Componente si module noi de vanzare
Viorel A
  • Răspunsuri 97
  • Viorel A
    86
  • hixpp02
  • Tanase Ion
  • Zoltanh
1. Modul camera video OV7670  ,  2 bucati - 20 lei / bucata.
https://ibb.co/dpMY95d
2. TCA2465 SIEMENS, smd, 4 bucati - 6 lei/ bucata
https://ibb.co/k0QdDyv
3. CS8416  (digital audio receiver 192 kHz), 2 bucati - 20 lei / bucata
https://ibb.co/gtS9h8y
4. Modul afisaj LED cu 4 digiti - I2C (50x20mm - dimensiunile afisajului - 0.56"  cu TM1637) , 2 bucati - 12 lei /bucata
https://ibb.co/yVnrqrK
5. Modul afisaj LED cu 4 digiti - I2C (30x14mm - dimensiunile afisajului cu TM1637) , 2 buc. - 8 lei/ bucata
https://ibb.co/0j8wzDF
6.
7. TPA3123D2 - amplificator clasaD  25W - 3 bucati - 10lei/ bucata
8. PCM2707  2 buc. - 20lei/bucata
9. TPA6120A2DWP - amplificator HiFi pt. casti de la TI , 6 bucati - 8 lei/ bucata.
IC-ul este marcat cu 89E335T 6120A2
https://ibb.co/hRtNc6R
10. DIR901  (96kHz Digital Audio Receiver), 6 buc. - 4lei/buc
12. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, 2 buc. - 8lei/bucata
13. PIC12F675 - 4 buc - 7lei/bucata
16. PIC16F690-I/P - 1buc - 7 lei
17. PIC16F648A-I/P, 2 buc. - 10 lei/bucata
18. PIC18F1320-I/P, 2 buc - 9lei/bucata
19. ATMEGA168-20PU, 1 buc. - 9 lei
21. ATMEGA88PA-PU, 2 buc. - 6 lei/bucata.
22. ATMEGA88-20PU, 1 buc. - 8 lei.
https://ibb.co/1qdZxX3
25. 2 module Olimex "Prototype board for PIC18F67J60 with Ethernet and TCP-IP stack"   - 35lei/buc
Informatii despre aceste gasiti aici : https://www.olimex.com/Products/PIC/Proto/PIC-P67J60/
Modulele au fost folosite si au firmware-ul schimbat.
https://ibb.co/f0Zd4xq
https://ibb.co/DYG1Rcz
27. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End - 8buc  - 20lei/buc
28. WM8804G  - S/PDIF Digital Interface Transceiver-    9buc - 7 lei/buc
29. SN65LBC179D - Low-Power Differential Line Driver And Receiver Pair - 5buc - 8lei/buc
30. TAS1020BPFB  - TAS1020B TAS1020 USB Streaming Controller - 5buc - 6 lei/buc
https://www.mouser.com/datasheet/2/405/tas1020b-557821.pdf
31. PCM1796DB    - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC  - 5buc - 14lei/buc
https://www.ti.com/lit/ds/symlink/pcm1796.pdf
32. PCM1798DBG4  - Audio D/A Converter ICs PCM1798 24-Bit 192kHz Audio DAC - 5buc - 14lei/buc
https://www.ti.com/lit/ds/symlink/pcm1798.pdf
33. PCM1794ADBR - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC -  5buc  - 14lei/buc
https://www.ti.com/lit/ds/symlink/pcm1794.pdf
34. PCM1792ADBR - 132dB SNR Highest Performance Stereo DAC (S/W Control) -  5buc  - 14 lei /buc
https://www.ti.com/lit/ds/symlink/pcm1792.pdf
35. CS4398-CZZ   - Audio D/A Converter ICs Stereo Multi-Bit DAC 192kHz 120dB w/VC - 6buc - 20lei/buc
https://ro.mouser.com/datasheet/2/76/CS4398_F2-1141331.pdf
36. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D - 3buc - 20 lei / buc
http://www.ti.com/general/docs/suppproductinfo.tsp?distId=10&gotoUrl=http%3A%2F%2Fwww.ti.com%2Flit%2Fgpn%2Ftpa3120d2
37. TCA9535PWR -Interface - I/O Expanders Remt 16Bit I2C SMBus Lo-Pwr I/O Expndr - 5buc - 4lei/buc
https://www.ti.com/lit/ds/symlink/tca9535.pdf?ts=1610875383162&ref_url=https%3A%2F%2Fwww.google.com%2F
38. LM3886T - Audio Power Amplifier, 68 W, B, 1 Channel, 20V to 84V, TO-220, 11 Pins - 7buc - 30lei/buc
https://www.ti.com/lit/ds/symlink/lm3886.pdf?ts=1610863647078&ref_url=https%3A%2F%2Fwww.google.com%2F
40. LME49710 - Dual High Performance, High Fidelity Audio Operational; DIP8 -    5buc - 10lei/buc
41. Transformatoare audio  1:1 (600ohm) - 6 buc - 15 lei / buc
https://ibb.co/KxVSntt
Module diverse, microcontrollere, DAC-uri HiFi, amplificatoare audio de putere si pt. casti + diverse disponibile.
Le-am organizat putin pe categorii. Componentele sunt noi (nefolosite). Unele nu se mai fabrica sau sunt mai greu de gasit.
Doar modulele Olimex au fost folosite , celelalte sunt neutilizate.
Module:
2. Modul afisaj LED cu 4 digiti - I2C (50x20mm - dimensiunile afisajului - 0.56"  cu TM1637) , 2 bucati - 12 lei /bucata
3. Modul afisaj LED cu 4 digiti - I2C (30x14mm - dimensiunile afisajului cu TM1637) , 2 buc. - 8 lei/ bucata
4. 2 module Olimex "Prototype board for PIC18F67J60 with Ethernet and TCP-IP stack"   - 35lei/buc
https://ibb.co/f0Zd4xq https://ibb.co/DYG1Rcz
Microcontrollere:       https://ibb.co/1qdZxX3
5.  PIC12F675 - 4 buc - 7lei/bucata
10. ATMEGA88PA-PU, 2 buc. - 6 lei/bucata.
11. ATMEGA88-20PU, 1 buc. - 8 lei.
Audio D/A Converter     https://ibb.co/hRtNc6R
12. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End - 8buc  - 20lei/buc
13. WM8804G  - S/PDIF Digital Interface Transceiver-    9buc - 7 lei/buc
14. PCM1792ADBR - 132dB SNR Highest Performance Stereo DAC (S/W Control) -  5buc  - 14 lei /buc
15. PCM1794ADBR - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC -  5buc  - 14lei/buc
16. PCM1796DB    - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC  - 5buc - 14lei/buc
17. PCM1798DBG4  - Audio D/A Converter ICs PCM1798 24-Bit 192kHz Audio DAC - 5buc - 14lei/buc
18. PCM2707  2 buc. - 20lei/bucata
19. CS4398-CZZ   - Audio D/A Converter ICs Stereo Multi-Bit DAC 192kHz 120dB w/VC - 6buc - 20lei/buc
20. CS8416  (digital audio receiver 192 kHz), 2 bucati - 20 lei / bucata
21. DIR901  (96kHz Digital Audio Receiver), 6 buc. - 4lei/buc
Amplificatoare:         https://ibb.co/KxVSntt
22. LM3886T - Audio Power Amplifier, 68 W, B, 1 Channel, 20V to 84V, TO-220, 11 Pins - 7buc - 30lei/buc
23. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D - 3buc - 20 lei / buc
24. TPA3123D2 - amplificator clasaD  25W - 3 bucati - 10lei/ bucata
25. TPA6120A2DWP - amplificator HiFi pt. casti de la TI , 6 bucati - 8 lei/ bucata.
Diverse:            https://ibb.co/KxVSntt
26. TCA2465 SIEMENS, smd, 4 bucati - 6 lei/ bucata
27. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, 2 buc. - 8lei/bucata
28. SN65LBC179D - Low-Power Differential Line Driver And Receiver Pair - 5buc - 8lei/buc
29. TAS1020BPFB  - TAS1020B TAS1020 USB Streaming Controller - 5buc - 6 lei/buc
30. TCA9535PWR -Interface - I/O Expanders Remt 16Bit I2C SMBus Lo-Pwr I/O Expndr - 5buc - 4lei/buc
31. LME49710 - Dual High Performance, High Fidelity Audio Operational; DIP8 -    5buc - 10lei/buc
32. Transformatoare audio  1:1 (600ohm) - 6 buc - 15 lei / buc
Module:
Actualizare lista componente disponibile:
Module:
21.
31.
La 08.02.2021 la 18:44, Viorel A a spus:
Module:
21.
31.
Up...
Module:
21.
31.
