Piese electronice, placi recuperate, aparate si carti
marianjoita
Se adauga la vanzare
Tranzistoare de putere
Lot format din 6 tranzistoare de putere recuperate, verificate: 2 x 2SC2278 (Si, NPN, 300V/1,25W/80MHz), 1 x 2SD478 (Si, NPN, 200V/5A/30W), 1 x 2SC1723 (Si, NPN, 300V/0,2A/15W/60MHz), 2 x 13007 (Si, NPN, 700V/8A/80W). Pret 8 lei tot lotul.
Foto: https://ibb.co/D8zqgh1
Lot 7 tranzistoare de putere cu siliciu, recuperate, verificate; 2 x 2N3055, 2 x KU607, 1 x KU601, 1 x SU169, 1 x 2SC642A (Toshiba). Pret 16 lei tot lotul.
Foto: https://ibb.co/1X2bG3Q
Tranzistoare de medie putere
Lot 3 tranzistoare de medie putere BF871 (Si, NPN, 300V/0,1A/1,6W/100MHz), recuperate, verificate. Pret 2 lei tot lotul.
Foto: https://ibb.co/6PPmhhF
Lot format din 6 tranzistoare de medie putere recuperate, verificate BF881 (Si, NPN, 400V,/0,1A, 7W, 60MHz). Pret 5 lei tot lotul.
Foto: https://ibb.co/fMhbvs7
Lot format din 6 tranzistoare de medie putere SF369 (250V, 0,03A, 60MHz, 2W). Recuperati, verificati. Pret 3 lei tot lotul.
Foto: https://ibb.co/cJrxBDd
Tranzistoare de mica putere
Lot format din 17 tranzistoare cu siliciu de mica putere, recuperate, verificate: 2SC639 (Si, NPN, 40V/0,2A/0,36W/375MHz), 2SC1634(Si, NPN, 50V/0,2A/0,32W/70MHz), PH2369 (Si, NPN, 40V/0,2A/0,5W/500MHz), 3 x 2SC2236 (Si, NPN, 30V/0,5A/0,9W/60MHz), EV C 936, UD S 16, 2 x 2SC2001 (Si, NPN, 30V/0,7A/0,6W/170MHz), 2 x BC172, 4 nemarcate. Pret 5 lei toate.
Foto: https://ibb.co/c2DbPc5
Lot format din 9 tranzistoare PNP (8 mica putere, 1 medie putere), recuperate, verificate: 8R303 (medie putere), CV 2 306 (SC306), 4 x 2SA733, 1 x BC251A, 2 x BC 557. Pret 3 lei tot lotul.
Foto: https://ibb.co/8NT1RmC
Lot format din 7 tranzistoare recuperate, verificate 2SC2482 (Si, NPN, 300V, 0,1A, 0,9W, 50MHz) Pret 2 lei tot lotul.
Foto: https://ibb.co/SK2j52n
Integrate
Lot 7 integrate recuperate, verificate: P3842 (controller PWM in frecventa), CVA2411TX (Arie de 3 tranzistoare folosite in circuitele de baleiaj orizontale ale monitoarelor CRT), TDA2140 (CI pentru regenerarea si procesarea subpurtatoarei in circuitele decodoare PAL), TDA2591 (oscilator orizontal TV color), TDA2151 (amplificator de iluminare si crominanta TV color), TDA2161 (Demodulator sincronizat si matrice RGB pentru TV color cu facilitati de afisare pe ecran). Pret 6 lei toate. Bonus, 1 x ET1100 (optocuplor), 1 x MCR22A (tiristor de mica putere), TDA3653C (circuit deflectie verticala).Pret 2 lei toate.
Foto: https://ibb.co/Z2rbFFP
Surse
Lot format din 3 surse 7805 recuperate. Pret 3 lei toate.
Foto: https://ibb.co/LNPWRtr
Punti redresoare
Lot format din doua punti redresoare: 1 x 3PM4 (recuperata), 1 x 3PM8 (noua). Pret 4 lei ambele.
Foto: https://ibb.co/7XrWn1C
Lot 10 punti redresoare recuperate: 2 x 1PM05, 2 x 1PM2, 1 x 1PM4, 2 x 1PM6, 2 x 1PM8, 1 x B250C1500. Pret 6 lei toate.
Foto: https://ibb.co/bv46RG5
Diode
Lot format din 3 diode redresoare duble Schottky SBL 2040CT (40V/20A). Recuperate, verificate. Pret 2 lei toate.
Foto: https://ibb.co/HGVWzNq
Lot format din 18 diode redresoare cu siliciu diverse, recuperate, verificate. Pret 2 lei tot lotul.
Foto: https://ibb.co/ZXZHSHv
15 diode redresoare duble ESAD81-004, capsule TO-3 (40V, 12A nominal, 120A varf). Recuperate, verificate. Pret 15 lei toate.
Foto: https://ibb.co/txqvGr0
Diverse
Lot 3 comutatoare recuperate cu un slot: unul are 10 pozitii, unul 12 pozitii iar al treilea 4 pozitii. Pret 15 lei toate.
Foto: https://ibb.co/NnjGdy0
Potentiometru multitura cu valoarea de 1K. Pret 5 lei.
Foto: https://ibb.co/QrCD44v
https://ibb.co/Yp2y5F6
Lot format din 14 cristale de cuart recuperate: 3 x 4 MHz, 3 x 4,4336190 MHz, 3,5795450 MHz, 20,250000 MHz, 8,867238 MHz, 12, 000 Mhz, 1-527-274-11, 27,000 Mhz, 8867,238, 10.000MHz . Pret 4 lei tot lotul.
Foto: https://ibb.co/nkPPBpD
TOATE PRETURILE SUNT NEGOCIABILE!
  • Răspunsuri 142
  • marianjoita
    43
  • GMCD
    22
  • vio2007
    10
  • imreberes
    9
Doresc sa cumpar:
Lot format din 10 tranzistoare MOSFET de putere, recuperate, verificate: P9NK50ZFP, 2 x 13N50C, KA1MO565R, 2 x IRFP150, F20NF06L, 3 x IRFZ44N, Pret 10 lei tot lotul.
Foto: https://ibb.co/mzDF9Yk
Lot format din 12 tranzistoare cu siliciu, 3 de putere (1 x BU205, 1 x SU169, 1 x TIP142), 9 de medie putere (2 x BD136, 1 x BF459, 1 x BD135, 1 x BD139, 3 x SF358, 1 x SD335). Recuperate, verificate. Pret 11 lei tot lotul.
Foto: https://ibb.co/ZVJ0wx0
Tranzistoare 2N3055, noi, verificate. Pret 2,5 lei bucata, disponibile 15 bucati.
Foto: https://ibb.co/CzKSsRm
9 tranzistoare BU, marea majoritate noi, verificate: 3 x BUX81, 2 x BU606, 1 x BU209, 2 x BU208, 1 x BU608. Pret 18 lei toate
Foto: https://ibb.co/DMLjXCy
Lot 4 tranzistoare noi BU508AFI, producator ST Microelectronics. Pret 12 lei tot lotul.
Foto: https://ibb.co/brvB2Ck
Lot 5 tranzistoare de putere rusesti, noi, KT812A. Pret 15 lei tot lotul
Foto: https://ibb.co/N2G4r44
Lot 6 tranzistoare de putere romanesti noi: 1 x 2N3772, 2 x 2N3442, 1 x SDT9209, 2 x SDT9204. Pret 15 lei toate.
Foto: https://ibb.co/P5wP2Pn
Lot 4 tranzistoare de putere cu germaniu verificate: 2 x ASZ1017 (Tungsram, unul are un picior mai scurt), 1 x ASZ15, 1 x ASZ16. Pret 12 lei toate.
Foto:
2 tranzistoare KD607, fabricatie Tesla. Verificate. Pret 5 lei.
Foto: https://ibb.co/KNZGqg7
Lot 10 diode sovietice D237B (400V/300mA), noi. Pret 2 lei lotul.
Foto: https://ibb.co/1JqTV6x
Lot format din 35 de diode redresoare recuperate, verificate, mai mult de jumatate din ele de putere. Pret 4 lei.
Foto: https://ibb.co/ncp41Ld
Va rog sa adaugati la mine:
Tranzistoare 2N3055, noi, verificate. Pret 2,5 lei bucata, disponibile 15 bucati. - pe cele care au indicativul terminat cu cifra 8 sau cu 10
1 oră în urmă, marianjoita a spus:
astea le doresc eu.revin cu completare.
Doresc eu
Din cele de 2N3055 as dori cu sufixul de H, W sau nimic.
Editat de imreberes
Lot format din 4 tranzistoare de putere cu siliciu KUY12, productie Tesla. Noi. Pret 10 lei lotul, disponibile mai multe loturi.
Foto: https://ibb.co/rxq4rxF
https://ibb.co/WkrhbCY
Circuite integrate romanesti TBA 570, noi. Pret 3 lei bucata.
Foto: https://ibb.co/JryT29q
Circuite integrate romanesti βT150, amplificatoare de putere, fara echivalent strain. Au fost utilizate ca etaje finale in radioreceptoare romanesti construite dupa 1990 (de exemplu radioreceptorul Thomas). Pret 3 lei bucata.
Foto: https://ibb.co/s27nP6H
Actualizare
Piese electronice
Tranzistoare 2N3055, noi, verificate. Pret 2,5 lei bucata, disponibile 17 bucati.
Foto: ttps://ibb.co/DMLjXCy
V a rog sa adaugati la mine:
Placa sursa in comutatie, 12V si 5V. Completa. Pret 20 lei.
Foto: https://ibb.co/LP3wb2w
https://ibb.co/Wp4nXG9
Placa recuperata de la un UPS de 600W. Are ca elemente active 5 MOSFET P60NF06 si un LM317 precum si 3 relee de 12V. Pret 14 lei.
Foto: https://ibb.co/BrqcTS3
https://ibb.co/YN4MtrC
Placa recuperata de la UPS de 600W. Este construit cu 6 N-channel Mosfet P60NF06 (60A/60V/135W) si 4 relee de 12V cu contacte 250V/12A. Functionala. Pret 18 lei.
Foto: https://ibb.co/wz9NzsC
https://ibb.co/XYGNWNH
https://ibb.co/23W9bby
Placa recuperata de la un blitz rusesc, construita cu 4 tranzistoare cu siliciu 3 tranzistoare de putere KT837K si 1 x КУ110. Functionala, completa. Pret 12 lei.
Foto: https://ibb.co/Q9V91Bh
Placa recuperata construita cu CI BA10358 si 6 tranzistoare de mica putere 4 x 2SC3374, 2 x 2SC3274. Integratul nu este lipit direct, este conectat cu ajutorul unui soclu. Montajul pare un preamplificator stereo. Pret 5 lei.
Foto: https://ibb.co/x1JfHdr
Montaj recuperat construit cu ajutorul a doua tranzistoare de colectie, SFT121 (cele cu palarie). Pret 3 lei.
Foto: https://ibb.co/n1s29vn
Placa recuperata din TV LG functionale dar cu display-uri sparte. Codul se vede in foto. Pret 25 lei.
Foto: https://ibb.co/wM4nwBd
https://ibb.co/nsY7fY5
Placa recuperata din TV LG functionale dar cu display-uri sparte. Codul se vede in foto. Pret 20 lei.
Foto: https://ibb.co/Z8RqFJ3
https://ibb.co/pX87nN0
Placa recuperata din aparatura de telecomunicatii. Are ca elemente de putere 2 tranzistoare 2N6554 (productie RCA) si unul 2N3055 (Motorola). Construita cu componente de calitate, in cea mai mare parte japoneze. Pret 18 lei.
Foto: https://ibb.co/HrRyDXX
Placa recuperata din aparatura Siemens. Are ca element de baza un tranzistor de medie putere 2N3441. Pret 6 lei.
Foto: https://ibb.co/sPpx6v8
Actualizare
Piese electronice
Lot format din 4 tranzistoare de putere cu siliciu KUY12 (80V/10A/70W/9MHz), productie Tesla. Noi. Pret 10 lei lotul, disponibile mai multe loturi.
