schema cu KT88
ioannis
salut!!! am 4 lampi KT88 si vreau sa construiesc un amplificator. am cautat multe scheme si asta care va prezint mi se pare mai fain. inainte sa ma apuc de construit imi trebuie pareriile voastre si mai ales experienta voastra la lampi care eu nu prea am!!! :(
  • Răspunsuri 10
  • ioannis
    5
  • sere
  • MiniTehnicus
  • yo3ihg
am gasit aceas schema dar la prima lampa ECC81 este adaugata o rez. de 100k in serie de 68k la anodul ei. care este corect?si inca ceva: am cautat sursa de alimentare p.t amplif asta dar n-am gasit. daca cineva poate sa ma ajute o sa ramin dator..... :)
Ca sa-ti faci o idee despre sursa de alimentare:
http://turneraudio.com.au/100w-monobloc-2004.html
Ai nevoie de un trafo retea cu 3 secundare, unul pentru tensiunea de filament de 6,3v si 8A, unul pentru tensiunea anodica de 320-350V
la 1A si unul pentru tensiunea de bias de 50 sau 60v la 0.3A.
Iar KT88 nu este identica cu 6550.
Datasheetul se gaseste aici:
http://www.mclink.it/com/audiomatica/tubes/kt88.htm
http://www.mclink.it/com/audiomatica/tubes/6550.htm
Between USA and Europe, the competition was not in both trying to make the best tube of one type.
The competition was, each tries to make a different tube that the other side of the ocean didn't have.
Like this each side thought to be more clever.
In Europe, the EL34 was "the" big pentode, which was the result of a long evaluation, starting with the AL1, a radio speaker-output tube for class A.
After that AL4 was developed. Then with 6.3Volts EL3 came, and with the coming of the octal sockets, EL34 was born.
In the USA it was the more sloppy 6L6 that won the race.
The EL34 is a real penthode, and the 6L6 was the El Cheapo.
In the UK there was the KT66 invented, which was a better quality 6L6.
After this, in the USA from the 6L6 the larger 6550 was derived and in Europe from the KT66 the larger KT88 was derived .
Saying that KT66 and 6L6 are almost the same, that leaves us with four very popular power penthodes.
Any other differences are just playing with numbers and pin-connections. The end of the evaluation is the KT88 and the crown is the EL156.
The EL156 never had a break through because of the socket being not American.
6L6
Low cost, reliable tube. Break through of the beam tetrode.
KT66
Better construction 6L6, made in UK
7581A
Better construction 6L6, made in USA
5881
EL34
Real penthode. Can do higher voltage. Works very nice in Class A also.
GU-50
Russian military tube. Fits somewhere in the 6L6 family. Superb quality, and rugged a tank.
6550
larger 6L6
KT88
Upgrade of 6L6, designed by TUNG-SOL. Real Penthode. Can be seen as a big EL34.
KT90
Original idea by EI - Yugoslavia. Modification of EL519 to work like KT88.
EL156
Something like KT88, but no octal socket.
PS. Ai grija cu tipurile astea de tuburi, sunt multe falsuri de vanzare pe piata.
Pt un SE cu KT88 uite o schema buna http://www.jogis-roehrenbude.de/Leserbriefe/Michael-Dieckmann-KT88-Amp/KT88.htm
Pt PP am atasat o schema de la triode dick si inca un manual de ansamblare de la un kit produs de velleman (k4040)
http://rapidshare.com/files/66012080/illustrated_assembly_manual_k4040_rev1.pdf
http://rapidshare.com/files/66011672/bill.zip
_______________________________
rezolvat problema cu conturile :).. nu stiiam .. cred ca nu am deranjat pe nimeni.
Schema in care apare rezistenta de 100k este cea corecta. Fara aceea rezistenta tubul ECC81 se alimenteaza la tensiune prea mare, periculos de mare.
multumesc pentru raspunsurile!! :)vlad_dude foarte interesanta schema care ai postat, dar imi trebuie 2xKT88 pe canal. urmatorul amplif care o sa fac o sa incerc schema ta!!! :)sere am incercat sa descarc ( bill zip ) dar nu am reusit!! :(
  • 1 lună mai târziu...
va salut din nou! o sa incerc sa fac un amplif in SE acuma cu KT88 si dupa unu in PP. acuma sint intre doua scheme care au propus vlad_dude si sere. daca fac asta care zice sere pot sa elimin tubul EM80 si piesele in jurul lui? ca tubul EM80 nu se gaseste aici in grecia! care este parerea voastra? fac atitea intrebari si cer ajutorul vostru ca nu am la dispozitia mea aparate de masurat si oschiloscop dar numa un multimetru si multa rebdare!!! :)
Poti sa scoti din schema tubul respectiv pt ca este folosit doar pe post de indicator. Nu influenteaza semnalul audio. Poti inlocui insa tubul respectiv cu 2xem84 si o sa ai cate un indicator pe fiecare canal ( cred ca o sa arate si mai interesant ). Daca nu vrei sa modifici schema trage un ochi si pe ebay .. aici
