Diverse piese/componente radio si TV
Eve
  • Răspunsuri 58
  • Eve
    31
  • alexis1
  • leo 17
  • GMCD
Valabile.
Plus cele de mai jos:
Condensator variabil - https://postimg.cc/gallery/zgjT5CY
o sectiune - 20 RON bucata - https://postimg.cc/tYRm4bJs / verso https://postimg.cc/yDkQ0TFB
2 sectiuni  - 30 RON bucata
3 sectiuni  - 40 RON bucata
https://postimg.cc/9DKxbqp9 / verso https://postimg.cc/TpkNys5C
https://postimg.cc/JsDzVR7C / verso https://postimg.cc/NK3fQZL9
Punte redresoare seleniu  - 30 RON bucata
 - fabr.RFT tip 250/C-400, 20 placute 32/32mm, fara sistem de prindere 165mm -  https://postimg.cc/LqXX5qTp
 - KONVERTA EC240/0.35 DF, 17 placute 43/43mm -  https://postimg.cc/1nbfkPwS
 - 8 placute 10/10cm -  https://postimg.cc/LqXX5qTp - https://postimg.cc/1nbfkPwS
Rezistor reglabil TESLA TR624 - 20 RON bucata - https://postimg.cc/yD6DNkKL
Rezistente pentru statie lipit 24V, 20W - 3 buc 30 RON -  https://postimg.cc/ph0DHs63
Tole E+I 20 - https://postimg.cc/nCjPBz88 grosime pachet 10.5cm - https://postimg.cc/PC1VVRr2 - 100 RON
Valabile urmatoarele:
Radio/recorder (netestate, in starea din poze):
    Radio Soundbox MK2 - 20 RON - https://postimg.cc/nMLLmHvM / https://postimg.cc/tn7CG5XF
                                                             https://postimg.cc/r0fFHbL8 / https://postimg.cc/xqF1yWR5
    Radio Olimpik 402 - 30 RON -  https://postimg.cc/hQtXgWr9  https://postimg.cc/V5frXn8d
    Radio Imula - 30 RON - https://postimg.cc/xcHP0XtG , https://postimg.cc/0zs0r9BT
    Kassettenrecorder ( https://postimg.cc/sMcQV5QH  / verso https://postimg.cc/ph9pY703 ) - 30 RON
    Radio BOSS Japan - 30 RON - https://postimg.cc/YvgqZLcJ
Tranzistor
OC821 - 4 buc 20 RON - https://postimg.cc/p9TzVyfv
AC180 - 5 RON bucata - https://postimg.cc/Wds0K5th
AC187/188 - 10 RON o pereche https://postimg.cc/Wds0K5th
2N3055 - cutie 20 buc 60 RON - https://postimg.cc/jwnfN93k / https://postimg.cc/T58Dc9Z2
Placi
      - radio recuperate
         https://postimg.cc/nCpfmT82 / https://postimg.cc/WDDBVHrN - 20 RON
         https://postimg.cc/HVzD95dg / https://postimg.cc/5Xtc702F / https://postimg.cc/k6KL6RfL - 20 RON
         https://postimg.cc/RWpkjBWp / https://postimg.cc/Lqrr83Bz - 10 RON
      1. cablaj simplu placat - 25 RON - https://postimg.cc/rD6Htz1n / https://postimg.cc/4KsFBMFp
            23.3cm x 8.5cm, grosime de 1mm
            19.8cm x 6.5cm, grosime de 1mm
            15.4cm x 10.3cm, grosime de 1mm
            21cm x 6cm, grosime de 1mm
            18.5cm x 15.4cm, grosime de 1mm
            21.3cm x 17.8cm, grosime de 2mm
      2. cablaj dublu placat - 20 RON - https://postimg.cc/WF4YPZV3 / https://postimg.cc/DW6pDgtH
           31cm x 18.5cm, grosime de 1mm
           22cm x 16.8cm, grosime de 1mm
           19.8cm x 8.3cm, grosime de 1.5mm
           15cm x 10.8cm, grosime de 1mm
      3. cablaj simplu placat - 30 RON - https://postimg.cc/XXzm4sp0 / https://postimg.cc/K1nH7FQZ
        22.5cm x 15.5cm, grosime de 1mm - 4 bucati
        27cm x 18.7cm, grosime de 1mm
     4. textolit
           2mm grosime - 12 placi diferite dimensiuni (lungime intre 22 si 32 cm) - 50 RON - https://postimg.cc/xqChwwjR
           3mm grosime - 30 RON toate (lungime intre 25 si 28.5cm) - https://postimg.cc/V0r7JcdP
           4mm grosime - 20 RON toate (lungime intre 22 si 32 cm) - https://postimg.cc/CB6PMKM4           Lamele - 8 bucati de diferite grosimi (1mm, 2mm si 3mm) - 30 RON - https://postimg.cc/t7YvSFDv
                      (lungime intre 28 si 35 cm, latime intre 4.5 si 6.5cm)
Osciloscop
    - Sonda noua Osciloscop E0100 tip A1, sigilat - 50 RON  https://postimg.cc/grKqn3rv / https://postimg.cc/NLtksdGs
    - Hartie oscilograme  - 40 RON ambele role - https://postimg.cc/N5ncv98c
    - tub 5LO38I (5ЛО38И) - 50 RON - https://postimg.cc/VJ6pbN8c
    - tub 3WP11 cu suport - 100 RON - https://postimg.cc/qt6FjZqb
Tuburi
    - M1409P31 CRT Magnavox cu suport - 100 RON - https://postimg.cc/z3x9Dhsk / https://postimg.cc/B8fz7BFJ / https://postimg.cc/fJk1VLZQ
    - ME1400 Mullard NOS - 4 buc - 80 RON bucata - https://postimg.cc/jwBB7r8g
    - PL83 Tesla - 25 RON buc -  https://postimg.cc/JHcKzwSB
    - 6AU6 - 4 buc. 10 RON buc, SH - https://postimg.cc/K3np333j
Transformatoare (  https://postimg.cc/gallery/DsrSMW6  )
       - toroidal 100VA 50Hz Pr 0-220V Sec 0-12V  - 50 RON - https://postimg.cc/N2R3Krv8
      1 - alimentare tv, cu tot cu montaj - 30 lei - https://postimg.cc/fJfqX5fC
      2 - https://postimg.cc/KKBDy2MY , https://postimg.cc/5YJq4RBS - 30 RON
      3 - https://postimg.cc/JGYqNK8Rhttps://postimg.cc/dZt2dZS7 - 30 RON
      4 - https://postimg.cc/Hr7QQg3t , https://postimg.cc/YhP6G9N9 - 30 RON
      5 - https://postimg.cc/jCZQTvLy , https://postimg.cc/jW0ycFFY - 30 RON
      6,7 - https://postimg.cc/1nywhNSW , https://postimg.cc/V06t5Qdn - 30 RON bucata
       8 - Telefunken CH 714- https://postimg.cc/SJV66JDh , https://postimg.cc/yDdFvsbS - 30 RON
       9 - Transformator de impuls TPI 4-3 - 10 RON bucata - https://postimg.cc/xNy1pnF8
      10 - traf 78070 - 25 RON - https://postimg.cc/Wt7QXv8C
      11.  din tole 10mm, grosime 29mm https://postimg.cc/z3Mg7dSC / https://postimg.cc/9RwwGC76  - 30 RON
Tole
   E8 (E+I) - grosime de 9cm aprox. 800gr - 30 RON - https://postimg.cc/XX2XfHgh / https://postimg.cc/JHh0wZRP
   E19 (E+1) - grosime 2.8 cm - 20 RON - https://postimg.cc/XByK79Ly / https://postimg.cc/Ty35knzv
   E20 (E+I) https://postimg.cc/nCjPBz88 grosime pachet 10.5cm - https://postimg.cc/PC1VVRr2 - 100 RON
Potentiometru
   - multitura Midori HP-10B, 100 Ohm 10 pozitii cu switch - 50 RON bucata -  https://postimg.cc/5YQ3qCbm
Rezistente
     - 40 RON https://postimg.cc/tsN08v14
     - Toral 24Ω 16W - 10 RON bucata (disponibile 10) - https://postimg.cc/rKvFqHFG
     - Remix 6.8kΩ si 12kΩ - 5 RON bucata, stoc 20 bucati - https://postimg.cc/0zvS9RNq
     - pentru statie lipit 24V, 20W - 3 buc 30 RON -  https://postimg.cc/ph0DHs63
Carti ( https://postimg.cc/gallery/0vwfB1Q )
Colectia Radio 13 buc - 50 RON https://postimg.cc/87zwQfWN
   - Colectia Radio si Televiziune - 7 buc - 30 RON - https://postimg.cc/6y0zmf8M
   - 20 carti la 70 RON - Colectia Radio si Televiziune -  https://postimg.cc/JG8RWZfh
   - Catalog Noi tuburi  electronice si tranzistoare - AL. POPOVICI - 25 RON - https://postimg.cc/fJthKVzV
   - Manual de tuburi si circuite electronice - Tudor Tanasescu Vol2 si 3 - 25 RON buc- https://postimg.cc/7JPZhw0g
Diverse:
   - Set motorase - 50 RON - https://postimg.cc/QHy6dcnf
    - Antena 10 RON - https://postimg.cc/SXNpb6XD
    - Amplificatoare FIF noi C10 - 20 RON bucata - https://postimg.cc/rRTJ7Jsp - 5 disponibile
    - 6 telecomenzi vechi - 15 RON - https://postimg.cc/FYVgL2t7  (una cu capac baterii lipsa)
    - Radioator aluminiu lungime 74cm,latime 11.5 cm - 50 RON https://postimg.cc/bD87TXrW
    - Socluri novale - 3 RON bucata - https://postimg.cc/GBWQ9tj1
    - Tabla aluminiu diferite dimensiuni
        - 40 RON - https://postimg.cc/3WKx7Kb2
        - 40 RON - https://postimg.cc/8s7y5qMT
        - 25 RON - https://postimg.cc/Rq2gnXLK
        - 25 RON carcasa - https://postimg.cc/mtM83Cmq , https://postimg.cc/gxW4gj50
    - Diamant pentru taiat geamuri/sticla - 30 RON - https://postimg.cc/fkvr9jqj
    - Pistol de insurubat/bormasina - 70 RON -  https://postimg.cc/Wtqt24fP / https://postimg.cc/Czj1qQgP
    - Mini-switch 2A 250 V, 6 pini - 8 bucati la 30 RON - https://postimg.cc/jWzNLxhZ
    - Claviaturi vechi - 60 RON - https://postimg.cc/D4htymhZ
    - Dymo 1740 nou - aparat pentru etichetat din anii '70 - 60 RON - https://postimg.cc/RNFcXzMZ
    - Agenda/mapa noua Radelkis - 60 RON - https://postimg.cc/r0k1J0pB / https://postimg.cc/bD9QFyDs
   - Radiatoare mici cu diferite componente - BStB0240, BD135/136, BD234, 2x BD237, 2x BF458, SM104, Tesla KU612        -  30 RON toate - https://postimg.cc/w36rd7HL
 - Role magnetofon 127 mm cu muzica din anii '60 - 60 RON - https://postimg.cc/mh85ZB2q
 - Casete audio vechi (o parte cred ca sunt neinregistrate) - 14 bucati - 60 RON - https://postimg.cc/tYcvPk6N
 - Rigla de calcul - 20 RON - https://postimg.cc/gnChhtzp / https://postimg.cc/FY0LVbzL
 - Comutatoare diferite modele - 40 RON - https://postimg.cc/bshnDmx3
 - set lame burghiu lemn, 8 dimensiuni - 25 RON - https://postimg.cc/w1tRnngx
 - Rindea faltuit, latime 20 mm - 12 RON - https://postimg.cc/zHqFSWhn / https://postimg.cc/vDQP9k1T
Comanda minima 50 RON - posta sau curier cu plata ramburs, fara predare personala.
Mai multe detalii si poze in PM.
Acum 1 oră, UDAR a spus:
Ce grosime are tabla ?
Multumesc.
Buna ziua,
Sunt de 1mm, 2mm si cateva de 3mm grosime:
  - 7.7cm/6.6cm -> grosime 2mm
  - 8.6cm/8 -> grosime 1mm
  - 8.4/9.4 -> 1mm
  - 10cm/13.1 -> grosime 1mm
  - 13cm/13 -> grosime 2mm
  - 15.7/8.4 -> grosime 2mm
  - 17.5/9.3 -> grosime 2mm
  - 20/6.7 -> 2mm
  - 20/13.8 -> 2mm
  - 15/9.2 -> 3mm
https://postimg.cc/Rq2gnXLK - tabla e de 2mm, tija de 43cm/2.4 si grosime 12mm
https://postimg.cc/8s7y5qMT  - coltarele de 1 si 2mm
27cm/26 , tabla gaurita -> 1mm
52cm/6, 51/5, 42/6.2, 11/11  -> 2mm
35/6 , 16.4/4, 16.8/3.5 -> 3mm
Tot ce a fost rezervat mai sus a fost trimis, restul sunt valabile.
Se adauga:
Instrument UM-4B - 40 RON  https://postimg.cc/xXVqd4LD
Tranzistor - https://postimg.cc/wRMtk13Z
XK830 3 buc - 5 RON toate
BCY91 TO-18 - 8 buc - 5 RON bucata
4 buc BC212 + 3 buc 212A = 5 RON
4 buc BC182 + 3 BC182A + un BC182B = 10 RON
Placi radio:
- prima posibil sa fie de la radio Mamaia 4 - https://postimg.cc/rDCHSsWq - 30 RON
- Eurotec EU-5902 - 30 RON https://postimg.cc/D8DGBPrg / https://postimg.cc/t7BWVj78
- set 20 RON - https://postimg.cc/G9xz7Vtj
Socluri - 25 RON - https://postimg.cc/mcWHGZ61
Acum 14 minute, leo 17 a spus:
Radio boss in ce stare este ?
Buna seara,
Nu a mai fost pornit/testat de mult timp. O sa il iau maine seara si revin in PM cu detalii si alte poze.
