zvasile Postat Octombrie 22, 2021 Partajează Postat Octombrie 22, 2021 Stie cineva cum se intra? am incercat asa dar nu merge, ''Cu CH99 analogic selectat, intrati în modul de service 1. Navigati la ultima reglare în modul de service 1 folosind tasta verde. Apasati tasta HOLD si acest lucru va duce în modul de service 2'' ultimul reglaj este Sub-Brightness, sasiul este GLP21 Link spre comentariu
iuliantv Postat Octombrie 22, 2021 Partajează Postat Octombrie 22, 2021 (editat) ce ati incercat dv cred ca e pentru crt incercati LCD Method 2 Start with the TV Turned On. Hold down the {VOL -} button on the tv. Press the info button on the remote 3 times, and the service menu should show. TV Method 1 Hold down the {VOL -} button ON THE TV. Press the {RECALL} or {INFO} button 3 times on the remote. The Service Menu will be displayed. Use {1} {2} on remote to navigate main menu items. Use {3} {4} on remote to navigate sub-menu items. Use {VOL+} {VOL -} on remote to change item value. Power off to exit service mode and save. TV Method 2 Hold down the {VOL -} button on the TV Then press the {0} button 3 times on the remote. To exit, press the {EXIT} button or turn the power off. How to enter into Service Mode While pressing [VOLUME ( - )] button on the main unit, press the [RED] button on the remote control for 3 times within 2 seconds. How to exit Switch off the power with the [POWER] button on the main unit or the [POWER] button on the remote control. sau How to enter into Service Mode While pressing [VOLUME ( - )] button on the main unit, press the [info ] button on the remote control for 3 times within 2 seconds. How to exit Switch off the power with the [POWER] button on the main unit or the [POWER] button on the remote control. sau How to enter into Service Mode While pressing [VOLUME ( - )] button on the main unit, press the [0] button on the remote control for 3 times within 2 seconds. How to exit Switch off the power with the [POWER] button on the main unit or the [POWER] button on the remote control. oricum mai nimic important de setat prin service la panasonic,plus menu service foarte stufos,creu de inteles,setari,memorari,te pierzi ,in cifre si litere Editat Octombrie 22, 2021 de iuliantv Link spre comentariu
zvasile Postat Octombrie 22, 2021 Autor Partajează Postat Octombrie 22, 2021 nu merge,in service 1 am intrat cu secventa de mai jos, ma poate cineva ajuta cu dumpul de aici? https://remont-aud.net/dump/lcd_dvd_tv/panasonic/panasonic_tx_32lxd60_shassi_main_board_glp21/324-1-0-48640 Link spre comentariu
zvasile Postat Octombrie 23, 2021 Autor Partajează Postat Octombrie 23, 2021 nu mai este nevoie de dump,in mare parte am rezolvat dar tot nu am reusit sa intru in service 2 Link spre comentariu
