Vand Multimetru digital DT9208A, carcasa antisoc
CADASEDA
40 lei
 Prețul e negociabil
tel 0723423784
Stare: Utilizat
Descriere
Multimetrul digital DT-9208A vine dotat cu o carcasa antisoc si functioneaza cu o baterie de 9 V.
Multimetrul masoara:
- Curent continuu (voltajul si amperajul)
- Curent alternativ (voltajul si amperajul)
- Rezistenta
- Masurare condensatori
- Masurare dioda
- Tranzistori
Voltaj curent continuu:
- Trepte - 200mV, 2V, 20V, 200V, 1000 V
- Rezolutie - 0.1 mV, 1 mV, 10 mV, 100 mV, 1V
- Precizie - 0.5% + 1cifra, 0.8% + 2cifre
Voltaj curent alternativ :
- Trepte - 200mV, 2V, 20V, 200V, 200mV, 750V
- Rezolutie - 0.1 mV, 1 mV, 10 mV, 100 mV, 0.1 mV, 1V
- Precizie - 0,8% + 3 cifre, 1,2% + 3 cifre
Amperaj CC & AC :
- Trepte - 2mA, 20mA, 200mA, 20 A
- Rezolutie - 1 µA, 10 µA, 0.1 mA, 0.01 A
- Precizie - 1% + 1 cifra, 2% + 5 cifre
Rezistenta :
- Trepte - 200, 2k, 20k, 200k, 2M Ohm, 20M, 200M Ohm
- Rezolutie - 0.1, 1, 10, 100, 1k Ohm, 10 k, 100 kOhm
- Precizie - 0.8% + 2 cifre, 1.5% + 2 cifre
Capacitate :
- Trepte - 2nF, 20nF, 200nf, 2µF, 20µF, 200uF
- Rezolutie - 1pF, 10pF, 100pF, 1nF, 10nF, 100nF
- Precizie - 2.5% + 5 cifre
Test Dioda - hfe Transistor - Test Volt 2.8V max
Test Continuu - Less than 30 +/- 10 Ohm
Specificatii:
- Temperatura optima de lucru: +0 - +40 grade C
- Greutate: circa 310g (batteria inclusa)
- Dimensiuni: 191mm(L) x 89mm(W) x 35mm (H)
Gradul de acuratete:
- DC Voltage 200mV-1000V (0.5%+1dgt)
- AC Voltage 200mV-750V (0.8%+3dgt)
- DC Current 2mA-20A (0.5%+1dgt)
- AC Current 2mA-20A (1.0%+3dgt)
- Resistanta 200-200M (0.8%+1dgt)
- Capacitate 2nF-20 grade F (2.5%+3dgt)
  • 1 lună mai târziu...
  • Răspunsuri 1
  • CADASEDA
Zile populare
