Dj_Dog Postat Aprilie 1, 2021 Partajează Postat Aprilie 1, 2021 (editat) 1) ) Traf Onkyo 500VA - 39-20-0-20-39V partea de forta + tensiuni auxiliare - 45 lei dmensiuni inaltime 8.5 cm latime 10 cm grosime pachet tole 6.5 https://imgur.com/XjZe1DI https://imgur.com/Epe4Y2l https://imgur.com/q7jd2m5 https://imgur.com/EbdFj0O https://imgur.com/Wg5c7zX 2) radiator tip tunel - 30 lei https://imgur.com/KE6Ytn6 3)pereche radiatoare 30 lei https://imgur.com/R3eWohS 4) modul subwoofer activ jbl, functional dar cu probleme la potentiometri , traf 200VA etaj final cu 2 bipolari TIP35/36C - 80 lei intreg sau se dezmembreaza https://imgur.com/GBSUiiN https://imgur.com/NGzFNu5 https://imgur.com/yDvb9XS 5) Condensatori Vishay 4700/63V 4 bucati - 50 lei https://imgur.com/gkOkFRU 6) Condensatori Nippon Chemicon 4700uF/71V - 20 lei https://imgur.com/ts1Xz5h 7) Gramada de relee - 15 lei (14 buc) https://imgur.com/iAiKmuL 8) condensatori 3300/ 42V - 15 lei https://imgur.com/Wggf0dA 9) Transformatoare aprox 120VA - 2 x 17 + 2x5V - 50 lei ambele https://imgur.com/7oenH3Y 10) Transformator redresor, tensiuni secundare 16,8 si 17,2V, sarma din secundar aprox 3 mm - 35 lei https://imgur.com/ZErzTJo 11) 3 smps-uri recuperate din switchuri 2 sunt la 220 si unu la 12V si scot tensiuni negative de -25 si-70V, cele la 220V scot si +5V ( ma gandesc ca sunt bune al montajele pe lampi pt teniuni de negativare)- 40 lei toate https://imgur.com/ZErzTJo 12) placa de sursa , nu stiu de la ce echipament, nu stiu daca e functionala, se vad urme de interventie pe ea se vinde completa, cum se vede in poze - 30 lei https://imgur.com/Tnuq6a3 https://imgur.com/hEbYIPv https://imgur.com/xLEgUHS 13) Mosfeti IXTH75N15 - 8 bucati recuperate - 100 lei toti 14) Mosfeti 2sk2837 - 8 buc recuperate - 40 lei toti 15) Mosfeti 2sk1518 - 4 buc - 15 lei toti 16) Amplificator chinezesc 2 x 50W la 4 ohmi, selector 4 intrari, are ledurile la wu-metru schimbate si integratul de comanda - 150 lei https://imgur.com/BrWtO0C 17) Cel lung si subtire este facut de mine cu li-ion 18650 , 10 buc de 2050mAh noi - are 2 cicluri incarcare descarcare - 100 lei Cel gros este nou nout nefolosit, li-po, capacitate 50000mAh - asa scrie pe el- real nu stiu exact Pe un incarcator cu fast charge a incarcat 23% in 6 ore, greutate aprox 600grame Pret - 200 https://imgur.com/GbjY9z4 https://imgur.com/aM3vgZ5 18) Set de 4 acumulatori dintr-o bormasina testati - 25 lei https://imgur.com/pxi0TR0 Editat Aprilie 1, 2021 de Dj_Dog Link spre comentariu
nustiunimic Postat Aprilie 1, 2021 Partajează Postat Aprilie 1, 2021 Linkul pozei de la pct. 11 este gresit (identic cu cel de la pct. 10). Link spre comentariu
Dj_Dog Postat Aprilie 1, 2021 Autor Partajează Postat Aprilie 1, 2021 Multumesc de atentionare Acesta este link-ul corect pt pct 11 -> https://imgur.com/jR4GeY7 Pct 1 si 9 rezervate Link spre comentariu
vali82ct Postat Aprilie 1, 2021 Partajează Postat Aprilie 1, 2021 (editat) Radiatoarele de la punctul 3 ce dimensiuni au? La punctul 11 cele 2 smps uri de -25V la iesire, cam cati amperi pot scoate? Editat Aprilie 1, 2021 de vali82ct Link spre comentariu
Dj_Dog Postat Aprilie 2, 2021 Autor Partajează Postat Aprilie 2, 2021 Acum 7 ore, vali82ct a spus: Radiatoarele de la punctul 3 ce dimensiuni au? La punctul 11 cele 2 smps uri de -25V la iesire, cam cati amperi pot scoate? Radiatoarele de la pct 3 au 36cm lungime/ 5 inaltime si 3,5 grosime, grosimea talpii are 0,5 cm - sunt de la os tatie auto 600W clasa AB La smps-uri nu cred ca scot mai mult de 0,2-0,3A pe tensiunile negative Link spre comentariu
M.Adrian Postat Aprilie 4, 2021 Partajează Postat Aprilie 4, 2021 Mai este disponibil vreun transformator? In poza de la punctul 1 se vad mai multe, m-ar interesa ceva cu 2 secundare de minim 30V si minim 3A pe secundar. Link spre comentariu
Dj_Dog Postat Aprilie 5, 2021 Autor Partajează Postat Aprilie 5, 2021 pct 1 vandut, restul valabile Link spre comentariu
Dj_Dog Postat Aprilie 9, 2021 Autor Partajează Postat Aprilie 9, 2021 anunt valabil Link spre comentariu
vali82ct Postat Aprilie 10, 2021 Partajează Postat Aprilie 10, 2021 Aveti un mp inca necitit. Link spre comentariu
Dj_Dog Postat Aprilie 11, 2021 Autor Partajează Postat Aprilie 11, 2021 Acum 11 ore, vali82ct a spus: Aveti un mp inca necitit. citit si raspuns! se adauga incarcatoare li-ion 16,8V/2A si 21V/1A - 25 lei bucata Link spre comentariu
Dj_Dog Postat Aprilie 30, 2021 Autor Partajează Postat Aprilie 30, 2021 up-date 1)Acumulatori litiu polimer diferite capacitati, unii masurati , altii nu - in jur de 30 bucati - 120 lei toti (nu apar toti in poza) https://imgur.com/ylTen56 2) radiator tip tunel - 20 lei https://imgur.com/KE6Ytn6 3)pereche radiatoare 20 lei https://imgur.com/R3eWohS 4) modul subwoofer activ jbl, functional dar cu probleme la potentiometri , traf 200VA etaj final cu 2 bipolari TIP35/36C - 80 lei intreg sau se dezmembreaza https://imgur.com/GBSUiiN https://imgur.com/NGzFNu5 https://imgur.com/yDvb9XS 5) Condensatori Vishay 4700/63V 4 bucati - 40 lei https://imgur.com/gkOkFRU 6) Condensatori Nippon Chemicon 4700uF/71V - 20 lei https://imgur.com/ts1Xz5h 7) Gramada de relee - 15 lei (14 buc) https://imgur.com/iAiKmuL 8) condensatori 3300/ 42V - 15 lei https://imgur.com/Wggf0dA 9) Transformatoare aprox 120VA - 2 x 17 + 2x5V - 50 lei ambele https://imgur.com/7oenH3Y 10) Transformator redresor, tensiuni secundare 16,8 si 17,2V, sarma din secundar aprox 3 mm - 35 lei https://imgur.com/ZErzTJo 11) 3 smps-uri recuperate din switchuri 2 sunt la 220 si unu la 12V si scot tensiuni negative de -25 si-70V, cele la 220V scot si +5V ( ma gandesc ca sunt bune al montajele pe lampi pt teniuni de negativare)- 40 lei toate https://imgur.com/ZErzTJo 12) placa de sursa , nu stiu de la ce echipament, nu stiu daca e functionala, se vad urme de interventie pe ea se vinde completa, cum se vede in poze - 20 lei https://imgur.com/Tnuq6a3 https://imgur.com/hEbYIPv https://imgur.com/xLEgUHS 13) Mosfeti IXTH75N15 - 8 bucati recuperate - 90 lei toti 14) Mosfeti 2sk2837 - 8 buc recuperate - 30 lei toti 15) Mosfeti 2sk1518 - 4 buc - 10lei toti 16) Amplificator chinezesc 2 x 50W la 4 ohmi, selector 4 intrari, are ledurile la wu-metru schimbate si integratul de comanda - 150 lei https://imgur.com/BrWtO0C 17) incarcatoare li-ion 16,8V/2A si 21V/1A - 20 lei bucata https://imgur.com/cw0xRhZ 18) Set de 4 acumulatori dintr-o bormasina testati - 20 lei https://imgur.com/pxi0TR0 trimit in provincie doar cu plata in avans / comanda minima 50 lei Link spre comentariu
Dj_Dog Postat Mai 1, 2021 Autor Partajează Postat Mai 1, 2021 pct 1 rezervat momentan Link spre comentariu
