Componente si module noi de vanzare
Viorel A
  • Răspunsuri 97
  • Viorel A
    86
  • hixpp02
  • Tanase Ion
  • Zoltanh
Adaugare produse si actializare preturi:
1. Modul senzori curent ACS715 Polulu (noi)     - 1buc.   30 lei
2. Module senzori curent ACS709 Polulu          - 2 buc   30 lei/buc.
3. Leonardo ETH, ATmega32U4 Ethernet W5500 (V2) - 1 buc.  90 lei
Microcontrollere:       https://ibb.co/1qdZxX3
4.  PIC12F675       - 4 buc     - 7 lei/bucata
5.  PIC16F690-I/P   - 1buc      - 8 lei
6.  PIC16F648A-I/P, - 2 buc.    - 10 lei/bucata
7.  PIC18F1320-I/P, - 2 buc     - 10 lei/bucata
8. ATMEGA168-20PU, - 1 buc.    - 15 lei
9. ATMEGA88PA-PU,  - 2 buc.    - 8 lei/bucata.  // 15 lei ambele
10. ATMEGA88-20PU,  - 1 buc.    - 8 lei.
Audio D/A Converter     https://ibb.co/hRtNc6R
11. WM8804G     - S/PDIF Digital Interface Transceiver                                                            -  4buc   - 8 lei/buc
12. PCM1792ADBR - 132dB SNR Highest Performance Stereo DAC (S/W Control) -  1buc    - 8 lei
13. PCM1794ADBR - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC    -  3buc    - 8 lei/buc
14. PCM1796DB   - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC        - 5buc    - 8 lei/buc
15. PCM1798DB   - Audio D/A Converter ICs PCM1798 24-Bit 192kHz Audio DAC  - 3buc    - 8 lei
16. CS4398-CZZ  - Audio D/A Converter Stereo Multi-Bit DAC 192kHz 120dB        - 3buc    - 20lei/buc
17. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End                        - 2buc    - 20lei/buc
18. AD1981B     - AC '97 SoundMAX Codec Data Sheet (Rev. C)   - 1buc
Amplificatoare:         https://ibb.co/KxVSntt
19. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D      - 3buc      - 12 lei/buc sau 30 lei toate.
20. TPA3123D2 - amplificator clasaD  25W                                           - 3 bucati  - 8 lei/bucata sau 20 lei toate.
21. TPA6120A2DWP - amplificator HiFi pt. casti de la TI , 2 bucati     - 6 lei/bucata  IC-ul este marcat cu 89E335T 6120A2
Diverse:            https://ibb.co/KxVSntt
21. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, - 2buc - 8lei/bucata
22. SN65LBC179D - Low-Power Differential Line Driver And Receiver Pair                             - 1buc - 5 lei
23. TAS1020BPFB  - TAS1020B TAS1020 USB Streaming Controller                                       - 3buc - 4 lei/buc
24. TCA9535PWR -Interface - I/O Expanders Remt 16Bit I2C SMBus Lo-Pwr I/O Expndr            - 5buc - 2 lei/buc
25. Nou: Kit bluetoth pt. motociclisti Motorcycle Bluetooth Headsets M1-S Pro   ( https://ibb.co/ynMB7LL )-  350 lei  https://www.fodsports.com/m1s-pro/
26. Nou : Mikrotik Groove 5Hn -  https://ibb.co/GdqWYRy https://ibb.co/M8GxXXX - 200 lei
27. Camera de actiune Sony HDR-AS30V -  https://ibb.co/GdqWYRy https://ibb.co/M8GxXXX  - utilizata- 250 lei
28.  Kit DC 12V 10A Relay 1CH Wireless RF Remote Control Switch Transmitter Receiver - varianta cu o singura telecomanda - nou -  45 lei   https://ibb.co/DK2N8mB  https://ibb.co/R7tM4M4
29.  Kit DC 12V 10A Relay 1CH Wireless RF Remote Control Switch Transmitter Receiver - varianta cu 2 telecomenzi - nou -  70 lei       https://ibb.co/ryyQn8H    http:// https://ibb.co/M7KYwMK
30. Kit ceas electronic cu LED, alimentare de la 5v - 20 lei
32. Kit telecomanda IR, contine telecomanda, senzorul IR si firele din imagine - 20 lei (bonus o a doua telecomanda), ambele nefolosite.
Componentele sunt adunate in timp si nu intentionez sa le mai folosesc. Preturile in opinia mea sunt mai mult decat convenabile. M-as bucura sa fie de folos cuiva iar eu sa recuperez o  parte din valoarea acestora.
Cheltuielile de transport vor fi suportate de cumparator.
  • 2 săptămâni mai târziu...
  • 1 lună mai târziu...
28.
Disponibile pentru vanzare  urmatoarele module si componente noi:
28.
Este ultima actualizare a listei si a preturilor dupa care voi renunta la acest mod de valorificare a componentelor.
Pentru comenzi mai mari de 300 lei pretul poate fi negociat.
2. Module senzori curent ACS709 Polulu          - 2 buc   25 lei/buc.
3. Leonardo ETH, ATmega32U4 Ethernet W5500 (V2) - 1 buc.  80 lei
4.
8. ATMEGA168-20PU, - 1 buc.    - 14 lei
11. WM8804G     - S/PDIF Digital Interface Transceiver                                                            -  4buc   - 8 lei/buc - 30 lei toate
13. PCM1794ADBR - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC    -  3buc    - 8 lei/buc  - 20 lei toate
14. PCM1796DB   - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC        - 5buc    - 8 lei/buc - 30 lei toate
16. CS4398-CZZ  - Audio D/A Converter Stereo Multi-Bit DAC 192kHz 120dB        - 3buc    - 20lei/buc - 50 lei toate
17. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End                        - 2buc    - 20lei/buc - 35 lei toate
19. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D      - 3buc      - 12 lei/buc sau 25 lei toate.
22.
23. TAS1020BPFB  - TAS1020B TAS1020 USB Streaming Controller                                       - 3buc - 4 lei/buc - 10 lei toate
24.
25.
28.
29.  Kit DC 12V 10A Relay 1CH Wireless RF Remote Control Switch Transmitter Receiver - varianta cu 2 telecomenzi - nou -  50 lei       https://ibb.co/ryyQn8H    http:// https://ibb.co/M7KYwMK
30. Kit ceas electronic cu LED, alimentare de la 5v - 10 lei
32. Kit telecomanda IR, contine telecomanda, senzorul IR si firele din imagine - 15 lei (bonus o a doua telecomanda), ambele nefolosite.
  • 4 luni mai târziu...
Buna ziua! Sunt interesat sa achizitionez de la dvs 1buc. x  ATMEGA88-20PU, si, poate daca a mai ramas ratacit prin "biblioteca" dvs. ,1buc.ATTINY 2313-20PU . Trimiteti-mi mesaj la tel.0733552033 ca sa stabilim detaliile,in caz ca sunteti de acord.Multumesc anticipat!Sanatate!
Va salut,
Daca le mai aveti, as lua reperele de mai jos:
Daca mai aveti MCP601, le-as lua si pe acelea.
Va multmesc!
Va rog daca se poate sa-mi rezervati punctul 30 kit ceas si mai astept pana mai adaugati cv la vanzare sa merite de un colet cu stima si respect multumesc anticipat
