Vand Osciloscop Multimetru profesional Fluke 97
CADASEDA
pret 1400lei neg
telefon 0723423784
Multimetru profesional Fluke 97 scopemeter in stare perfecta de funcționare.
Made in Holland.
A fost verificat recent si s-a constatat ca are inca o precizie foarte buna pe toate domeniile de masura ( nu necesita calibrare)
Poate inlocui cu succes un osciloscop digital de laborator, prezinta avantaj portabilitatea, iar alimentarea din baterii nu mai necesita separare galvanica la depanarea surselor in comutatie.
Poate masura si rezistente mici pana la 0,01 ohm cu posibilitatea de compensare a cordoanelor
Poate genera semnale dreptunghiulare, sinus, rampa de tensiune si curent.
Masoara Vmax, Vmin, Vpp, Vavr, Vrms, Perioada, frecventa, pwm duty cycle, etc(5 valori simultan).
This is a Digital Hand-held Scopemeter Fluke 97. The oscilloscope is a dual channel 50MHz in fine working condition.
Please note: I sell the item with power supply and the case.
Main features:
- Bandwidth: 50 MHz Dual Channel
- Sample Rate: 25 Megasamples/second
- Autoset: Automatically sets Voltage, Time & Trigger
- Multimeter Display: 3 2/3 Digits (> 3000 Counts)
- True RMS Volts: AC or AC+DC up to 600V (1700V Pk-Pk)
- Resistance: 30 ohm to 30 Mohm
- Diode Test: up to 2.8V
- Continuity Beeper
- Time/Division: 10 ns/div to 5 sec/div
- Volts/Division: 1 mV/div to 100 V/div
- Current Probe Scaling
- Digital Delay or Pre-Trigger: By Number of Cycles, Events or Time
- Special Multimeter Modes: dBm, dBV, dBW, Audio Watts
- Oscilloscope Cursors: Display 5 Simultaneously
- Waveform Memory
- Set-up Memory: Store & Recall 10 Front Panel Set-Ups
- Waveform Mathematics: Add, Subtract, Multiply, Invert, Filter or Integrate Waveforms
- Signal Generator Output: Sine wave, Square wave or Ramp
Editat de CADASEDA
  • Răspunsuri 7
  • CADASEDA
    5
  • daniels
  • Cozonac
  • MCIGMA
