Canon PIXMA MP110
MARLANU
Am si eu o problema cu imprimanta multifunctionala Canon PIXMA MP110,seara a functionat perfect iar dimineata cand am pornit-o imi apare acest cod : CHECK PRINTER [5B00],daca stie cineva cu se pote remedia acest defect il rog sa imi spuna si mie :prayer:
  • Răspunsuri 5
  • MARLANU
Zile populare
Vizitator Herr Spiegellman
Cred ca trebuie sa scrie in manual. Daca ar fi sa imi dau cu presupusa as spune ca o ai de ceva vreme si ai cam tiparit cu ea... daca e asa da-mi un reply si iti spun ce si cum mai departe :d
Asa... la Canon exista o chestie... si anume in momentul in care isi face curatarea cartuselor, suge ceva cerneala din ele si o "scuipa" intr-un burete aflat pe fundul imprimantei... cand se umple buretele, nu mai vrea sa mearga :d Te rezolva un service, care iti va schimba buretele.
am gasit,poate intereseaza si pe altcineva, Fixed for Canon errors 5b00 + / -I finally got it ..... I reset the MP130 with 5b00 errorBuy myself? \\((^.^)//thinks it over, please....Printer and computer is RAM base structure.They cannot record any memory without battery.please follow the steps with screwdrivers1. Unplug the printer (NO power or any connection)2. Flip the whole thing Up side down3. At the bottom, you can see there are screws4. they are for the generator of the power supply5. Take them away 6. And slowly take away the "brown" box?7. Then you will see a power cord links with printer8. Use a very small driver to release it with real care9. Leave it for 30 minutes10. Put it back together .... doneAfter thatAlso, from other, but work....The reset procedure (for canon MP130) is:-Turn on the machine(1) Press MENU(2) Press SCAN COPY SCAN to enter service mode(3) USE > to got to NVRAM ACCESS(4) set ABS-M LEVEL to 0(5) set ABS-P LEVEL to 0(6) Press STOP to EXITDONE !
