Componente, transformatoare, surse, statii de lipit, etc.
Everest
Nu trimit colete cu ramburs, plata se face in avans in cont.
Taxele postale le suporta cumparatorul.
Multumesc de intelegere.
1.  Condensatori 4700uf-35v 85gr ... 1,3 lei/buc ... 20 lei/20buc.
                             NaAJlo3.jpg?1
                     2.  Condensatori 4700uf-35v 105gr ... 1,5 lei/buc ... 25 lei/20buc.
                            ty0MGJC.jpg?2
3.  Conector B2P-VH ... 10 lei/20 buc.
                            4NbvHHZ.jpg?1
4.  Diode 600v/6A ...  15 lei/50 buc. ... 30 lei toate 114 buc.
                            jzutucQ.jpg?1
5.  LM317T ... 8 lei/10 buc. ... 20 lei/30 buc.
                           5ZSysOC.jpg?1
6.  LM317T cu radiator ... 13 lei/10 buc. - stoc 50 buc.
                          aSobkus.jpg?1
7.  BDW42 cu radiator  ... 15 lei toate 6 buc.
                          kTbCWtg.jpg?1
8.  DK4 Micro Switch ... 2 lei/buc. ... 15 lei/10 buc.
                         https://imgur.com/a/9XrTBaw
                         alcbPQE.jpg?1
9.  Micro Switch PCB (cu loc pentru LED) ... 2 lei/buc. ... 15 lei/10 buc.
                          https://imgur.com/a/87TJ6Ic
                          sraUb1H.jpg?1
10.  N-FET sursa 6-8-12A/600V ... 2,5 lei/buc. ... 20 lei/10 buc. - stoc 50 buc.
                          https://imgur.com/a/7p75rEU
                          H2uvYLc.jpg?1
11.  Radiatoare TO-220 ... 1,5 lei/buc. - stoc 50 buc.
                         https://imgur.com/a/jcEBMat
                         cTnSd8C.jpg?1
12.  Senzor reed SMT ... 2 lei/buc. ... 15 lei/10 buc.
                        https://imgur.com/a/hLHuBXB
                        F5y0iuH.jpg?1
13.  Traf toroidal ... 25 lei/buc.(1,5kg) ... 40 lei impreuna.
                        https://imgur.com/a/ebvzUi7
                        2giEdaU.jpg?1
14.  Traf 21v - 50VA ... 15 lei/buc. (0,8kg)(sec.0,9mm) - stoc 5 buc.
                       https://imgur.com/a/ptIiVWw
                       2KMPNQ5.jpg?1
15.  Traf 21v - 100VA ... 25 lei/buc. (1,4kg)(sec.1,3mm) - stoc 5 buc.
                       https://imgur.com/a/wZ98cU0
                       1lAjgSV.jpg?1
16.  Traf 21-30v - 120VA ... 30 lei/buc. (1,5kg)(sec.1,2mm) - stoc 4 buc.
                       https://imgur.com/a/ZVsDhLQ
                       pgHOVJL.jpg?1
17.  Traf 21-30v - 160VA ... 40 lei/buc. (2,4kg)(sec.1,3mm) - stoc 2 buc.
                      https://imgur.com/a/5ZtcgL7
                      zc5CMay.jpg?1
18.  Traf separator retea ... 100 lei/buc. (10,5kg) - stoc 2 buc.
                     https://imgur.com/a/vTLOg2V
                     7HmeXq2.jpg?1
19.  Sursa EA 24v-10.5A ... 100 lei/buc. - stoc 3 buc.
                     https://imgur.com/a/87EtevG
                     8MuSmiQ.jpg?1
20.  Sursa liniara DF-3010-A  0-30v/0-10A ... 200 lei/buc. (11,5kg) - stoc 2 buc.
                     https://imgur.com/a/3OFIKYw
                     0ijxt4l.jpg?1
21.  Sursa AX-3010DS  0-30v/0-10A  ... 250 lei/buc. - stoc 2 buc.
                     https://imgur.com/a/Hav4iFx
                     lPWxXAZ.jpg?1
22.  Sursa SIEMENS 24v-10A ... 70 lei/buc.
                    https://imgur.com/a/OMsN8LY
                   MNK5YUI.jpg?1
23.  Sursa VOLTCRAFT VSP 1410   0-40v/0-10A  &  0-6v/1,5A  ... 450 lei.
                  https://imgur.com/a/9t1y9GG
                  m3crHch.jpg?1
24.  Statie de lipit digitala ... 150 lei.
                https://imgur.com/a/BVYqVbE
                eS5qYCc.jpg?1
25.  Statie de lipit Weller WS80 ... 150 lei.
               https://imgur.com/a/SOztwYK
              KHWKiYV.jpg?1
26.  Statie de lipit RX-802AS ... 450 lei. (maner,varf si burete noi)
             https://imgur.com/a/jac5qt2
             t39mQ9h.jpg?1
27.  Statie de lipit HAKKO FX-951 ... 220 lei. (fara letcon)
                      letconul e functional si din cauza uzurii se ofera bonus
           https://imgur.com/a/klWEUcP
             1qhBoc5.jpg?1
28.  Statie de lipit HAKKO FX-951 ... 250 lei. (fara letcon)
        https://imgur.com/a/4HiuABg
             PfvCYvF.jpg?1
29.  Pompa cositor PK-366N ... 20 lei/buc.
        https://imgur.com/a/2lb4mTf
           qlCyyUE.jpg?1
30.  Moeller EASY 621 & 620 ... 200 lei.
       https://imgur.com/a/BeemhTF
          3X6V0s8.jpg?1
31.  C-CONTROL II STATION ... 100 lei.
       https://imgur.com/a/PogtoSG
          6OVPBJ5.jpg?1
32.  STEGO HG 140 ... 50 lei.  .... Aparat de încălzire; semiconductor; HG 140; 100W; 120÷240V; IP20  STEGO HG 140
       https://imgur.com/a/ocFy2eq
          9pm8zO5.jpg?1
33.  Releu RPM42BD cu soclu ... 50 lei/buc.(releu + soclu) ... 80 lei impreuna.
       https://imgur.com/a/LvXxGDY
          aPmLX7j.jpg?1
34.  Releu 5v-1A ... 5 lei/buc.
       https://imgur.com/a/jh576R5
          1IRT47q.jpg?1
35.  Releu 9v ... 1,5 lei/buc. ... peste 10 buc. 1 leu/buc.
       https://imgur.com/a/Fw69RNl
         BhyCySQ.jpg?1
36.  Releu 18v ... 1,5 lei/buc. ... peste 10 buc. 1 leu/buc.
       https://imgur.com/a/PU6GNfH
         qVzruZg.jpg?1
37.  Releu 24v ... 1,5 lei/buc. ... peste 10 buc. 1 leu/buc.
       https://imgur.com/a/UJjWB82
         y3lYitc.jpg?1
38.  Releu 103T-1CH-C-12VDC (releu dublu) ... 5 lei/buc.
        https://imgur.com/a/IeRpyGB
          EbfqnVw.jpg?1
39.  Telecomenzi RF 433.92 MHz ...  5lei/buc. ... 40 lei/10 buc. ... 60 lei/20 buc.
          https://imgur.com/a/DgziyND
           Bg7pUPv.jpg?1
40.  Calculator ADLER 81 ... 50 lei.
           https://imgur.com/a/1jRL4dy
           vSjvBsF.jpg?1
41.  Traf toroidal 2x12V/2x6.66A 160VA ... 60 lei.
           https://imgur.com/a/MDayH7C
           3W2RtKb.jpg?2
42.  Placa sursa + radiator tunel ... 50 lei.
           https://imgur.com/a/e1c2pcz
           3mKkjHA.jpg?1
43.  Cleme WAGO-280 ... 0,5 lei/buc ... 30 lei/60 buc. pe sina. - stoc 600 buc.
           https://imgur.com/a/d6Bkr9n
           cWWU63L.jpg?1
44.  Fludor ... 60 lei/rola 500g ... 100 lei/rola 1kg.
           iC6maw5.jpg?1
45. Cartuse inkjet HP ... 15 lei/buc. ... 50 lei toate.
          https://imgur.com/a/y076NII
           i8pHrDS.jpg?2
46.  Manometru WIKA ... 50 lei/buc. ... 80 lei impreuna.
            https://imgur.com/a/Z6hBxuL
           FMSG3Ju.jpg?1
47.  Manometru WIKA cu glicerina ... 70 lei/buc. ... 110 lei impreuna.
          https://imgur.com/a/6NGwtq1
         E6xqDJU.jpg?1
  • Răspunsuri 101
  • Everest
    26
  • Zoltanh
    10
  • dan cod
    7
  • woodyteo
    5
Buna seara,
Doresc una bucata 18.  Traf separator retea ... 100 lei/buc. (10,5kg)
Va rog sa-mi transmiteti contul si suma, inclusiv transport, pe care s-o transfer. Va trimit adresa prin mesaj.
Buna seara ; ma intereseaza :
6.  LM317T cu radiator ... 13 lei/10 buc. - 10 buc.
11.  Radiatoare TO-220 ... 1,5 lei/buc. - 10 buc
Doresc sa cumpar:
  5.  LM317T ... 20 lei/30 buc.
14.  Traf 21v - 50VA ... 15 lei/buc. (0,8kg)(sec.0,9mm) - stoc 5 buc. - toate cele 5 buc.
V-am trimis mp.
 2.  Condensatori 4700uf-35v 105gr ... 1,5 lei/buc ... 25 lei/20buc. - 20 buc.
 4.  Diode 600v/6A ...  15 lei/50 buc. ... 30 lei toate 114 buc. - 50 buc.
 11.  Radiatoare TO-220 ... 1,5 lei/buc. - 24 buc.
 15.  Traf 21v - 100VA ... 25 lei/buc. (1,4kg)(sec.1,3mm) - 4 buc.
 34.  Releu 5v-1A ... 5 lei/buc.  - 10 buc.
Astea le-as vrea eu.
Eu vreau asa:
2.4700uF 20 bucati
4.Diode 50 bucati
15. Traf 1 bucata
20. Sursa cea de jos care are etichetele ambele
37. Releu 24 20 bucati
Eu as dori :
4. Diode 15 lei /50 buc.
5. LM 317 20n lei/30 buc.
7. Lm 317 cu rad. 13 lei/ 10 buc
16-17 Traf 21-30 v (120 - 160 W) - 2 bucati poate 1+1 !
11 Radiatoare TO 220 daca mai sunt ! 20 buc.
Astept sa vad ce mai ramane pana la mine si discutam pe MP !
Buna seara! Mă interesează pozitia 13, ambele bucăți, și o bucată de la poziția 18, traf separator. Mulțumesc! Mai departe discutăm pe MP! O seara bună!
Acum 57 minute, elektronu85 a spus:
...si eu as mai fi vrut...ambele pozitii.
Si din astea as fi vrut...nu atat pentru tranzistoare, ci pentru radiatoare de formatul asta....daca mai exista, as vrea vreo 20 de bucati minim....
Editat de carageae
