Sistemul de distribuţie canadian: bifazat sau monofazic simetric ? (de la Automobile electrice)
  • Răspunsuri 89
1280px-Elementary_Two_Phase_Alternator.j
Pentru mine asta este cu doua faze.
The generators at Niagara Falls installed in 1895 were the largest generators in the world at that time and were two-phase machines
https://en.wikipedia.org/wiki/Two-phase_electric_power
In USA si Canada avem Split-phase electric power.
https://en.wikipedia.org/wiki/Split-phase_electric_power
Quote
A split-phase or single-phase three-wire system is a type of single-phase electric power distribution. It is the alternating current (AC) equivalent of the original Edison Machine Works three-wire direct-current system. Its primary advantage is that it saves conductor material over a single-ended single-phase system, while only requiring a single phase on the supply side of the distribution transformer.[1]
The two 120 V AC lines are supplied to the premises from a transformer with a 240 V AC secondary winding which has a center tap connected to ground. This results in two 120 V AC line voltages which are out of phase by 180 degrees with each other. The system neutral conductor is connected to ground at the transformer center tap. 240 V AC can be obtained by connecting the load between the two 120 V AC lines.
Editat de merck
Acum 12 minute, merck a spus:
https://www.scribd.com/doc/251227880/Electrotehnica-de-la-A-la-Z-pdf
Vezi aici cum sunt definite sisteme monofazice si sistemele bifazice in limba romana.
Ce ai aratat tu acolo este un caz particular de sistem bifazic nesimetric.
Alimentarea in America de Nord se face prin sistem bifazic simetric.
Vezi si cum e definit sistemul monofazic.
Poate te lamuresti si iti mai deschizi orizontul....
Pentru mine e incheiata discutia si sincer nu ma intereseaza ce zice dl Lepadat sau cum interpreteaza el ceea ce crede ca a inteles el.
Am pus din cartea dlui Wildi care stie el de ce nu alimenteaza motoarele monofazate in acest sistem "bifazat", si insista ca fraierul sa puna condensatoare de pornire. Oare dl Lepadat stie?
1 hour ago, Sharky said:
Daca da, puse la cat? La 180?
In cazul de fata 120-240V, cele 2 tensiuni de 120V sunt defazate la 180 grade una fata de cealalta.
Editat de Mircea
Un sistem n fazat are n faze independente una de alta aflate  intr-o relatie de faza bine stabilita, era definitia generala.
Acel sistem nu are "fazele" indeendente intre ele, o incarci pe una se incarca in realitate faza principala care este in fapt doar una, aia de MT.
Editat de Ion_Bumbu
Acum 8 minute, Ion_Bumbu a spus:
Tu ai fiert ceva rachie acuma?
Editat de d2134
Acum 24 minute, Mircea a spus:
Hai ca o dam in solutia magica a trafului care alimentat in monofazat poate face in secundar un sistem polifazat. Mergem in directia asta sau ne oprim?
D-ta ai invatat meserie in Romania sau in Canada?
Acum 24 minute, Ion_Bumbu a spus:
Dumneavoastra poate, eu nu.
Cred ca nu eu scriu neinteligibil.
Editat de d2134
Acum 25 minute, Mircea a spus:
Important e sa o inveti, nu unde.
Conteaza foarte mult limba in care inveti anumiti termeni si cum ii folosesti.
In romana din anii '20 -'30 la al treilea electrod al triodei se numea placa. Dupa frantuzescul plaque.
Acum i se spune anod. E exact acelasi lucru. Dar azi daca spui de tensiune de placa se gasesc destui sa te faca prost.
Asa si d-ta, daca am folosit termenul romanesc mai vechi, te-ai gasit sa ma critici. Acum se zice "monofaza cu trei fire" sau "monofaza splitata" (dupa etimologia engleza). Daca ai invatat un pic de electrotehnica in limba romana, poti sa dai un exemplu de text universitar unde se foloseste expresia " monofaza pe trei fire"?
Editat de d2134
Eu sunt convins ca pana la urma te vei descurca si tu.
Si ca sa-ti raspund la intrebarea inutila: cum tu nu inveti despre sistemul electric din Bangladesh, nici bangladesenii nu invata despre cel din România. Ca doar n-o fii buricul pamantului fix sub talpile tale.
Acum 41 minute, Mircea a spus:
Acum 43 minute, Mircea a spus:
Eu cind am facut scoala am invatat despre sistemele din Bangladesh si despre cele din America.
