IR (CIR) Headers
Ovidanie
Am primit cadou o placa de baza Intel® Desktop Board DH67BL model   G10189-207 si vad ca are un conector pentru " Consumer IR (CIR) Headers";
The Desktop Board has two CIR headers: the receiver or input header (Figure 20, C)
and the output or emitter header (Figure 20, D). The receiver header consists of a
filtered translated infrared input compliant with Microsoft CIR specifications and a
“learning” infrared input. The learning input is a high-pass input which the computer
can use to “learn” to speak the infrared communication language of other user
remotes. The emitter header consists of two output ports which the computer can use
to emulate “learned” infrared commands in order to control external electronic
hardware.
Adica dupa ce " invata " telecomanda pot regla volumul auditiei si play/ pauza in VLC ??
  • Răspunsuri 0
  • Ovidanie
Zile populare
