Which led lights are the best?
LutherAnderson
Hi everybody,
I am using a Hyundai Santafe. My car has been used for a long time, so the car lights are weak, so I want to replace it with led bulbs. That's why I want people to point out which are the best led lights on the market?
Thank you very much.
  • Răspunsuri 6
  • yo9hrb
  • sesebe
  • validae
  • LutherAnderson
This question can best be answered by someone who has replaced halogen bulbs with LEDs. The offer of such LED bulbs is quite large, I would say that for better reliability you should choose a model that has a forced cooling. Excessive heat destroys the LEDs.
Also you need to check if this modification of the lighting system is OK related to the law. I think it is not OK. Some modification need a new certification / homologation of the vehicle. And is not cheap.
I think that the best solution is the replacement of the headlights. Or polishing.
Not in US. In the US you can make a lot of changes without certifications.
  • 2 ani mai târziu...
La 25.05.2021 la 15:52, merck a spus:
When it comes to the best LED lights, you've got some top-notch options to choose from. Brands like Philips, Sylvania, and JDM Astar are known for their quality and performance in automotive lighting.
Before you make a decision, just double-check that the LED bulbs you're eyeing are compatible with your Santa Fe. Also, think about factors like brightness, color temperature, and how long they'll last to find the perfect match for your needs.
look into those brands and make sure to check the compatibility before making a decision. Excited to give my Santa Fe a fresh new look with those LED lights.
Editat de Declan Smith
mister Declan Smith ...your  answer  is  delayed  with  only  3  years ...pay  attention , please  at  the  time  of  the  original  posting ...
