problema afisare numarator pe lcd 16x2
bogdan546
Am realizat un numarator folosind un encoder cu afisare pe serial si pe un lcd 16x2 . Problema este ca pe serial functioneza corect, dar pe lcd in momentul cand decrementez sub -10 sau incementez peste 10 ramane ultima coloana 0 si in loc sa afiseze la decementare 9,8,7 ...0 afiseaza 09, 08,07 ...01  .
#include <LiquidCrystal.h>
const int rs=12, en=11, d4=5, d5=4, d6=3, d7=2;
LiquidCrystal lcd(rs,en,d4,d5,d6,d7);
 int counter = 0;
 int counter1 = 0;
 int currentStateCLK;
 int previousStateCLK;
 String encdir ="";
 void setup() {
   // setare encoder ca intrare D6 si D7
  DDRD &= B00000000;
   // setare pini iesire leduri D8 si D9
  DDRB |=B00000011;
   // Setup Serial Monitor
   Serial.begin (9600);
   lcd.begin(16,2);
   // citire initiala a  inputCLK
   previousStateCLK = (PIND >>6 & B01000000 >> 6);
 void loop() {
  // citire curenta  inputCLK
   currentStateCLK = (PIND >> 6 & B01000000 >> 6);
   if (currentStateCLK != previousStateCLK){
     if ((PIND >> 7 & B10000000 >> 7) != currentStateCLK) {
       counter --;
       counter1 --;
       encdir ="CCW";
       PORTB &= ~B00000001;
       PORTB |= B00000010;
     } else {
       counter ++;
       counter1 ++;
       encdir ="CW";
       PORTB &= ~B00000010;
       PORTB |= B00000001;
     Serial.print("Directie: ");
     Serial.print(encdir);
     Serial.print(" -- Valoare: ");
     Serial.println(counter);
      lcd.setCursor(0,1);
      lcd.print("counter1= ");
      lcd.print(counter1);
   previousStateCLK = currentStateCLK;
  • Răspunsuri 0
Zile populare
