Spitfire Postat Mai 8, 2021 Partajează Postat Mai 8, 2021 -tub CCFL nou+ inverter(12V) -10 lei -dispozitiv de desfacut capace ceasuri, solid (alama si otel) -20 lei -bomfaier Made in Germany, complet metalic, foarte ergonomic-30 lei -lot suruburi foarte mici (ceasuri, etc) -8 lei -condensator cuptor microunde 0,92uF/2100VAC, verificat -10 lei -lot 3 relee Reed -9 lei -CPU socket AM2 AMD Sempron SDD3000IAA3CN TDP35W -10 lei -CPU socket AM2 AMD LE-1150 45W 2GHz/256KB L2 -10 lei - 42 circuite integrate CMOS seria 4000, noi(CD4001-2buc.,CD4011-4 buc, CD4069, CD4511-5 buc.,CD4518-2buc, HCF40106-2buc., HCF4013-2buc., HEF4015-2buc., CD4017-3 buc, CD4020-2buc., CD4024, HC14174BCP, CD4052, CD4040-2buc., CD4047 -2buc., CD4049-3 buc., CD4060BE-3buc., CD4093BE-4buc.) -1 leu/bucata -13 integrate OP-AMP, unele noi, altele recuperate: LM13600N(N), JRC2903D(R), KA4558 (2buc)(R), 6562(R), LM393N, LM358N(2buc.)(N), LM358P(2buc)-(N), LM358DP(R), TL062CP(R), TL082CN(N). -1 leu/bucata. - IC multimetru digital ICL7106CPL -10 lei --radiator aluminiu anodizat 160x50x35 -20 lei -adaptor DVI-I la VGA -5 lei -placa cu 3 porturi USB 2.0 pe slot PCI-10 lei -ventilator 120mm 18V -8 lei -ventilator 230V~ 20W, calitativ, 140mm diametru elice -10 lei -Tuner FM-AM Pioneer F-225 -perfecta stare de functionare, sensibil -100 lei Link spre comentariu
Spitfire Postat Mai 10, 2021 Autor Partajează Postat Mai 10, 2021 sus............................ Link spre comentariu
Spitfire Postat Mai 12, 2021 Autor Partajează Postat Mai 12, 2021 sus.............................. Link spre comentariu
Spitfire Postat Mai 13, 2021 Autor Partajează Postat Mai 13, 2021 sus................................ Link spre comentariu
Spitfire Postat Mai 14, 2021 Autor Partajează Postat Mai 14, 2021 sus............................. Link spre comentariu
Spitfire Postat Mai 17, 2021 Autor Partajează Postat Mai 17, 2021 sus.............................. Link spre comentariu
Spitfire Postat Mai 18, 2021 Autor Partajează Postat Mai 18, 2021 sus........................... Link spre comentariu
Spitfire Postat Mai 20, 2021 Autor Partajează Postat Mai 20, 2021 sus............................ Link spre comentariu
Spitfire Postat Mai 26, 2021 Autor Partajează Postat Mai 26, 2021 sus................................... Link spre comentariu
Spitfire Postat Mai 28, 2021 Autor Partajează Postat Mai 28, 2021 sus............................ Link spre comentariu
Spitfire Postat Mai 29, 2021 Autor Partajează Postat Mai 29, 2021 (editat) Se adauga: -potentiometre logaritmice noi, nefolosite, 10 Kohm Noble Made in USA -5lei/buc -microintrerupatoare Matsushita Made in Japan 16A/250V~ -3 lei/buc -breadboard Nickel Wishboard 720 puncte, 180x170mm- 30 lei -fire breadboard cca. 80 buc -8 lei Editat Mai 29, 2021 de Spitfire Link spre comentariu
xaxa Postat Mai 30, 2021 Partajează Postat Mai 30, 2021 ma intereseaza fire breadboard cca. 80 buc -8 lei Link spre comentariu
Spitfire Postat Mai 31, 2021 Autor Partajează Postat Mai 31, 2021 Bomfaierul rezervat, restul disponibile. Link spre comentariu
Spitfire Postat Iunie 2, 2021 Autor Partajează Postat Iunie 2, 2021 sus................................... Link spre comentariu
