soft alba model: lcd32880hdf
iod2
  • Răspunsuri 6
  • iod2
  • iuliantv
  • Costica Tv
Zile populare
stiu ca la mb25 sau mb35 ledul mai fleshuia si cand era dusa una din surse,3v2 5v....nu mai stiu care,era o arsa siguranta  smd prin mijlocul placii digitale,mai mult in partea de sus ,am chinuit unul odata cu binuri .......
de test puteti incerca si binurile de mai jos,daca nu au imagine corecta,macar va lamuriti daca ele sant cauza
ps,scl-sda-3v sant prezente pe memoriile spi eprrom?
uitati mai jos un fragment ,gasit pe un forum,unde se discuta despre verificarea sigurantelor smd
Check microfuse FS105 on main board, near CAM module.
Check SMD fuse FS106 (4A) for open-circuit. Check diodes D881 and D893 (UF5402) for short-circuit.
24V rail might be short-circuit, disconnect inverter board supply to prove. Check and replace dual N-channel MOSFETs IC803 and IC804.
Replace IC830 (FAN7711 and SMD capacitor C925 (1nF).
Check for short-circuit between pin 6 and pin 8 of IC830 (FAN7711). Replace IC830 and SMD capacitor C833 (100nF).
Check and replace SMD transistor Q839 (BC859).
Check D893 and D891 (UF5402) in centre of PSU for short-circuit.
Voltage at regulator U122 varies between 4V and 9V instead of being stable at 8V. Replace U122 (LM1117ADJ) on main board.
Check C961 (470uF/35V) at top of PSU.
Check D893 and R1036 (2.2K) on PSU.
Replace IC830 (FAN7711).
Check D893 and its feed resistor. Replace MOSFETs Q813 and Q814 and IC830. Replace C828.
Replace C892 (100uF), C801 (33uF), C840 (33uF).
Editat de iuliantv
