Componente si module noi de vanzare
Viorel A
Adaug la cele de mai sus 3 kit-uri cu modul gprs Neoway M590E.
Un kit contine un pcb, un modul M590E + celelate componente necesare.
Avesta este kit-ul: https://www.instructables.com/GSMGPRS-Module-DIY-Kit/
Sunt disponibile 3 bucati la pretul de 25 lei / bucata , cu ridicare personala din Brasov sau
Sfantu Gheorghe sau cu transport prin Posta/Curier, caz in care cheltuielile de transport vor fi suportate de cumparator.
https://ibb.co/9sbsKgW
https://ibb.co/GsPwy2W
  • Răspunsuri 97
  • Viorel A
    86
  • hixpp02
  • Tanase Ion
  • Zoltanh
Am actualizat lista modulelor/componentelor  si preturile:
1. Modul camera video OV7670  ,  2 bucati - 10 lei / bucata. https://ibb.co/dpMY95d
2. Modul afisaj LED cu 4 digiti - I2C (50x20mm - dimensiunile afisajului - 0.56"  cu TM1637) , 2 bucati - 9 lei /bucata https://ibb.co/yVnrqrK
3. Modul afisaj LED cu 4 digiti - I2C (30x14mm - dimensiunile afisajului cu TM1637) , 2 buc. - 6 lei/ bucata https://ibb.co/0j8wzDF
4. 2 module Olimex "Prototype board for PIC18F67J60 with Ethernet and TCP-IP stack"   - 20 lei/buc
Informatii despre aceste gasiti aici : https://www.olimex.com/Products/PIC/Proto/PIC-P67J60/
Modulele au fost folosite si au firmware-ul schimbat. https://ibb.co/f0Zd4xq https://ibb.co/DYG1Rcz
Microcontrollere:       https://ibb.co/1qdZxX3
5.  PIC12F675 - 4 buc - 5 lei/bucata
6.  PIC16F690-I/P - 1buc - 6 lei
7.  PIC16F648A-I/P, 2 buc. - 8 lei/bucata
8.  PIC18F1320-I/P, 2 buc - 8 lei/bucata
9.  ATMEGA168-20PU, 1 buc. - 8 lei
10. ATMEGA88PA-PU, 2 buc. - 5 lei/bucata.
11. ATMEGA88-20PU, 1 buc. - 5 lei.
Audio D/A Converter     https://ibb.co/hRtNc6R
12. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End - 4buc  - 18lei/buc sau 50 lei toate.
13. WM8804G  - S/PDIF Digital Interface Transceiver-    4buc - 6 lei/buc sau 20 lei toate
14. PCM1792ADBR - 132dB SNR Highest Performance Stereo DAC (S/W Control) -  3buc  - 10 lei /buc
https://www.ti.com/lit/ds/symlink/pcm1792.pdf
15. PCM1794ADBR - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC -  5buc  - 10 lei/buc sau 40 lei toate.
https://www.ti.com/lit/ds/symlink/pcm1794.pdf
16. PCM1796DB    - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC  - 5buc - 10 lei/buc sau 40 lei toate.
https://www.ti.com/lit/ds/symlink/pcm1796.pdf
17. PCM1798DBG4  - Audio D/A Converter ICs PCM1798 24-Bit 192kHz Audio DAC - 5buc - 10 lei/buc sau 40 lei toate.
https://www.ti.com/lit/ds/symlink/pcm1798.pdf
18. CS4398-CZZ   - Audio D/A Converter ICs Stereo Multi-Bit DAC 192kHz 120dB w/VC - 6buc - 16lei/buc
https://ro.mouser.com/datasheet/2/76/CS4398_F2-1141331.pdf
Amplificatoare:         https://ibb.co/KxVSntt
19. LM3886T - Audio Power Amplifier, 68 W, B, 1 Channel, 20V to 84V, TO-220, 11 Pins - 7buc - 25 lei/buc sau 150 lei toate.
https://www.ti.com/lit/ds/symlink/lm3886.pdf?ts=1610863647078&ref_url=https%3A%2F%2Fwww.google
20. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D - 3buc - 13 lei/buc sau 30 lei toate.
http://www.ti.com/general/docs/suppproductinfo.tsp?distId=10&gotoUrl=http%3A%2F%2Fwww.ti.com%2Flit%2Fgpn%2Ftpa3120d2
21. TPA3123D2 - amplificator clasaD  25W - 3 bucati - 8 lei/bucata sau 20 lei toate.
22. TPA6120A2DWP - amplificator HiFi pt. casti de la TI , 6 bucati - 6 lei/bucata sau 30 lei toate.
IC-ul este marcat cu 89E335T 6120A2
Diverse:            https://ibb.co/KxVSntt
23. TCA2465 SIEMENS, smd, 4 bucati - 4 lei/ bucata
https://ibb.co/k0QdDyv
24. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, 2 buc. - 8lei/bucata
25. SN65LBC179D - Low-Power Differential Line Driver And Receiver Pair - 5buc - 5 lei/buc
26. TAS1020BPFB  - TAS1020B TAS1020 USB Streaming Controller - 3buc - 4 lei/buc
https://www.mouser.com/datasheet/2/405/tas1020b-557821.pdf
27. TCA9535PWR -Interface - I/O Expanders Remt 16Bit I2C SMBus Lo-Pwr I/O Expndr - 5buc - 2 lei/buc
https://www.ti.com/lit/ds/symlink/tca9535.pdf?ts=1610875383162&ref_url=https%3A%2F%2Fwww.google.com%2F
28. Transformatoare audio  1:1 (600ohm) - 6 buc - 12 lei/buc sau  60 lei toate.
29. Kit-uri cu modul GSM Neoway M590E.  - 3 bucati - 25 lei/bucata sau 60 lei cele 3 bucati.
https://ibb.co/9sbsKgW https://ibb.co/GsPwy2W
Cu exceptia modulelor Olimex (pct.4), toate celelalte sunt noi.
Cheltuielile de transport vor fi suportate de cumparator.
  • 2 săptămâni mai târziu...
La 08.06.2021 la 17:54, Viorel A a spus:
Sus ...
  • 1 lună mai târziu...
Disponibile :
  • 3 săptămâni mai târziu...
  • 4 săptămâni mai târziu...
Disponibile pentru vanzare:
4. 2
Actualizare lista:
4. 2
5.  PIC12F675 - 4 buc - 7 lei/bucata
6.  PIC16F690-I/P - 1buc - 8 lei
7.  PIC16F648A-I/P, 2 buc. - 10 lei/bucata
8.  PIC18F1320-I/P, 2 buc - 10 lei/bucata
9.  ATMEGA168-20PU, 1 buc. - 10 lei
10. ATMEGA88PA-PU, 2 buc. - 10 lei/bucata.
11. ATMEGA88-20PU, 1 buc. - 10 lei.
12. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End - 4buc  - 25lei/buc
13. WM8804G  - S/PDIF Digital Interface Transceiver-    4buc - 10 lei/buc
18. CS4398-CZZ   - Audio D/A Converter ICs Stereo Multi-Bit DAC 192kHz 120dB w/VC - 6buc - 25lei/buc
20. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D - 3buc - 15 lei/buc sau 40 lei toate.
Componentele sunt adunate in timp de aceea preturile le-am stabilit mai mici decat preturile actuale de lista de la TME.
Actualizare lista:
1. Lot de 79 circuite integrate noi(neutilizate). Se vand doar la pachet: 100 lei
MMC4510       3
ULN2004AN   13
ULN2003A     1
LM3915N-1    2
MMC4051E    1
CD74HC4052E   1
SG3524N     2
HIN232CP    1
MMC4017    1
TBA920       1
HEF4050BP   2
DP111    1
BM324   1
74175PC  1
MMC4011  1
TCA440  1
CDB4157E    4
BE555  1
TDA1046  1
MMC40193E  1
74HCT14  1
74LS06N  1
MMC4543  1
MMC381  1
CDB400  1
MT8870DE    2
SN7408  1
F-7474PC  1
SN74LS244N  1
SN7404N  1
BA723C  1
74175PC  1
LM337       6
TS7809      2
M27C256B    2
74HCT125N   3
MAX712CPE       IC: circuit de supraveghere; controler încărcare acumulatori  35
ICM7556IPD      IC: circuit periferic; astabil,monostabil,ceas RC; CMOS; 1MHz
CD4511DE    4
MC14513BCP  4   BCD−To−Seven Segment Latch/Decoder/Driver CMOS MSI (Low−Power Complementary MOS)
M74HC368B1  3
2. Modul senzori curent ACS715 Polulu (noi) - 1buc.  40 lei
3. Module senzori curent ACS709 Polulu - 2 buc   40lei/buc.
4. Leonardo ETH, ATmega32U4 Ethernet W5500 (V2) 1 buc.  120 lei
5. Placa de dezvoltare Arduino Mega (Atmega2560) 1 buc  40 lei
6. Placa de dezvoltare Arduino DUE R3  2 buc.    120 lei
6.  PIC12F675 - 4 buc - 7 lei/bucata
7.  PIC16F690-I/P - 1buc - 8 lei
8.  PIC16F648A-I/P, 2 buc. - 10 lei/bucata
9.  PIC18F1320-I/P, 2 buc - 10 lei/bucata
10.  ATMEGA168-20PU, 1 buc. - 10 lei
11. ATMEGA88PA-PU, 2 buc. - 10 lei/bucata.
12. ATMEGA88-20PU, 1 buc. - 10 lei.
16. PCM1796DB    - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC  - 3buc - 10 lei/buc
17. PCM1798DBG4  - Audio D/A Converter ICs PCM1798 24-Bit 192kHz Audio DAC - 3buc - 10 lei
18. CS4398-CZZ   - Audio D/A Converter ICs Stereo Multi-Bit DAC 192kHz 120dB w/VC - 3buc - 25lei/buc
19. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End - 2buc  - 25lei/buc
20. LM3886T - Audio Power Amplifier, 68 W, B, 1 Channel, 20V to 84V, TO-220, 11 Pins - 7buc - 25 lei/buc
21. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D - 3buc - 15 lei/buc sau 40 lei toate.
22. TPA3123D2 - amplificator clasaD  25W - 3 bucati - 8 lei/bucata sau 20 lei toate.
23. TPA6120A2DWP - amplificator HiFi pt. casti de la TI , 2 bucati - 6 lei/bucata sau 30 lei toate. IC-ul este marcat cu 89E335T 6120A2
24. TCA2465 SIEMENS, smd, 4 bucati - 4 lei/ bucata
25. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, 2 buc. - 8lei/bucata
26. SN65LBC179D - Low-Power Differential Line Driver And Receiver Pair - 5buc - 5 lei/buc
27. TAS1020BPFB  - TAS1020B TAS1020 USB Streaming Controller - 3buc - 4 lei/buc
28. TCA9535PWR -Interface - I/O Expanders Remt 16Bit I2C SMBus Lo-Pwr I/O Expndr - 5buc - 2 lei/buc
Componentele sunt adunate in timp si nu intentionez sa le mai folosesc. Preturile in opinia mea sunt mai mult decat convenabile. M-as bucura sa fie ce folos cuiva iar eu sa recuperez o mica parte din valoarea acestora.
Editat de Viorel A
1 oră în urmă, vily a spus:
Va salut,
Ce provenienta are circuitul integrat? Este cumparat de la un distribuitor sau Aliexpress?
Cred ca de la Farnell le-am cumparat acum 6-7 ani.  Sigur nu de pe Aliexpress.
Acum 16 ore, yoo a spus:
Bună seara.
Punctele 20 și 23 le vreau eu.
Revin cu adresa pe PM.
Va mulțumesc anticipat
 Va salut!  Componentele de la pct. 20 s-au dat deja.
Va rog sa luati in considerare doar ultima lista care va fi actualizata:
MMC4510       3
ULN2004AN   13
ULN2003A     1
LM3915N-1    2
MMC4051E    1
CD74HC4052E   1
SG3524N     2
HIN232CP    1
MMC4017    1
TBA920       1
HEF4050BP   2
DP111    1
BM324   1
74175PC  1
MMC4011  1
TCA440  1
CDB4157E    4
BE555  1
TDA1046  1
MMC40193E  1
74HCT14  1
74LS06N  1
MMC4543  1
MMC381  1
CDB400  1
MT8870DE    2
SN7408  1
F-7474PC  1
SN74LS244N  1
SN7404N  1
BA723C  1
74175PC  1
LM337       6
TS7809      2
M27C256B    2
74HCT125N   3
MAX712CPE   1
ICM7556IPD  1
CD4511DE    4
MC14513BCP  4
M74HC368B1  3
3. Module senzori curent ACS709 Polulu          - 2 buc   40 lei/buc.
4. Leonardo ETH, ATmega32U4 Ethernet W5500 (V2) - 1 buc.  120 lei
5. Placa de dezvoltare Arduino Mega (Atmega2560)- 1 buc   40 lei
6. Placa de dezvoltare Arduino DUE R3           - 2 buc.  120 lei
7.  PIC12F675       - 4 buc     - 7 lei/bucata
8.  PIC16F690-I/P   - 1buc      - 8 lei
9.  PIC16F648A-I/P, - 2 buc.    - 10 lei/bucata
10.  PIC18F1320-I/P, - 2 buc     - 10 lei/bucata
11. ATMEGA168-20PU, - 1 buc.    - 10 lei
12. ATMEGA88PA-PU,  - 2 buc.    - 10 lei/bucata.
13. ATMEGA88-20PU,  - 1 buc.    - 10 lei.
14. WM8804G     - S/PDIF Digital Interface Transceiver                   -  4buc    - 10 lei/buc
15. PCM1792ADBR - 132dB SNR Highest Performance Stereo DAC (S/W Control) -  1buc    - 10 lei /buc
16. PCM1794ADBR - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC -  3buc    - 10 lei/buc
17. PCM1796DB   - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC  - 5buc    - 10 lei/buc
18. PCM1798DB   - Audio D/A Converter ICs PCM1798 24-Bit 192kHz Audio DAC - 3buc    - 10 lei
19. CS4398-CZZ  - Audio D/A Converter Stereo Multi-Bit DAC 192kHz 120dB   - 3buc    - 25lei/buc
20. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End             - 2buc    - 25lei/buc
21. AD1981B     - AC '97 SoundMAX Codec Data Sheet (Rev. C)   - 1buc (bonus la cumpararea de componente in valoare > 50 lei)
22. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D      - 3buc      - 15 lei/buc sau 40 lei toate.
23. TPA3123D2 - amplificator clasaD  25W                        - 3 bucati  - 8 lei/bucata sau 20 lei toate.
24. TPA6120A2DWP - amplificator HiFi pt. casti de la TI , 2 bucati - 6 lei/bucata  IC-ul este marcat cu 89E335T 6120A2
25. TCA2465 SIEMENS, smd, 4 bucati - 4 lei/ bucata
26. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, - 2buc - 8lei/bucata
27. SN65LBC179D - Low-Power Differential Line Driver And Receiver Pair                      - 1buc - 5 lei
28. TAS1020BPFB  - TAS1020B TAS1020 USB Streaming Controller                                - 3buc - 4 lei/buc
29. TCA9535PWR -Interface - I/O Expanders Remt 16Bit I2C SMBus Lo-Pwr I/O Expndr            - 5buc - 2 lei/buc
30. Transformatoare audio  1:1 (600ohm) - 6 buc                                             - 12 lei/buc sau  60 lei toate.
31. ADT7463A Remote Thermal Controller and Voltage Monitor - 1buc   (bonus la cumpararea de componente in valoare > 50 lei)
