dezmembrari audio
  • Răspunsuri 379
  • Tanase Ion
    41
  • carageae
    39
  • imreberes
    22
  • Vittorino
    20
Acum 12 ore, Budreala Radu a spus:
Punctul 15, magnetofonul Philips, va rog la mine!
magnetofon philips n4510,optic impecabil, nefunctional, adica becurile la vumetre se aprind dar nu face nici o comanda. Neumblat interior, doar ce l-am adus. Pret 150 lei------pana luni, apoi il dezmembrez
https://ibb.co/zmkHxr7
https://ibb.co/8dmyhJB
https://ibb.co/Kw11kk1
comanda minima 30 lei-----------ce apare colorat este rezervat
1.  parte mecanica casetofon completa 10 lei
https://ibb.co/CsKdD1n
https://ibb.co/qYZJKdk
2. modul radio 20 lei
https://ibb.co/Vqn4J0g
3. 2 mecanisme pickup fara doze  40 lei amandoua
https://ibb.co/X4f7tJQ
https://ibb.co/W6nRz25
https://ibb.co/jzwBz0y
https://ibb.co/N38wZ9x
4. difuzor subwoofer, functional dar suspensia este ciupita intr-un loc 25 lei
https://ibb.co/rfTZTf5
https://ibb.co/LvJXVm0
5. piese provenind din aparate electrice functionale 15 lei toate
https://ibb.co/8DyKZNL
6. preamplificator corector de ton 20 lei
https://ibb.co/KDzXWxN
7. volum motorizat 15 lei, comutatoarele cadou
https://ibb.co/SmrV360
 deck sony
8. mecanica completa si functionala 25 lei
https://ibb.co/v34HQrt
https://ibb.co/2Pw5BNz
9. placa de baza cu NE646=dolby 20lei
https://ibb.co/GkPRGf0
10. butoane, picioruse 10 lei totul
https://ibb.co/5vf1F8j
11. traf 5lei,vumetru cu leduri 15 lei
https://ibb.co/Tkt54sD
magnetofon cu lampi hornyphon
12. sasiu complet cu traf iesire 30 lei
https://ibb.co/Rz6WcY1
https://ibb.co/Vj5KdKQ
13. traf alimentare 30 lei, difuzor 5 lei, motor 5 lei, ochi magic 10 lei
https://ibb.co/R3wJVHW
https://ibb.co/54ZGKzW
14. pickup philips cu lampi functional audio, sunet bun, dar nu invarte discul (eventual ajutat cu mana).Fara interventii interioare, 70lei sau il dezmembrez desi e pacat, arata foarte bine
https://ibb.co/xq4B3jF
https://ibb.co/k1BQfCp
https://ibb.co/Snd8Zp0
https://ibb.co/M7XFHTY
15. magnetofon philips n4510,optic impecabil, nefunctional, adica becurile la vumetre se aprind dar nu face nici o comanda. Neumblat interior, doar ce l-am adus. Pret 150 lei------pana luni, apoi il dezmembrez
combina philips,nu mai stiu modelul ceva cu studio center
16. brat pickup cu contragreutate , doza si ac 30 lei, trafo alimentare 20 lei
https://ibb.co/5hPYXbm
https://ibb.co/4mZsrKy
17. modul radio complet 25 lei
https://ibb.co/ZfYZH6P
https://ibb.co/1vS39mY
18. etaj final  25 lei
https://ibb.co/Nsd9mJs
19.corector ton 10 lei,electronica deck 10 lei
https://ibb.co/Ph9DZ3y
boxe jvc s66 functionale
20. difuzoare bas...unul are o bucata lipsa dar merge. 25 lei
https://ibb.co/YBxhXD1
https://ibb.co/j3zBT7X
21. difuzoare medii 25 lei, difuzoare inalte 25lei, filtre 20 lei
https://ibb.co/XVz9VBk
https://ibb.co/ZBFstyr
22. cutie goala buna pentru o sursa 10 lei
https://ibb.co/hVzmFjD
https://ibb.co/WHnJtbs
https://ibb.co/DkHm4L4
23. motoras pe 220v 10 lei
https://ibb.co/wstB8nz
https://ibb.co/gvqm15C
combina philips neverificata, nu mai stiu modelul
24. electronica cd 10 lei
https://ibb.co/1G8QynF
25. electronica deck 10 lei
https://ibb.co/3NNLgpR
26. bloc optic in camp magnetic 20 lei
https://ibb.co/0mbdNYM
https://ibb.co/fMr3G6X
27. 2 mecanisme deck complete cu curele bune 20lei ambele
https://ibb.co/Kjg00Fj
https://ibb.co/kJQpGxz
28. tot ce se vede in poza 20 lei
https://ibb.co/9brNqNz
29. tot ce se vede in poza 20 lei
https://ibb.co/BZcKLdK
30. radio cu lampi Philips, mort complet, neumblat inauntru, 130 lei asa cum se vede sau pe bucati.
https://ibb.co/Lpkdk6w
https://ibb.co/v4M1j9q
https://ibb.co/BGCbSkm
https://ibb.co/Kr1xvZy
Acum 17 ore, Budreala Radu a spus:
Am primit magnetofonul azi, ambalat ireproșabil! Un mare up de la mine!
Multumesc si eu!
 deck sony
31. deck ITT, foarte greu, necesita curele, neumblat interior 40 lei sau se poate dezmembra . Lipseste un buton la un potentiometru.
https://ibb.co/NmKg9zP
https://ibb.co/6XWFqXK
combina philips
32. corector ton plus etaje finale ok 30 lei
https://ibb.co/XXHb7V6
33. set butoane 5 lei, placa electronica deck plus motoras 5 lei, balamale pickup 5 lei
https://ibb.co/V2D01bL
34. modul radio 20 lei
https://ibb.co/pPLWZgy
35. trafo alimentare plus restul din poza 20 lei
https://ibb.co/NNXn90V
Editat de fluffy37
Va salut!
Rezerv eu:
Lasam lista deschisa... poate pana pe joi-vineri mai apare ceva de radio cu bobinute.
Multumesc pentru intelegere.
Acum 20 ore, Budreala Radu a spus:
Poate apare și un pickup deck...
V-am lasat un mesaj privat.
@cristis, nu mai exista pozitia 1, doar ultimul post este valabil.
 deck sony
combina philips
radio cu lampi hornyphon prinzess dupa cum urmeaza
https://ibb.co/LhL0P0V
36. difuzoare 20 lei
https://ibb.co/37V1vCw
https://ibb.co/WGC7XVY
37. toate lampile, numai impreuna 50 lei, 4 butoane 15 lei toate
https://ibb.co/mGGDnbv
38. sasiu complet 40 lei
https://ibb.co/VL1vkMf
https://ibb.co/5xgbTxs
https://ibb.co/h1nM3n1
Restructurare topic
Comanda minima 30 lei
1. difuzor subwoofer, functional dar suspensia este ciupita intr-un loc 25 lei
2. difuzoare bas...unul are o bucata lipsa dar merge. 25 lei
3. mecanica completa si functionala deck sony 25 lei
boxe schneider perfect functionale, carcase varza
4. difuzoare inalte 30lei
https://ibb.co/P4BW8Dy
https://ibb.co/SvJVF9D
5. difuzoare bas, diam 20cm,diam magnet 10 cm 50 lei
https://ibb.co/nQddbHk
https://ibb.co/BrHSNq5
6. modul cu ceva irf-uri 10 lei
https://ibb.co/Q7g1ZLt
7. picioruse aparate 5 lei setul
https://ibb.co/02bg3Vz
https://ibb.co/dWgGWPc
8. modul deck 10 lei bucata
https://ibb.co/ftj7bVZ
https://ibb.co/HGmc5M8
9. 2 module 10lei ambele
https://ibb.co/CwW5475
10. placa cd -player 5 lei
https://ibb.co/fxkC5vH
11. corectoare ton 15 lei bucata
https://ibb.co/yn897Cv
https://ibb.co/vwTyjZh
https://ibb.co/qF3Rp5D
12. tot ce se vede in poza 10 lei
https://ibb.co/ryC45PJ
13. module radio 30 lei totul
https://ibb.co/2g52sQ7
14. tot ce se vede in poza 10 lei
https://ibb.co/J5fRP6q
amplituner philips
15. trafo alimentare 25 lei
https://ibb.co/prprTPz
16. etaj final cu bdt-uri bune 40 lei
https://ibb.co/qFpC6Rj
https://ibb.co/4Tx910X
https://ibb.co/fpPYJFG
17. corector ton plus volum 20 lei
https://ibb.co/C1RLQx7
18.module radio si intrari 20 lei
https://ibb.co/Pxtpb0T
Editat de fluffy37
