merck Postat Septembrie 12, 2021 Partajează Postat Septembrie 12, 2021 (editat) Ca sa nu mai "murdarim" topicul lui @Усилитель, propun sa ne mutam aici. De la Crowhurst citire: There are three kinds of shielding: magnetic, electromagnetic, and electric. Magnetic shielding prevents the magnetic field that causes the induction from reaching the low-level circuit. The entire circuit or transformer is surrounded by the shield. The inducing field passes into the shield, around the circuit to be shielded and out at the other side. This reduces the induction inside the shield by a factor dependent upon the permeability of the magnetic material of which the shield is made, the thickness of this material that provides a magnetic conducting path, and the frequency of the magnetic fluctuation. Magnetic shielding is most effective against steady magnetic fields and low-frequency induction, such as hum. At higher frequencies, it becomes less and less effective because the magnetism takes time to be induced in the material of the shield. The faster the inducing magnetic field fluctuates, the less effective the shield is in conveying the magnetic field around the shielded circuit. Electromagnetic Shielding The second type of shielding uses a different principle, but is also effective against magnetic fields. Electromagnetic shielding does not use a magnetic material, but rather one that conducts electric current well, such as copper or aluminum. When the magnetic field causing the induction fluctuates, it causes current to flow in the shield. This current in the shield sets up its own magnetic field that opposes the original inducing magnetism, and the two fields tend to cancel inside the shield. Outside the shield, the two fields are in the same direction and the combined magnetic field is increased. Therefore, this kind of shield has the effect of "pushing" the inducing field outward, instead of permitting it to reach the shielded circuits. Because it depends on fluctuating fields, this kind of shield is completely ineffective against steady magnetism. It is also comparatively ineffective against low-frequency fluctuation, and only becomes really effective at higher frequencies. sursa: http://www.vias.org/crowhurstba/crowhurst_basic_audio_vol3_040.html Editat Septembrie 12, 2021 de merck Link spre comentariu
simson Postat Septembrie 12, 2021 Partajează Postat Septembrie 12, 2021 Propun ca citatele in limba engleza sa fie postate tradus asta ca sa fie citite de toti. Eu de exemplu nu am rabdare si nici timp sa migalesc translator cum cred ca sunt si altii. Link spre comentariu
dumitrumy Postat Septembrie 12, 2021 Partajează Postat Septembrie 12, 2021 Există trei tipuri de ecranare: magnetică, electromagnetică și electrică. Ecranul magnetic previne câmpul magnetic care determină inducția să ajungă la circuitul de nivel scăzut. Întregul circuit sau transformator este înconjurat de scut. Câmpul de inducere trece prin scut, ocoleşte circuitul care urmează să fie protejat și iesee pe cealaltă parte. Acest lucru reduce inducția în interiorul ecranului cu un factor dependent de permeabilitatea materialului magnetic din care este fabricat ecranul, grosimea acestui material care asigură o cale magnetică de conducere și de frecvența fluctuației magnetice. Ecranul magnetic este cel mai eficient împotriva câmpurilor magnetice staţionare și a inducției de joasă frecvență, prevenind efecte cum ar fi brumul indus. La frecvențe mai mari, devine din ce în ce mai puțin eficient, deoarece magnetismul are nevoie de timp pentru a fi indus în materialul scutului (histerezisul materialului). Cu cât fluctuează mai rapid câmpul magnetic inducător, cu atât scutul este mai puțin eficient în transmiterea câmpului magnetic în jurul circuitului ecranat. Ecranare electromagnetică Al doilea tip de ecranare folosește un principiu diferit, dar este eficient și împotriva câmpurilor magnetice. Ecranul electromagnetic nu folosește un material magnetic, ci mai degrabă unul care conduce bine curentul electric, cum ar fi cuprul sau aluminiul. Când câmpul magnetic care provoacă inducția fluctuează, acesta determină curentul indus astfel să se scurgă prin ecran. Acest curent indus din scut își configurează propriul câmp magnetic care se opune magnetismului inductor original, iar cele două câmpuri tind să se anuleze în interiorul scutului. În afara ecranului, cele două câmpuri sunt în aceeași direcție și câmpul magnetic combinat este mărit. Prin urmare, acest tip de scut are efectul de a „împinge” câmpul inductor spre exterior, în loc să-i permită să ajungă la circuitele ecranate. Deoarece depinde de câmpuri fluctuante, acest tip de scut este complet ineficient împotriva magnetismului constant. De asemenea, este relativ ineficient împotriva fluctuațiilor de frecvență joasă și devine efectiv numai la frecvențe mai mari. Link spre comentariu
icar Postat Septembrie 13, 2021 Partajează Postat Septembrie 13, 2021 @simson, perfect de acord cu tine. Asta ca sa nu facem apel si la legile bunului simt privind folosirea limbilor straine. @dumitrumy, perfect adevarat ce spui, intarind asfel cele spuse si de mine. Dar...problema ramine nerezolvata: schimba, sau nu, ecranul de fier, sau cupru, inductanta trafului? Ca despre asta se face vorbire, nu despre ce fel de ecran se foliseste si in ce scop. Adica, se incumeta cineva sa faca niste masurari? Link spre comentariu
dumitrumy Postat Septembrie 13, 2021 Partajează Postat Septembrie 13, 2021 CITAT 1: Postat 14 ore în urmă Propun ca citatele in limba engleza sa fie postate tradus asta ca sa fie citite de toti. Eu de exemplu nu am rabdare si nici timp sa migalesc translator cum cred ca sunt si altii. CITAT 2: perfect adevarat ce spui, intarind asfel cele spuse si de mine. >>>>>>>>>>>>>>>>>>>>>>>>>>>> Eu nu am spus nimic, am reactionat doar la doleanta lui &simson pt ca eu "am rabdare si timp sa migalesc" (mi-a luat cam 1 min). Am permanent deschis "google translate", am selectat prima postare, COPY dincolo si apoi COPY aici. La fel ca si in topicul de unde s-a desprins acesta. Dl. Olimpiu a dat 2 adrese si pt ca "am timp" am intrat acolo si am dat COPY la ce parea pe subiect si am postat pe forum pt a ajuta pe cei ce muncesc si nu au timp. Nu am postat nicio parere/ idee a mea, am inceput sa ma feresc cat pot de supermenii care te pun mereu la punct, cum este si repetarea expresiei ca ceilalti dau cu "oistea-n gard". Link spre comentariu
merck Postat Septembrie 13, 2021 Autor Partajează Postat Septembrie 13, 2021 Acum 26 minute, icar a spus: Dar...problema ramine nerezolvata: schimba, sau nu, ecranul de fier, sau cupru, inductanta trafului? Pai depinde de cum este realizat ecranul. Daca avem un traf SE cu intrefier ca in poza de mai jos: si platbanda de pe tole face contact cu tolele (scurtcircuiteaza intrefierul) este normal ca inductanta sa difere. Nu mai spun de suruburile de strangere si de cuplul de strangere. Link spre comentariu
icar Postat Septembrie 13, 2021 Partajează Postat Septembrie 13, 2021 @dumitrumy, imi cer scuze daca s-a inteles altceva. Te-am citat cu "este adevarat ce spui", pentru cele scrise mai sus, fie ele si o traducere. Referitor la oistea in gard, iertat sa-mi fie, dar cam asa e. Chestiunea si intrebarea era daca un ecran de fier/cupru schimba semnificativ valoarea inductantei, iar raspunsurile/interventiile au stipulat ca cutare firma foloseste cutare tip de ecran sau cutare tip de ecran sau s-a aratat cum functioneaza un ecran. Par raspunsuri la obiect? Mie imi pare ca nu. Merck, da suruburile mai mult sau nai putin strinse, influienteaza inductanta, dar nu asta era problema, ci oala de ceai. Inca o data, se incumeta cineva sa faca niste masurari pe un traf de iesire oarecare, cu sau fara ecran? Link spre comentariu
merck Postat Septembrie 13, 2021 Autor Partajează Postat Septembrie 13, 2021 Acum 23 minute, icar a spus: Merck, da suruburile mai mult sau nai putin strinse, influienteaza inductanta, dar nu asta era problema, ci oala de ceai. Inca o data, se incumeta cineva sa faca niste masurari pe un traf de iesire oarecare, cu sau fara ecran? Oala de ceai nu este un ecran. Prima data trebuie testat daca ecranul performeaza ca ecran, ca daca atenuarea este de cateva procente mai bine continuam sa facem ceai in oala decat sa o folosim ca ecran. Link spre comentariu
Усилитель Postat Septembrie 13, 2021 Partajează Postat Septembrie 13, 2021 Dar chiar este nevoie de ecran , influenteaza asa de mult ? Vad ca de ex amplifurile lui Viobio merg bine,suna bine , nu are "chestii"in plus .Si alte o gramada sunt tot asa facute.Pana nu ajunge brum magnetic de la traf alimentare la trafuri iesire ,si dintr-unul de iesire semnal in celalalt lucrurile sunt ok ,parerea mea.Oricum si aici ajuta "distantarea " si unghiul dintre infasurarile trafurilor. Acum accept ca o firma de renume pune si ecrane atat estetic si cu rol de ecranare , trebuie sa justifice pretul cerut , sau sa dea un plus fata de concurenta ,sau sa lamureasca cumparatorul ca acesta trebuie cumparat ( nu cred sa fie chiar asa mare cerere de trafuri de iesire incat lumea sa cumpere orice , asa ca alege , si trebuie motivat ) .Daca stiu bine Lundahl mizeaza pe calitatea deosebita ,incat nu prea se complica inutil cu ecrane exterioare. Este doar un gand ,o parere , puteti arunca cu ecrane de transformator in mine.... Link spre comentariu
validae Postat Septembrie 13, 2021 Partajează Postat Septembrie 13, 2021 Ecranele se folosesc doar acolo unde e neapărată nevoie, dacă ai spaţiu suficient în carcasă ca să depărtezi traful suficient de amplificator nu e musai să ecranezi traful. Link spre comentariu
merck Postat Septembrie 13, 2021 Autor Partajează Postat Septembrie 13, 2021 Acum 54 minute, Усилитель a spus: Daca stiu bine Lundahl mizeaza pe calitatea deosebita ,incat nu prea se complica inutil cu ecrane exterioare. Ei se complica : insa pretul este pe masura: Unit price Euro, VAT excl. €60.47 Link spre comentariu
Усилитель Postat Septembrie 13, 2021 Partajează Postat Septembrie 13, 2021 Nu am zis ca deloc "nu prea ", stiu bine ca toti au pt bani seriosi modele "extra "cu ce vrea clientu pe banii lui. In rest vad ca pe siteuri chinezesti o oferta bogata de "capace"de aluminiu ,de toate formele ,culorile.( are si racire ) Link spre comentariu
Mircea Postat Septembrie 13, 2021 Partajează Postat Septembrie 13, 2021 Tipul asta voiam si eu sa-l sugerez. De cand cu explozia aluminiului extrudat, apoi se poate orice. Si arata mult mai bine decat organizatoarele de creioane la 3 lei bucata. Link spre comentariu
Усилитель Postat Septembrie 13, 2021 Partajează Postat Septembrie 13, 2021 Da , numai la acesta nu o sa zica lumea : ce idee...... Si nu toti comanda din china ..... orgsnizatoarele sunt din fer , ecraneaza mai bine.... Link spre comentariu
KISS Postat Septembrie 13, 2021 Partajează Postat Septembrie 13, 2021 (editat) Uite ce ''departate'' sunt...si ecranele sunt de fier. Editat Septembrie 13, 2021 de KISS Link spre comentariu
