stefan94stefan Postat Octombrie 18, 2021 Partajează Postat Octombrie 18, 2021 (editat) Salutare , Cine ma poate ajuta cu denumirea acestui cablu USB 3.0 provine de la un front panel al unei carcase Cooler Master HAF X si vine montat pe un PCB insa doar cu suruburi si un cablu mic pentru a lua impamantare de pe carcasa? Am nevoie sa stie cum il pot gasi de cumparat !? Atasez cateva poze : https://i.imgur.com/q2gA8Pi.jpg https://i.imgur.com/Piu6ZhK.jpg https://i.imgur.com/yBJn8Y3.jpg https://i.imgur.com/Suldjhn.jpg Editat Octombrie 18, 2021 de stefan94stefan Corectare linkuri poze Link spre comentariu
Kuki Postat Octombrie 18, 2021 Partajează Postat Octombrie 18, 2021 https://www.google.com/search?sxsrf=AOaemvI5DEg_WQ2hSNvPkqF9ZPbhEWg6ow:1634573093329&source=univ&tbm=isch&q=usb3+front+panel&client=avast-a-1&fir=Htnhj9TRc7BZNM%2CypOHR9-qO5io5M%2C_%3BbkkMSPdPH7-L8M%2Ca--6BGEGK9-aMM%2C_%3Bjqz0KheSJmlKfM%2CMltZPQrIoHnA1M%2C_%3BpdToWN3916ZG1M%2CZeFbabBDBHKLuM%2C_%3BpgBkO_PmJgUW2M%2CcnxV5fY4WBeItM%2C_%3BeaONq5d3wwyhcM%2C5kOXD-1TTVvQRM%2C_%3BmhvqjfVGFXuRqM%2CN4qWeyigCiCCcM%2C_%3BG-P_9qrDXFkTjM%2Cj5SFK0U3uDb2vM%2C_%3Bs1NLM94FOW8eCM%2C0JUfLB5NaaO5VM%2C_%3BDX30ufgYnq2ecM%2CZZTEhE3vyPwlAM%2C_%3Blzz4AZUJKVzSaM%2CcobY68ZgD3pidM%2C_%3BB5apTAtQbnvK8M%2C8XR_R5igrvi5aM%2C_%3BehI_y6zSxEIsSM%2CLkCw3G6mLPTdzM%2C_%3Bf8R4CsCVLRDrSM%2Cj5SFK0U3uDb2vM%2C_%3B5EiVM7dGX5iYpM%2C6ty8Vl8tKqsiDM%2C_&usg=AI4_-kQKaNooUI4uKi5WLfyJkrmXS24lvQ&sa=X&ved=2ahUKEwiWzNikq9TzAhUNhf0HHWonA7cQjJkEegQIEBAC&biw=2263&bih=1300&dpr=1.5 Link spre comentariu
stefan94stefan Postat Octombrie 19, 2021 Autor Partajează Postat Octombrie 19, 2021 Nu am nevoie de tot panelul doar acel cablu cu porturi usb 3.0 Link spre comentariu
stryx Postat Octombrie 20, 2021 Partajează Postat Octombrie 20, 2021 Exact modelul acela nu am gasit. Totusi se poate adapta un cablu de genul asta: https://www.ebay.co.uk/itm/233138735661?hash=item364826ca2d:g:EmsAAOSwU21fW1-B sau: https://www.ebay.co.uk/itm/402579508322?hash=item5dbb9bcc62:g:PFgAAOSwloxfv5vH Totusi trebuie sa fi atent ca genul asta de cabluri se gasesc cu mai multe lungimi. Link spre comentariu
stefan94stefan Postat Octombrie 22, 2021 Autor Partajează Postat Octombrie 22, 2021 (editat) La 20.10.2021 la 15:16, stryx a spus: Exact modelul acela nu am gasit. Totusi se poate adapta un cablu de genul asta: https://www.ebay.co.uk/itm/233138735661?hash=item364826ca2d:g:EmsAAOSwU21fW1-B sau: https://www.ebay.co.uk/itm/402579508322?hash=item5dbb9bcc62:g:PFgAAOSwloxfv5vH Totusi trebuie sa fi atent ca genul asta de cabluri se gasesc cu mai multe lungimi. Da fix cam asta este ce mi-ar trebui , am contactat Cooler Master pe e-mail dar ei nu mai produc piese pt tipul acela de carcasa si trebuie sa adaptez ceva . Multumesc ! Editat Octombrie 22, 2021 de stefan94stefan adaugare info Link spre comentariu
