Propunere schema Single-Ended 300B-XLS
  • Răspunsuri 70
  • THOMAS
    11
  • Remus Ionescu
    8
  • Усилитель
    6
  • merck
Acum 10 minute, valderama a spus:
Cost estimativ 3500 euro două monoblocuri, costisitor (sper sa câștig la LOTO:rade:).
  Pe schema trebuie trecut  6П9 fara П,nu  exista 6П9П,asa stiu eu (!!!!)  ,sau pentru cei cu dare de mana ar merge 6AG7...in rest,sa aveti castg la LOTO!:rade:
Editat de LMOlimpiu
2 hours ago, Remus Ionescu said:
Eu as vrea sa construiesc un SE / EL 300B-XLS / OT Hashimoto H-30 - 3.5 S.
Am vrut sa pun ceva grafice pt OT dar nu am acces.
Am gasit si ceva scheme dar la fel.
Incerc asa: http://www.audiodesignguide.com/my/new300bxls2004/new300bxls.html
Multumesc Domnule Vasile
Construcția și reglajul unui SE cu 300B este peste nivelul mediu. Nu e suficient să ai schema si componentele (chiar transformatorul de iesire). Am ramas uimit de ”apariția” acestui topic!
6 hours ago, valderama said:
Nu am dispoziție pentru o astfel de investiție
Un traf care promite , de la firma englezeasca "Primary Windings " la numai
53 Lire .( varianta la care partea de jos se scufunda in sasiu .) mai este "in picioare ,putin mai scump ca are nevoie de 2 capace ,si cu "schelet ".
http://primarywindings.com/product/kt88_10w/
IMG_20180322_084631411.jpg?resize=768,43
A high quality 10W Single ended output transformer. May be used in any single ended design with a valve having an output impedance of 3500 Ohms, such as a KT88.
Primary
90mA DC current
Multi section winding, for reduced leakage inductance.
Inductance
Inductance 24H at 25Hz.
Leakage inductance 15mH
Bandwidth
Wide bandwidth, 20-30KHz. (-1dB)
Secondary
Output impedance 4,8 and 16 Ohms.
Steel
High quality Grain Orientated M6 0.35mm.
Hand laminated for the best stacking factor, and accuracy.
Winding wire
Double coated Grade 2 enamelled copper wire.
Wound using CNC winders for highly accurate wire placement and turns count.
Layer wound for excellent wind consistency and alignment resulting in reduced leakage inductance.
Connecting wire – stand up only
High quality PVC 600V
Primary : 24AWG UL1015
Secondary : 20 AWG UL1015
Mounting
Available in Frame, Drop through or stand up versions.
10 minutes ago, Усилитель said:
Primary
90mA DC current
In schema din primul post avem 110mA deci nu merge traful indicat de tine. Nici la capitolul putere nu este ok, doar 10W.
Fix sub traful tau era cel pentru 300B (20W) insa la curentul de repaus tot nu corespunde (doar 100mA)
http://primarywindings.com/product/300b_20w_se/
Editat de merck
Da ai dreptate , dar in cazul cand nu vrei sa storci si sa obosesti tubul ,ma gandeam ca 10W ajung , oricum nu e bine de tras la max amplificatorul, si se poate scoate calitate la volum si pret mai mic . Conform tabelului , ar merge 3500 ohm 11 W ,la 60 mA, ma gandeam ca 10 W ajung , ca ultima solutie .( la banii aceia  ,plus ca pe hartie banda de frecvente nu arata rau )
http://www.emissionlabs.com/datasheets/EML300B-XLS.html
Cel de 20W e deja scump...( aproape triplu fata de cel 10W ) La 53 nu iei un OT pt el84 mai rasarit....
Editat de Усилитель
Părerea mea este urmatoarea:
Se pot construi in regim DIY transformatoare de iesire. Sunt useri pe acest forum care au informatiile, miezurile precum și tehnologia necesară pentru a obtine rezultate asemănătoare cu cele de marcă. Putini vor putea face diferența dpdv auditiv. (studiez - citesc -  de vreo 5 ani acest forum, fără a face un cont); mă refer la domnii Bodea Dorin și Lăzăroiu.
Cine doreste să încerce acestă schemă nu are decât! Ea va funcționa fără probleme! Diferentele se vor vedea la măsurători și mai putin auditiv! Reglajele de finețe le face fiecare și nu se spun!
Editat de PlutothePup
adaugare detalii
