Componente si module noi de vanzare
Viorel A
Actualizare lista componente disponibile:
1. Lot de 79 circuite integrate noi(neutilizate). Se vand doar la pachet: 100 lei
MMC4510       3
ULN2004AN   13
ULN2003A     1
LM3915N-1    2
MMC4051E    1
CD74HC4052E   1
SG3524N     2
HIN232CP    1
MMC4017    1
TBA920       1
HEF4050BP   2
DP111    1
BM324   1
74175PC  1
MMC4011  1
TCA440  1
CDB4157E    4
BE555  1
TDA1046  1
MMC40193E  1
74HCT14  1
74LS06N  1
MMC4543  1
MMC381  1
CDB400  1
MT8870DE    2
SN7408  1
F-7474PC  1
SN74LS244N  1
SN7404N  1
BA723C  1
74175PC  1
LM337       6
TS7809      2
M27C256B    2
74HCT125N   3
MAX712CPE   1
ICM7556IPD  1
CD4511DE    4
MC14513BCP  4
M74HC368B1  3
2. Modul senzori curent ACS715 Polulu (noi)     - 1buc.   40 lei
3. Module senzori curent ACS709 Polulu          - 2 buc   40 lei/buc.
4. Leonardo ETH, ATmega32U4 Ethernet W5500 (V2) - 1 buc.  120 lei
5. Placa de dezvoltare Arduino Mega (Atmega2560)- 1 buc   40 lei
6.
Microcontrollere:       https://ibb.co/1qdZxX3
7.  PIC12F675       - 4 buc     - 7 lei/bucata
8.  PIC16F690-I/P   - 1buc      - 8 lei
9.  PIC16F648A-I/P, - 2 buc.    - 10 lei/bucata
10.  PIC18F1320-I/P, - 2 buc     - 10 lei/bucata
11. ATMEGA168-20PU, - 1 buc.    - 10 lei
12. ATMEGA88PA-PU,  - 2 buc.    - 10 lei/bucata.
13. ATMEGA88-20PU,  - 1 buc.    - 10 lei.
Audio D/A Converter     https://ibb.co/hRtNc6R
14. WM8804G     - S/PDIF Digital Interface Transceiver                   -  4buc    - 10 lei/buc
15. PCM1792ADBR - 132dB SNR Highest Performance Stereo DAC (S/W Control) -  1buc    - 10 lei /buc
16. PCM1794ADBR - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC -  3buc    - 10 lei/buc
17. PCM1796DB   - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC  - 5buc    - 10 lei/buc
18. PCM1798DB   - Audio D/A Converter ICs PCM1798 24-Bit 192kHz Audio DAC - 3buc    - 10 lei
19. CS4398-CZZ  - Audio D/A Converter Stereo Multi-Bit DAC 192kHz 120dB   - 3buc    - 25lei/buc
20. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End             - 2buc    - 25lei/buc
21. AD1981B     - AC '97 SoundMAX Codec Data Sheet (Rev. C)   - 1buc (bonus la cumpararea de componente in valoare > 50 lei)
Amplificatoare:         https://ibb.co/KxVSntt
22. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D      - 3buc      - 15 lei/buc sau 40 lei toate.
23. TPA3123D2 - amplificator clasaD  25W                        - 3 bucati  - 8 lei/bucata sau 20 lei toate.
24. TPA6120A2DWP - amplificator HiFi pt. casti de la TI , 2 bucati - 6 lei/bucata  IC-ul este marcat cu 89E335T 6120A2
Diverse:            https://ibb.co/KxVSntt
25. TCA2465 SIEMENS, smd, 4 bucati - 4 lei/ bucata
26. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, - 2buc - 8lei/bucata
27. SN65LBC179D - Low-Power Differential Line Driver And Receiver Pair                      - 1buc - 5 lei
28. TAS1020BPFB  - TAS1020B TAS1020 USB Streaming Controller                                - 3buc - 4 lei/buc
29. TCA9535PWR -Interface - I/O Expanders Remt 16Bit I2C SMBus Lo-Pwr I/O Expndr            - 5buc - 2 lei/buc
30. Transformatoare audio  1:1 (600ohm) - 6 buc                                             - 12 lei/buc sau  60 lei toate.
31. ADT7463A Remote Thermal Controller and Voltage Monitor - 1buc   (bonus la cumpararea de componente in valoare > 50 lei)
Componentele sunt adunate in timp si nu intentionez sa le mai folosesc. Preturile in opinia mea sunt mai mult decat convenabile. M-as bucura sa fie ce folos cuiva iar eu sa recuperez o mica parte din valoarea acestora.
Cheltuielile de transport vor fi suportate de cumparator.
  • Răspunsuri 97
  • Viorel A
    86
  • hixpp02
  • Tanase Ion
  • Zoltanh
  • 2 săptămâni mai târziu...
Pentru ca s-au mai dat din ele, actualizez lista componentelor disponibile:
MMC4510  3
ULN2004AN   13
ULN2003A     1
LM3915N-1    2
MMC4051E    1
CD74HC4052E   1
SG3524N     2
HIN232CP    1
MMC4017    1
TBA920       1
HEF4050BP   2
DP111    1
BM324   1
74175PC  1
MMC4011  1
TCA440  1
CDB4157E    4
BE555  1
TDA1046  1
MMC40193E  1
74HCT14  1
74LS06N  1
MMC4543  1
MMC381  1
CDB400  1
MT8870DE    2
SN7408  1
F-7474PC  1
SN74LS244N  1
SN7404N  1
BA723C  1
74175PC  1
LM337       6
TS7809      2
M27C256B    2
74HCT125N   3
MAX712CPE   1
ICM7556IPD  1
CD4511DE    4
MC14513BCP  4
M74HC368B1  3
5.
6.
  • 3 săptămâni mai târziu...
Actualizare lista componentelor disponibile:
MMC4510  3
ULN2004AN   13
ULN2003A     1
LM3915N-1    2
MMC4051E    1
CD74HC4052E   1
SG3524N     2
HIN232CP    1
MMC4017    1
TBA920       1
HEF4050BP   2
DP111    1
BM324   1
74175PC  1
MMC4011  1
TCA440  1
CDB4157E    4
BE555  1
TDA1046  1
MMC40193E  1
74HCT14  1
74LS06N  1
MMC4543  1
MMC381  1
CDB400  1
MT8870DE    2
SN7408  1
F-7474PC  1
SN74LS244N  1
SN7404N  1
BA723C  1
74175PC  1
LM337       6
TS7809      2
M27C256B    2
74HCT125N   3
MAX712CPE   1
ICM7556IPD  1
CD4511DE    4
MC14513BCP  4
M74HC368B1  3
5.
6.
30.
31.
Componentele sunt adunate in timp si nu intentionez sa le mai folosesc. Preturile in opinia mea sunt mai mult decat convenabile. M-as bucura sa fie de folos cuiva iar eu sa recuperez o mica parte din valoarea acestora.
1.
5.
6.
30.
Adaug:
31. Network Attached Storage Zyxel NSA320 in perfecta stare de functionare. A fost utilizat in regim casnic (spun asta pentru a se intelege ca nu a functionat in regim permanent, 24 din 24 si 7 zile din 7).
Aparatul se vinde cu 2 HDD-uri de 1T (sistemul de operare este pe unul dintre acestea).
https://ibb.co/Ph5d2yC https://ibb.co/dr12Vyy https://ibb.co/gMWqJBL https://ibb.co/YRhSCMG https://ibb.co/xfcksbN       - pret  350 lei
32. Nou: Kit bluetoth pt. motociclisti Motorcycle Bluetooth Headsets M1-S Pro   ( https://ibb.co/ynMB7LL )-  350 lei  https://www.fodsports.com/m1s-pro/
33. Nou : Mikrotik Groove 5Hn -  https://ibb.co/GdqWYRy https://ibb.co/M8GxXXX - 200 lei
34. Camera de actiune Sony HDR-AS30V -  https://ibb.co/GdqWYRy https://ibb.co/M8GxXXX  - utilizata- 250 lei
Componentele sunt adunate in timp si nu intentionez sa le mai folosesc. Preturile in opinia mea sunt mai mult decat convenabile. M-as bucura sa fie de folos cuiva iar eu sa recuperez o  parte din valoarea acestora.
1.
5.
6.
30.
Adaug:
35. Placa de dezvoltare "LILYGO TTGO T5 V2.4 Wifi Bluetooth Wireless Module Base ESP-32 Esp32 BW Display EPaper Electric Development Board" + display e-ink 2.9" suplimentar . Modulul este nou . https://ibb.co/SxkZZ3B          https://ibb.co/xHGwgq3         https://ibb.co/1r7B79X       pret - 120 lei
1. Modul senzori curent ACS715 Polulu (noi)     - 1buc.   40 lei
2. Module senzori curent ACS709 Polulu          - 2 buc   40 lei/buc.
3. Leonardo ETH, ATmega32U4 Ethernet W5500 (V2) - 1 buc.  120 lei
4.  PIC12F675       - 4 buc     - 7 lei/bucata
5.  PIC16F690-I/P   - 1buc      - 8 lei
6.  PIC16F648A-I/P, - 2 buc.    - 10 lei/bucata
7.  PIC18F1320-I/P, - 2 buc     - 10 lei/bucata
8. ATMEGA168-20PU, - 1 buc.    - 10 lei
9. ATMEGA88PA-PU,  - 2 buc.    - 10 lei/bucata.
10. ATMEGA88-20PU,  - 1 buc.    - 10 lei.
11. WM8804G     - S/PDIF Digital Interface Transceiver                                                            -  4buc   - 10 lei/buc
12. PCM1792ADBR - 132dB SNR Highest Performance Stereo DAC (S/W Control) -  1buc    - 10 lei
13. PCM1794ADBR - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC    -  3buc    - 10 lei/buc
14. PCM1796DB   - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC        - 5buc    - 10 lei/buc
15. PCM1798DB   - Audio D/A Converter ICs PCM1798 24-Bit 192kHz Audio DAC  - 3buc    - 10 lei
16. CS4398-CZZ  - Audio D/A Converter Stereo Multi-Bit DAC 192kHz 120dB        - 3buc    - 25lei/buc
17. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End                        - 2buc    - 25lei/buc
18. AD1981B     - AC '97 SoundMAX Codec Data Sheet (Rev. C)   - 1buc
19. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D      - 3buc      - 15 lei/buc sau 40 lei toate.
20. TPA3123D2 - amplificator clasaD  25W                                           - 3 bucati  - 8 lei/bucata sau 20 lei toate.
21. TPA6120A2DWP - amplificator HiFi pt. casti de la TI , 2 bucati     - 6 lei/bucata  IC-ul este marcat cu 89E335T 6120A2
22. TCA2465 SIEMENS, smd, 4 bucati - 4 lei/ bucata
23. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, - 2buc - 8lei/bucata
24. SN65LBC179D - Low-Power Differential Line Driver And Receiver Pair                             - 1buc - 5 lei
25. TAS1020BPFB  - TAS1020B TAS1020 USB Streaming Controller                                       - 3buc - 4 lei/buc
26. TCA9535PWR -Interface - I/O Expanders Remt 16Bit I2C SMBus Lo-Pwr I/O Expndr            - 5buc - 2 lei/buc
27. Nou: Kit bluetoth pt. motociclisti Motorcycle Bluetooth Headsets M1-S Pro   ( https://ibb.co/ynMB7LL )-  350 lei  https://www.fodsports.com/m1s-pro/
28. Nou : Mikrotik Groove 5Hn -  https://ibb.co/GdqWYRy https://ibb.co/M8GxXXX - 200 lei
29. Camera de actiune Sony HDR-AS30V -  https://ibb.co/GdqWYRy https://ibb.co/M8GxXXX  - utilizata- 250 lei
Adaug:
30.  Kit DC 12V 10A Relay 1CH Wireless RF Remote Control Switch Transmitter Receiver - varianta cu o singura telecomanda - nou -  45 lei
https://ibb.co/DK2N8mB  https://ibb.co/R7tM4M4
31.  Kit DC 12V 10A Relay 1CH Wireless RF Remote Control Switch Transmitter Receiver - varianta cu 2 telecomenzi - nou -  70 lei
Editat de Viorel A
Adaug:
Actualizare preturi pentru componentele si modulele disponibile:
1. Modul senzori curent ACS715 Polulu (noi)     - 1buc.   35 lei
2. Module senzori curent ACS709 Polulu          - 2 buc   35 lei/buc.
3. Leonardo ETH, ATmega32U4 Ethernet W5500 (V2) - 1 buc.  100 lei
8. ATMEGA168-20PU, - 1 buc.    - 18 lei
9. ATMEGA88PA-PU,  - 2 buc.    - 8 lei/bucata.
10. ATMEGA88-20PU,  - 1 buc.    - 8 lei.
11. WM8804G     - S/PDIF Digital Interface Transceiver                                                            -  4buc   - 8 lei/buc
12. PCM1792ADBR - 132dB SNR Highest Performance Stereo DAC (S/W Control) -  1buc    - 8 lei
13. PCM1794ADBR - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC    -  3buc    - 8 lei/buc
14. PCM1796DB   - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC        - 5buc    - 8 lei/buc
15. PCM1798DB   - Audio D/A Converter ICs PCM1798 24-Bit 192kHz Audio DAC  - 3buc    - 8 lei
16. CS4398-CZZ  - Audio D/A Converter Stereo Multi-Bit DAC 192kHz 120dB        - 3buc    - 20lei/buc
17. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End                        - 2buc    - 20lei/buc
19. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D      - 3buc      - 12 lei/buc sau 30 lei toate.
22.
30.  Kit DC 12V 10A Relay 1CH Wireless RF Remote Control Switch Transmitter Receiver - varianta cu o singura telecomanda - nou -  45 lei   https://ibb.co/DK2N8mB  https://ibb.co/R7tM4M4
31.  Kit DC 12V 10A Relay 1CH Wireless RF Remote Control Switch Transmitter Receiver - varianta cu 2 telecomenzi - nou -  70 lei       https://ibb.co/ryyQn8H    http:// https://ibb.co/M7KYwMK
