Cozonac Postat Aprilie 22, 2021 Partajează Postat Aprilie 22, 2021 (editat) Sonda pasiva Tektronix 500MHz, TPP0500B, noua, nefolosita - 2000 lei Compatibila cu osciloscoapele din seria MDO3000, MDO4000, si MSO/DPO5000. Caracteristici principale / Specificatii 500 MHz probe bandwidth models 10X and 2X attenuation factor 300 V CAT II input voltage Designed for use with the MDO3000, MDO4000, and MSO/DPO5000 series oscilloscopes Compact probe head for probing small-geometry circuit elements Small probe body for enhanced visibility to the device-under-test Rigid tip for secure device-under-test connectivity Replaceable probe tip cartridges Large accessory set for versatile connectivity Integrated oscilloscope and probe measurement system provides intelligent communication that automatically scales and adjusts units on the oscilloscope display to match the probe attenuation Built-in AC compensation optimizes signal path across the entire frequency range Applications Low-power devices Service Manufacturing engineering test Research and development Fisa tehnica: https://www.romtek.ro/uploads/products/files/TPP1000 TPP0500B TPP0502 TPP0250.pdf Mai multe poze: https://imgur.com/a/3uDdowz Editat Aprilie 22, 2021 de Cozonac Link spre comentariu
Cozonac Postat Aprilie 26, 2021 Autor Partajează Postat Aprilie 26, 2021 (editat) Pretul scade la 1500 lei. Sonda este noua si nefolosita, pretul acesteia este de 3200 lei in magazin. Accept si schimburi cu unele AMC-uri. Editat Aprilie 26, 2021 de Cozonac Link spre comentariu
Cozonac Postat Iunie 6, 2021 Autor Partajează Postat Iunie 6, 2021 schimb cu diverse Link spre comentariu
Cozonac Postat Iunie 15, 2021 Autor Partajează Postat Iunie 15, 2021 up. schimb cu diverse Link spre comentariu
Cozonac Postat Iunie 17, 2021 Autor Partajează Postat Iunie 17, 2021 Up. Sonda costa peste 3000 lei in magazin, puteti cauta. Este noua, iar mie nu-mi foloseste. Pret: 1000 lei sau schimb cu echipamente audio, AMC-uri sau diverse. Link spre comentariu
Cozonac Postat Iulie 8, 2021 Autor Partajează Postat Iulie 8, 2021 Topicul se poate inchide, multumesc. Link spre comentariu
