Componente si module noi de vanzare
Viorel A
Pentru ca s-au adunat prea multe si nu intentionez sa le mai folosesc, sunt disponibile urmatoarele:
1. Modul camera video OV7670  ,  2 bucati - 20 lei / bucata.
https://ibb.co/dpMY95d
2. TCA2465 SIEMENS, smd, 4 bucati - 6 lei/ bucata
https://ibb.co/k0QdDyv
3. CS8416  (digital audio receiver 192 kHz), 4 bucati - 20 lei / bucata
https://ibb.co/gtS9h8y
4. Modul afisaj LED cu 4 digiti - I2C (50x20mm - dimensiunile afisajului - 0.56"  cu TM1637) , 2 bucati - 12 lei /bucata
https://ibb.co/yVnrqrK
5. Modul afisaj LED cu 4 digiti - I2C (30x14mm - dimensiunile afisajului cu TM1637) , 2 buc. - 8 lei/ bucata
https://ibb.co/0j8wzDF
6. Modul cu PCF8574T - adaptor afisaj LCD char la I2C - 1 bucata - 7lei
7. TPA3123D2 - amplificator clasaD  25W - 3 bucati - 10lei/ bucata
8. PCM2707  2 buc. - 20lei/bucata
9. TPA6120A2DWP - amplificator HiFi pt. casti de la TI , 6 bucati - 6 lei/ bucata.
IC-ul este marcat cu 89E335T 6120A2
https://ibb.co/hRtNc6R
10. DIR901  (96kHz Digital Audio Receiver), 6 buc. - 4lei/buc
11. PCM1796 123dB SNR Stereo DAC (S/W Control)  - 10lei/buc
https://ibb.co/pj6NhTT
12. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, 5 buc. - 8lei/bucata
13. PIC12F675 - 5 buc - 7lei/bucata
14. PIC16F628A-I/P - 1 buc - 4 lei
15. PIC16F84A-04/P - 1 buc. - 10lei
16. PIC16F690-I/P - 1buc - 7 lei
17. PIC16F648A-I/P, 2 buc. - 10 lei/bucata
18. PIC18F1320-I/P, 2 buc - 9lei/bucata
19. ATMEGA168-20PU, 1 buc. - 9 lei
20. ATTINY2313-20PU, 1 buc. -  5 lei
21. ATMEGA88PA-PU, 2 buc. - 6 lei/bucata.
22. ATMEGA88-20PU, 1 buc. - 8 lei.
23. ATTINY13-20PU , 1 buc - 5lei
24. MCP601-I/P , 3 buc -  2lei/buc
https://ibb.co/1qdZxX3
  • Răspunsuri 97
  • Viorel A
    86
  • hixpp02
  • Tanase Ion
  • Zoltanh
Buna ziua,
Doresc sa cumpar:
-BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, 1 bucata - 8lei/bucata
- PIC12F675 - 1 buc - 7lei/bucata
- PIC16F628A-I/P - 1 buc - 4 lei
- PIC16F648A-I/P, 1 buc. - 10 lei/bucata
- ATTINY2313-20PU, 1 buc. -  5 lei
- ATTINY13-20PU , 1 buc - 5lei
- MCP601-I/P , 3 buc -  2lei/buc - 6lei
TOTAL = 52 Lei
Daca mai sunt disponibile va trimit PM cu adresa.
Multumesc.
Acum 19 ore, Zoltanh a spus:
Buna ziua,
Doresc sa cumpar:
TOTAL = 52 Lei
Multumesc.
Sigur, Astept adresa.
Au ramas disponibile:
12. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, 4 buc. - 8lei/bucata
13. PIC12F675 - 4 buc - 7lei/bucata
25. 2 module Olimex "Prototype board for PIC18F67J60 with Ethernet and TCP-IP stack"   - 35lei/buc
Informatii despre aceste gasiti aici : https://www.olimex.com/Products/PIC/Proto/PIC-P67J60/
Modulele au fost folosite si au firmware-ul schimbat.
https://ibb.co/f0Zd4xq
https://ibb.co/DYG1Rcz
Disponibile:
Cele doua afisaje de la pct. 26 le cumpar eu.
Va rog sa rezervati cateva zile, mai adaugam ceva pe parcurs.
Multumesc.
Editat de hixpp02
Constat ca mi-au ramas multe componente noi pe care nu le voi mai folosi asa ca public aici o lista actualizata cu speranta ca vor fi de folos cuiva:
Componentele cum spuneam sunt noi si de cea mai buna calitate (cumparate din surse de incredere), iar unele dintre acestea nu se mai fabrica.
12. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, 3 buc. - 8lei/bucata
26. 2 afisaje noi (neutilizate) Raystar tip RX2002A-FHW-TS (Afişaj: LCD; alfanumerice; COG,FSTN Positive; 20x2; LED; PIN: 8) - 16 lei/ bucata
https://www.tme.eu/Document/b6b8e0d42be042efebdee8423bd3c746/RX2002A-FHW-TS.pdf
27. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End - 10buc  - 20lei/buc
28. WM8804G  - S/PDIF Digital Interface Transceiver-    9buc - 7 lei/buc
29. SN65LBC179D - Low-Power Differential Line Driver And Receiver Pair - 5buc - 8lei/buc
30. TAS1020BPFB  - TAS1020B TAS1020 USB Streaming Controller - 5buc - 6 lei/buc
https://www.mouser.com/datasheet/2/405/tas1020b-557821.pdf
31. PCM1796DB    - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC  - 5buc - 14lei/buc
https://www.ti.com/lit/ds/symlink/pcm1796.pdf
32. PCM1798DBG4  - Audio D/A Converter ICs PCM1798 24-Bit 192kHz Audio DAC - 5buc - 14lei/buc
https://www.ti.com/lit/ds/symlink/pcm1798.pdf
33. PCM1794ADBR - Audio D/A Converter ICs 24 bit 192kHz Stereo Audio DAC -  5buc  - 14lei/buc
https://www.ti.com/lit/ds/symlink/pcm1794.pdf
34. PCM1792ADBR - 132dB SNR Highest Performance Stereo DAC (S/W Control) -  5buc  - 14 lei /buc
https://www.ti.com/lit/ds/symlink/pcm1792.pdf
35. CS4398-CZZ   - Audio D/A Converter ICs Stereo Multi-Bit DAC 192kHz 120dB w/VC - 8buc - 20lei/buc
https://ro.mouser.com/datasheet/2/76/CS4398_F2-1141331.pdf
36. TPA3120D2PWP-ND - Audio Amplifiers 25-W Stereo Class-D - 3buc - 20 lei / buc
http://www.ti.com/general/docs/suppproductinfo.tsp?distId=10&gotoUrl=http%3A%2F%2Fwww.ti.com%2Flit%2Fgpn%2Ftpa3120d2
37. TCA9535PWR -Interface - I/O Expanders Remt 16Bit I2C SMBus Lo-Pwr I/O Expndr - 5buc - 4lei/buc
https://www.ti.com/lit/ds/symlink/tca9535.pdf?ts=1610875383162&ref_url=https%3A%2F%2Fwww.google.com%2F
38. LM3886T - Audio Power Amplifier, 68 W, B, 1 Channel, 20V to 84V, TO-220, 11 Pins - 7buc - 30lei/buc
https://www.ti.com/lit/ds/symlink/lm3886.pdf?ts=1610863647078&ref_url=https%3A%2F%2Fwww.google.com%2F
39. LM4562 -Amplificator operaţional; 55MHz; 2,5÷17V; Canale: 2; DIP8-      5buc - 1.5 lei/buc
https://www.ti.com/lit/gpn/lm4562
40. LME49710 - Dual High Performance, High Fidelity Audio Operational; DIP8 -    5buc - 10lei/buc
41. Transformatoare audio  1:1 (600ohm) - 6 buc - 15 lei / buc
https://ibb.co/KxVSntt
S-au vandut cateva componente asa ca actualizez cantitatile:
3. CS8416  (digital audio receiver 192 kHz), 2 bucati - 20 lei / bucata
6.
9. TPA6120A2DWP - amplificator HiFi pt. casti de la TI , 6 bucati - 8 lei/ bucata.
12. BQ24001 , 1-cell, 1.2-A, linear Li-ion battery charger with integrated FET and one LED, 2 buc. - 8lei/bucata
27. WM8741GEDS  - Audio D/A Converter ICs Stereo DAC High End - 8buc  - 20lei/buc
35. CS4398-CZZ   - Audio D/A Converter ICs Stereo Multi-Bit DAC 192kHz 120dB w/VC - 6buc - 20lei/buc
