Eroare la compilare
Alex vw
Buna dimineata.Lucrez la o a 2 a automatizare pentru masina si la compilare am cateva erori care ma dau peste cap .Imi puteti explica unde s-a gresit ?
 *  HVAC car control with Arduino
 *  Version 1.0
 *  Copyright (C) 2018  Hartmut Wendt  www.hwhardsoft.de
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see <http://www.gnu.org/licenses/>.
 *  #include <OneWire.h>
 *#include <DallasTemperature.h>
// Portkonfiguration
#define REL_VENT_FRONT 5      //relay output for ventilation front
#define REL_VENT_FOOT 6       //relay output for ventilation footwell area
#define REL_VENT_WINDOW 7     //relay output for ventilation window
#define REL_FAN_PWR 8             //relay output for fan power
#define PWM_FAN_PIN 9             //PWM output for fan power
#define REL_COMPRESSOR 11         //relay output for AC compressorr
#define REL_HEATING 12            //relay output for heating valve
#define REL_AIR_CIRCULATION 13    //relay output for air circulation
#define REL_FOG_LIGHT 14          //relay output for fog light
#define REL_HEATING_WINDOW_FRONT 15   //relay output for window heating front
#define REL_HEATING_WINDOW_REAR 16    //relay output for window heating rear
#define TEST_PIN 19               // output for sw tests
#define DS18S20
// OneWire DS18S20, DS18B20, DS1822 Temperature sensor
DS18S20  sens_out(2);       // outside temperature sensor on D2
DS18S20  sens_in_right(3);  // inside right side temperature sensor on D3
DS18S20  sens_in_left(4);   // inside left side temperature sensor on D4
int temp_out = 20;             // measured outside temperature
int temp_in_right = 20;        // measured inside right side temperature
int temp_in_left = 20;         // measured inside left side temperature
int set_in_right = 20;        // setted inside right side temperature
int set_in_left = 20;         // setted inside left side temperature
// Variables
int i1;
char *test;
String s1;
String inputString;
boolean AC_ENABLED = false;
int bscheduler = 0;
/** Wird beim Start einmal ausgeführt */
void setup()
    // set port direction
    pinMode(REL_VENT_FRONT, OUTPUT);
    pinMode(REL_VENT_FOOT, OUTPUT);
    pinMode(REL_VENT_WINDOW, OUTPUT);
    pinMode(REL_FAN_PWR, OUTPUT);
    pinMode(REL_COMPRESSOR, OUTPUT);
    pinMode(REL_HEATING, OUTPUT);
    pinMode(REL_AIR_CIRCULATION, OUTPUT);
    pinMode(REL_FOG_LIGHT, OUTPUT);
    pinMode(REL_HEATING_WINDOW_FRONT, OUTPUT);
    pinMode(REL_HEATING_WINDOW_REAR, OUTPUT);
    pinMode(TEST_PIN, OUTPUT);
    // init serial port for nextion communication.
    Serial.begin(9600);
    delay(250);
    // first read in of temperatures
    temp_out = read_temperature(sens_out);
    delay(100);
    temp_in_right = read_temperature(sens_in_right);
    delay(100);
    temp_in_left = read_temperature(sens_in_left);
    //pwm init
    Timer1.initialize(1000);  // 1.000 us = 1 kHz
    Timer1.pwm (PWM_FAN_PIN, 0);
// ----- Main loop -----------------------------------------------------------------------------------
void loop()
    // processing of incomming messages from nextion
    Nextion_processing();
    switch(bscheduler)
      // measure outside temperature
      case 0:
          // transmit outside temperature to nextion display
          Serial.print("ID1.val=");
          Serial.print(temp_out);
          Serial.write(0xff);
          Serial.write(0xff);
          Serial.write(0xff);
          break;
      // measure inside right temperature
      case 25:
          break;
      // measure inside left temperature
      case 50:
          break;
      // HVAC control
      case 75:
        clima_control();
        break;
    bscheduler++;
    if (bscheduler > 100) bscheduler = 0;
    delay(10);
// read temperature from a connected 1wire temperature sensor
int read_temperature(OneWire ds) {
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
  if ( !ds.search(addr))
    ds.reset_search();
    delay(250);
    return(97);
  if (OneWire::crc8(addr, 7) != addr[7])
      return(98);
  // the first ROM byte indicates which chip
  switch (addr[0])
    case 0x10:
      type_s = 1;
      break;
    case 0x28:
      type_s = 0;
      break;
    case 0x22:
      type_s = 0;
      break;
    default:
      return(99);
  ds.reset();
  ds.select(addr);
  ds.write(0x44, 1);        // start conversion, with parasite power on at the end
  delay(750);
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Read Scratchpad
  for ( i = 0; i < 9; i++)
    data[i] = ds.read();
  // Convert the data to actual temperature
  int16_t raw = (data[1] << 8) | data[0];
  if (type_s) {
    raw = raw << 3; // 9 bit resolution default
    if (data[7] == 0x10)
      digitalWrite(TEST_PIN, HIGH);
      raw = (raw & 0xFFF0) + 12 - data[6];
  else
    byte cfg = (data[4] & 0x60);
    if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
    else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
    else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
  return((int)raw / 16.0);
unsigned long StrToHex(String str, byte digits)
  char ConvByte[10];
  str.toCharArray(ConvByte, digits);
  return (unsigned long) strtol(ConvByte, NULL, 16);
// ------ receiving and processing of incomming data from nextion
void Nextion_processing()
  int i1;
  String s1;
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    inputString += inChar;
    if (inChar != '|') return;
  int i2=inputString.indexOf("=");
  if (i2 > 0) {
    #ifdef _debug_snd
    Serial.print("Nextion: ");
    Serial.print(inputString);
    Serial.println("    -   ");
    Serial.print(inputString.substring(i2-2,i2));
    Serial.print("=");
    Serial.println(inputString[i2+1]);
    #endif
    //- id2 FOG LIGHT -
    if (inputString.indexOf("id02=1")> -1) {
      // FOG LIGHT on
      digitalWrite(REL_FOG_LIGHT, HIGH);
    else if(inputString.indexOf("id02=0")> -1) {
      // FOG LIGHT off
      digitalWrite(REL_FOG_LIGHT, LOW);
    //- id5 ventilation footwell + window -
    if (inputString.indexOf("id05=1")> -1) {
      // set ventilation to foot well & window
      digitalWrite(REL_VENT_FRONT, LOW);
      digitalWrite(REL_VENT_FOOT, HIGH);
      digitalWrite(REL_VENT_WINDOW, HIGH);
    else if(inputString.indexOf("id05=0")> -1) {
      // switch all ventilation off
      digitalWrite(REL_VENT_FOOT, LOW);
      digitalWrite(REL_VENT_WINDOW, LOW);
    //- id9 ventilation footwell -
    if (inputString.indexOf("id09=1")> -1) {
    else if(inputString.indexOf("id09=0")> -1) {
    //- id14 ventilation front -
    if (inputString.indexOf("id14=1")> -1) {
      // set ventilation to front
      digitalWrite(REL_VENT_FRONT, HIGH);
    else if(inputString.indexOf("id14=0")> -1) {
    //- id22 ventilation front + footwell -
    if (inputString.indexOf("id22=1")> -1) {
      // set ventilation to front + foot well
    else if(inputString.indexOf("id22=0")> -1) {
    //- id4 electrical window heating rear -
    if (inputString.indexOf("id04=1")> -1) {
      // window heating on
      digitalWrite(REL_HEATING_WINDOW_REAR, HIGH);
    else if(inputString.indexOf("id04=0")> -1) {
      // window heating off
      digitalWrite(REL_HEATING_WINDOW_REAR, LOW);
    //- id6 electrical window heating front -
    if (inputString.indexOf("id06=1")> -1) {
      digitalWrite(REL_HEATING_WINDOW_FRONT, HIGH);
    else if(inputString.indexOf("id06=0")> -1) {
      digitalWrite(REL_HEATING_WINDOW_FRONT, LOW);
    //- id7 air circulation -
    if (inputString.indexOf("id07=1")> -1) {
      // air circulation on
      digitalWrite(REL_AIR_CIRCULATION, HIGH);
    else if(inputString.indexOf("id07=0")> -1) {
      //air circulation off
      digitalWrite(REL_AIR_CIRCULATION, LOW);
    //- id10 Air Condition enabled/disabled -
    if (inputString.indexOf("id10=1")> -1) {
      // AC enabled
      AC_ENABLED = true;
    else if(inputString.indexOf("id10=0")> -1) {
      // AC disabled
      AC_ENABLED = false;
    //- id18 HVAC on/off -
    if (inputString.indexOf("id18=1")> -1) {
      // HVAC on
    else if(inputString.indexOf("id18=0")> -1) {
      // HVAC off
      AC_ENABLED = false;
      // FAN off
      digitalWrite(REL_FAN_PWR, LOW);
    //- id13 FAN control -
    if (inputString.indexOf("id13=0")> -1) {
      // FAN off
    else if(inputString.indexOf("id13=1")> -1) {
      // FAN level 1
      digitalWrite(REL_FAN_PWR, HIGH);
      Timer1.pwm (PWM_FAN_PIN, 146);
    else if(inputString.indexOf("id13=2")> -1) {
      // FAN level 2
      Timer1.pwm (PWM_FAN_PIN, 293);
    else if(inputString.indexOf("id13=3")> -1) {
      // FAN level 3
      Timer1.pwm (PWM_FAN_PIN, 439);
    else if(inputString.indexOf("id13=4")> -1) {
      // FAN level 4
      Timer1.pwm (PWM_FAN_PIN, 585);
    else if(inputString.indexOf("id13=5")> -1) {
      // FAN level 5
      Timer1.pwm (PWM_FAN_PIN, 731);
    else if(inputString.indexOf("id13=6")> -1) {
      // FAN level 6
      Timer1.pwm (PWM_FAN_PIN, 877);
    else if(inputString.indexOf("id13=7")> -1) {
      // FAN level Max
      Timer1.pwm (PWM_FAN_PIN, 1023);
    //-- setted temperature right --
    i1 = inputString.indexOf("id20=");
    if (i1 > -1)
      set_in_right = inputString.charAt(i1 + 5) - 48;
    //-- setted temperature left --
    i1 = inputString.indexOf("id16=");
    if (i1 > -1)
      set_in_left = inputString.charAt(i1 + 5) - 48;
  while(Serial.available()) {Serial.read();}
  inputString = "";
// HVAC control
void clima_control() {
    // cooling or heating requiredn?
    if (temp_out < set_in_left) {
      // heating
      digitalWrite(REL_COMPRESSOR, LOW);
      digitalWrite(REL_HEATING, HIGH);
    } else if ((temp_out > (set_in_left + 1)) && (temp_out > 15) && (AC_ENABLED == true)) {
      // cooling
      digitalWrite(REL_COMPRESSOR, HIGH);
      digitalWrite(REL_HEATING, LOW);
    } else {
      // temperature ok - no further action required
  • Răspunsuri 3
Zile populare
Sa le luam in ordine.
In primul rand te rog sa folosesti butonul "<>"din editor pentru a introduce codul in textul mesajului.
In al doilea rand, eroarea provine din modul in care (nu) ai declarat ONE_WIRE_BUS si modul in care ai trecut declaratia OneWire catre senzorul Dallas.
Exemplu:
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
In codul postat de tine nu prea apare asa ceva.
Studiaza cu atentie exemplele de aici: https://github.com/milesburton/Arduino-Temperature-Control-Library/tree/master/examples si incepe treptat cu sketch-urile, de la cel mai simplu la cel mai complicat, pe masura ce intelegi ce si cum.
[code]
 *  Version 1.0
#include <TimerOne.h>
OneWire  sens_out(2);       // outside temperature sensor on D2
OneWire  sens_in_right(3);  // inside right side temperature sensor on D3
OneWire  sens_in_left(4);   // inside left side temperature sensor on D4
// Variables
int i1;
char *test;
String s1;
String inputString;
int bscheduler = 0;
void setup()
    Serial.begin(9600);
    delay(250);
    delay(100);
    delay(100);
    //pwm init
void loop()
    switch(bscheduler)
      case 0:
          Serial.write(0xff);
          Serial.write(0xff);
          Serial.write(0xff);
          break;
      case 25:
          break;
      case 50:
          break;
      // HVAC control
      case 75:
        clima_control();
        break;
    bscheduler++;
    delay(10);
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
    ds.reset_search();
    delay(250);
    return(97);
      return(98);
  switch (addr[0])
    case 0x10:
      type_s = 1;
      break;
    case 0x28:
      type_s = 0;
      break;
    case 0x22:
      type_s = 0;
      break;
    default:
      return(99);
  ds.reset();
  ds.select(addr);
  delay(750);
  ds.select(addr);
  if (type_s) {
  else
  char ConvByte[10];
  int i1;
  String s1;
  if (i2 > 0) {
    #ifdef _debug_snd
    Serial.print("=");
    #endif
    //- id2 FOG LIGHT -
      // FOG LIGHT on
      // FOG LIGHT off
      // AC enabled
      AC_ENABLED = true;
      // AC disabled
      AC_ENABLED = false;
      // HVAC on
      // HVAC off
      AC_ENABLED = false;
      // FAN off
      // FAN off
      // FAN level 1
      // FAN level 2
      // FAN level 3
      // FAN level 4
      // FAN level 5
      // FAN level 6
      // FAN level Max
    if (i1 > -1)
    if (i1 > -1)
  inputString = "";
// HVAC control
      // heating
      // cooling
    } else {
[/code]
Rezolvat .. Ms frumos.
@Alex vw
Eu nu prea am inteles care a fost rostul postărilor tale atat de lungi.
Este un copy/paste a unui program de pe net care functionează.
In prima postare ai modificat ceva (complet aiurea) ca să ai motiv de o intrebare.
Apoi ai revenit cu codul original care evident că merge.
