criss Postat Septembrie 2, 2010 Autor Partajează Postat Septembrie 2, 2010 la ce va trebuie schema?veriticati bobina, primarul bobinei va intereseaza(cea de masa si nu +), trageti un fir pana unde doriti sa puneti displayul si inca 3 fire pt masa, contact +12V si iluminarea displayului.faceti o poza cu bobina de inductie. Link spre comentariu
kinderu56 Postat Septembrie 4, 2010 Partajează Postat Septembrie 4, 2010 ma refeream la schema dela displei ce facer fiecare pin Link spre comentariu
criss Postat Septembrie 4, 2010 Autor Partajează Postat Septembrie 4, 2010 1 Permanent 12V Always on 12V, keeps the clock running.2 Not connected (Temperature) Temperature for TID3 Ground 0V Ground connected to the chassis4 Not connected (Temperature) Temperature for TID5 Accessories => 12V when the key is on accessories. The display goes on.6 Headlights => 12V when headlights are on.7 Dashboard illumination => Signal for the strength of the dashboard lights8 Car-radio on => The Radio is on. The date will disappear and make space for the RDS signal9 SCL Serial Clock10 MRQ Master Request or something...11 SDA Serial data from the radio12 Not connected (Speed) Speed signal for displays with temperature readout. (TID)2,4,12 sunt disponibile doar la TID (triple info display) la did(dual info display) nu Link spre comentariu
kinderu56 Postat Septembrie 9, 2010 Partajează Postat Septembrie 9, 2010 ---------------mersi Link spre comentariu
