in pcb 10 lei toate https://ibb.co/mcpYV2K 12. doua doze pickup philips cu ac ok, 50 lei bucata https://ibb.co/rpSv9XD https://ibb.co/7g53zpN combina veche siemens 13. trafo alimentare 20 lei, mecanica completa deck 10 lei https://ibb.co/VNzrs5m https://ibb.co/64MKZF2 14. etaj final finali ok dar nu sunt originali 30 lei https://ibb.co/vQK3NNy https://ibb.co/mtWwktD 15. module radio plus ce se mai vede in poza 35 lei https://ibb.co/PGRyDYN 16. module casetofon plus ce se vede in poza 25 lei https://ibb.co/kqN7jsY 17. butoane 10 lei,indicator 5 lei, modul senzori 15 lei https://ibb.co/PYxHmNK 18. vumetre cu ace 20 lei https://ibb.co/ctFnfTd combina sony 19. mecanica cd cu kss-240 ok, 30 lei https://ibb.co/t8w42RV https://ibb.co/8r4cB0r 20. restul de module 20 lei toate https://ibb.co/tb2jFMj 21. picioruse aparate 5 lei setul https://ibb.co/XFgpGyX combina veche europhon 22. trafo alimentare 15 lei, mecanica deck 10 lei https://ibb.co/4FkL6fN https://ibb.co/JyDK0P8 23. modul radio 20 lei https://ibb.co/x790sY7 24.modul deck plus etaj final 30lei https://ibb.co/rMGQ1hc https://ibb.co/d2T8WfG combina veche siemens 25. traf alimentare 15 lei, mecanica deck 10 lei, butoane 5 lei toate, picioruse 5 lei tot setul https://ibb.co/rQF1zTR https://ibb.co/3vqkYWZ 26. egalizator 10 lei, restul de potentiometre 15 lei toate, indicator 5 lei https://ibb.co/X2F5XGr 27. modul radio si etaj final 35 lei https://ibb.co/DM6hFnw https://ibb.co/c1nGdYd 28. balamale pickup 5 lei, borne difuzor 5 lei https://ibb.co/rtXZctN radio cu lampi radione jupiter w--------------tot continutul 150 lei sau 29. traf alimentare 30 lei, traf iesire 25 lei https://ibb.co/r23QFtM https://ibb.co/hYTyDNK 30. bobine 20 lei toate https://ibb.co/PxphGr2 https://ibb.co/0jdt0GY 31. variabil 20 lei, lot butoane 15 lei https://ibb.co/w0nmCLv https://ibb.co/DtgbxxC 32. lot lampi (numai impreuna,nu dau la bucata) 70 lei https://ibb.co/PW8JmnL 33. difuzoare 30 lei impreuna https://ibb.co/VQJc8vG https://ibb.co/0tM1xxg 34. 3 trafo retea din amplificatoare, cel de 2x55v costa 80 lei, cel negru 25 , cel mic 20 lei https://ibb.co/qp5YWwZ https://ibb.co/5546Fc8 35. 2 trafo retea din amplificatoare, 40 lei cel mare, 25 lei cel mic https://ibb.co/KXrFsqF 36. traf alimentare 20 lei, butoane 5 lei, indicator 5 lei https://ibb.co/cwBTSZX https://ibb.co/ryzbz5T 37. module radio 25 lei toate https://ibb.co/HNTRkCD 38. etaj final cu AD-uri 25 lei https://ibb.co/dtG3zSQ https://ibb.co/8BRKQ7T 39. placa de baza 20 lei https://ibb.co/rbmpPYf https://ibb.co/HBtrxtC radio philips vezi model in poza 40. placa de baza, finali ok 35 lei https://ibb.co/xG1PSnj https://ibb.co/9bnYqf5 https://ibb.co/BC1GVhN 41. traf alimentare 20 lei, butoane 5 lei, potentiometru volum cu priza loudness 5 lei https://ibb.co/gWkK7yd https://ibb.co/Q6W7kW8 42. indicator 5 lei, variabil 5 lei, modul posturi fixe 10 lei https://ibb.co/g3SSxyf https://ibb.co/JRJcXvt Link spre comentariu
Tanase Ion Postat Decembrie 14, 2021 Partajează Postat Decembrie 14, 2021 Rezervatimi de la punctul41 butoane si potentiometru si de la 42 indicatorul Link spre comentariu
hamatdumitru Postat Decembrie 14, 2021 Partajează Postat Decembrie 14, 2021 (editat) Rog eu: 40. placa de baza, finali ok 35 lei 41. traf alimentare 20 lei Editat Decembrie 14, 2021 de hamatdumitru Link spre comentariu
Vittorino Postat Decembrie 14, 2021 Partajează Postat Decembrie 14, 2021 (editat) Va salut! Rezervati la mine: 42. variabil 5 lei, modul posturi fixe 10 lei https://ibb.co/g3SSxyf https://ibb.co/JRJcXvt Multumesc mult. Editat Decembrie 14, 2021 de Vittorino Link spre comentariu
Vizitator Postat Decembrie 16, 2021 Partajează Postat Decembrie 16, 2021 Comanda minima 30 lei, ce apare colorat este rezervat, amplificatorul se retrage de la vanzare, suna prea bine. 1. difuzor subwoofer, functional dar suspensia este ciupita intr-un loc 20 lei https://ibb.co/rfTZTf5 https://ibb.co/LvJXVm0 2. difuzoare bas...unul are o bucata lipsa dar merge. 20 lei https://ibb.co/YBxhXD1 https://ibb.co/j3zBT7X 3. cutie cu condensatori electrolitici recuperati valori peste 2200uF----25 lei https://ibb.co/zSX87dR 4. perechi de condensatori electrolitici recuperati valori peste 2200uF 25 lei toate https://ibb.co/NVdkCNB 5. perechi de condensatori electrolitici recuperati valori peste 2200uF 5 lei perechea https://ibb.co/kSLT6Q4 6. lot de becuri vechi recuperate si verificate (chiar si cel mai negru functioneaza) 25 lei numai impreuna https://ibb.co/jMMRh3P 8. traf mare capsulat 12v 17a 60 lei https://ibb.co/F3RLN4S 10. doza pick-up audiotechnica plus headshell saba 100 lei, nu are ac. https://ibb.co/Zck2Q1X https://ibb.co/QD0Yq4Z https://ibb.co/M6dQ4bB https://ibb.co/DR6ybFx 11. reglete cu montare in pcb 10 lei toate https://ibb.co/mcpYV2K 12. doua doze pickup philips cu ac ok, 50 lei bucata https://ibb.co/rpSv9XD https://ibb.co/7g53zpN 28. balamale pickup 5 lei https://ibb.co/rtXZctN Link spre comentariu
Tanase Ion Postat Decembrie 17, 2021 Partajează Postat Decembrie 17, 2021 Confirm ridicate colet, produsele au ajuns bine, multumesc frumos ptr bonus, cu respect si stima o zi buna Link spre comentariu
Vizitator Postat Decembrie 17, 2021 Partajează Postat Decembrie 17, 2021 Multumec si eu, domnule Tanase. adaug 3 tunere propuse spre dezmembrare, unul din cele mici functioneaza impecabil, al doilea mic merge doar pe fm, cel mare merge doar FM-ul. Neservisate, se vand impreuna cu 150 lei sau 100 lei cel mare si 50 lei fiecare din cele mici https://ibb.co/87Pw4jH https://ibb.co/n0ZNRqW Link spre comentariu
