Diverse componente
poplex22
1. DVD extern samsung   70lei
https://ibb.co/BP095TC
https://ibb.co/Qv8tSVc
2. Aparat masura rusesc : U4341  30lei
https://ibb.co/Rz5332D
3. Componente rusesti de putere : rezistente, diode tiristori   60lei
https://ibb.co/483QyKq
4. Aspirator masina la 12V   20lei
https://ibb.co/KVG5pWr
https://ibb.co/k3Gk95w
5. Mecanisme DVD         10lei
https://ibb.co/3WQw762
6. Invertoare LCD diverse de la : 12v - 24v alimentare si 2 - 4 - 6 - 8 lampi   40 lei
https://ibb.co/gw5HrnC
7. Diverse filtre ceramice 5,5 - 6 - 6,5mhz , circuite bistandard sunet tv  si FUS-uri    10 lei
https://ibb.co/zx1JGKH
8. Diverse procesoare TV cu tub catodic      20 lei
https://ibb.co/pW1ZF91
9.Diverse tipuri de afisaj segmente led       50 lei
https://ibb.co/1QT6dGY
10. Cutiute cu cheita pt. depozitat orice        10lei
https://ibb.co/hK7PyQY
https://ibb.co/7WTnWY3
11. Diverse valori condensatori stiro ( pF, nF)  si  trimeri ceramici si aer intre 5 - 60pF    40lei
https://ibb.co/7RxcKYq
12. Diverse valori condensatori ceramici pF, zecipF, sutepF, nF zecinF, sutenF           50lei
https://ibb.co/s1gLhp2
13. Diverse valori rezistente pelicula metalica 1%: intre zeci Ohmi - sute KOhmi          60lei
https://ibb.co/z8rjTQ6
14. Diverse leduri culori si marimi :   20lei
https://ibb.co/Xx83gBr
15. Semireglabili simpli si de putere diverse marimi forme si valori : zeci Ohmi - megaOhmi       50lei
https://ibb.co/cc3Cpy9    https://ibb.co/syFYx3J
16. Diverse circuite integrate pt tv-uri cu tub catodic : audio, verticale, alimentare-smps, avf     20lei
https://ibb.co/3YSc6cq
17. Componente digitale : EL74ls02  - 23buc.,  EL74ls03  - 48buc.                             40lei
https://ibb.co/QcmLXxN
18. Push-Touch-uri   22buc.,        10lei
https://ibb.co/ykGcJV1
19. Comutatoare decadice cu iesiri binare : Stripswitch P.C.B    14buc.                       30lei
https://ibb.co/n6Y4fVd
20. Relee reed p.c.b  0,5 - 2A/12V/ 0,9 - 1,2kohmi                         16buc.                       30lei
https://ibb.co/61HCNvK
21. Diverse recuperate : DVD-uri, motorase dvd - cd, unitati optice, subansamble      30lei
https://ibb.co/THG8S4Q
22.Unitati DVD pt. pc.-uri si surse alimentare pt. p.c.-uri: DVD -2buc., surse  -5buc.   60lei
https://ibb.co/VLzKgdR
  • Răspunsuri 27
  • poplex22
    21
  • deneinvins
  • vio2007
  • nelu100
Pachetul cu materialele solicitate (și diverse accesorii) a ajuns în bune condiții.
Mulțumesc și pe această cale pentru expediere și pentru tot ce era în pachet.
  • Membru activ
  • 526 postări
disponibil :
