Diverse carti 2 lei bucata/Suporți trafo toroidal
adydep
*Suporti trafo toroidal,diametru aprox. 7cm,2 bucati,10 lei ambele
https://postimg.cc/bDsV0cW7
*Carti:
https://postimg.cc/SJB0gKMs
https://postimg.cc/n99RmvT1
https://postimg.cc/SjntHhqz
https://postimg.cc/XB9K3xQt
https://postimg.cc/JDDcYRJr
https://postimg.cc/ygMhw2XF
https://postimg.cc/k2H21KyS
https://postimg.cc/ygmycsZk
https://postimg.cc/PCJycgBR
https://postimg.cc/3d4Wc9tZ
https://postimg.cc/t71XqJFq
https://postimg.cc/njj6JsgN
https://postimg.cc/fkv6hhrz
https://postimg.cc/fJpCG2DW
https://postimg.cc/vx18CHtm
https://postimg.cc/HJ4t7T5j
https://postimg.cc/8FDRGx3G
https://postimg.cc/8F169MJP
https://postimg.cc/30yp9hyX
https://postimg.cc/V5bd7DGW
https://postimg.cc/7JgPqtjv
https://postimg.cc/YGLqsC3C
https://postimg.cc/8f8PQgKB
https://postimg.cc/bG9VQxbx
https://postimg.cc/7bd9Jsdv
https://postimg.cc/xNcsDBZ5
https://postimg.cc/4KgF7LK4
https://postimg.cc/BXFgT5fj
https://postimg.cc/9rydRWyT
https://postimg.cc/8jgWVqxC
https://postimg.cc/fVw9VYzn
https://postimg.cc/VJDbn5vS
https://postimg.cc/QBCKbsKf
https://postimg.cc/pyF842G7
https://postimg.cc/BPHKKgPs
https://postimg.cc/Wtzj1zLW
https://postimg.cc/LJBGTFFg
https://postimg.cc/304PCy33
https://postimg.cc/WFKy32gC
https://postimg.cc/cKx2kkd9
https://postimg.cc/pyh7SFtH
https://postimg.cc/WFtKTDF0
https://postimg.cc/dZr5VGqZ
https://postimg.cc/3dLtJrhB
https://postimg.cc/ykNT5qRS
https://postimg.cc/vDhz384s
https://postimg.cc/JtMxNH4x
https://postimg.cc/3k4F8gn8
https://postimg.cc/nCw1fdKS
https://postimg.cc/nC5qPXZ6
https://postimg.cc/k23BSK7X
https://postimg.cc/ftrbR0Hs
https://postimg.cc/bDJJPR9L
https://postimg.cc/RqWFbXFZ
https://postimg.cc/py3TNzhY
https://postimg.cc/T553LYSD
https://postimg.cc/CB3V2CPR
https://postimg.cc/qg2fR3DG
https://postimg.cc/sMDbw0jn
Editat de adydep
  • Răspunsuri 27
  • adydep
    18
  • deneinvins
  • floob
  • hamatdumitru
Acum 4 ore, adydep a spus:
Vreau eu suportii. Stiti pentru ce trafo imi trebuie. :da
Va rog sa-i puneti de-o parte, poate mai scoateti ceva la vanzare si completam.
Editat de zvonacfirst
-suportii trafo si catalog transformatoare linii 1 si 2-retinute,restul valabile.
-se adauga cele de mai jos:
*placa recuperata dintr-o combina Sony,pret 10 lei
https://postimg.cc/q6R7g804
https://postimg.cc/Z0hF0n13
*placa recuperata dintr-o boxa activa,finalii TDA2030,pret 15 lei
https://postimg.cc/fk2LpgjL
*placa recuperata dintr-o boxa activa,contine 2 buc 4558 si 2 buc 4053,pret 10 lei
https://postimg.cc/4KgNpCZ8
*boxe cu dimensiuni aprox. de 27x6x4cm,difuzoarele sunt Samsung 8 ohm/5W,pret 20 lei perechea
https://postimg.cc/FdPrt7Sq
https://postimg.cc/BLZSwxjH
*transformator cu sectiunea aprox. 15 cmp (2,5x6cm),dimensiuni exterioare 7x7,5 cm,inaltime pachet tole 6cm
-primar 230V
-secundar de forta 2x30V,1x12V,1x12,6V ,2x2,5v
greutate aprox.2,5kg,pret 60 lei
https://postimg.cc/dZBdLqYp
https://postimg.cc/FYnyysLQ
https://postimg.cc/GB8kqwFT
*modul final audio recuperat din combina Sony- STK402-070S (stk original),grosime talpa radiator aprox. 6mm,dimensiuni radiator 10x17cm,pret 40 lei
https://postimg.cc/0M771YH8
https://postimg.cc/H8HXYrfb
https://postimg.cc/SXBcPTdT
*lot tranzistori originali,2 bucati D2061 si 3bucati B1370,se vand impreuna cu placa din poza recuperata dintr-o combina AIWA,pret 12 lei
https://postimg.cc/CdBmKVMD
*lot 9 difuzoare ,pret 15 lei tot lotul
https://postimg.cc/w7D2hcmj
https://postimg.cc/sBH4VTtw
Editat de adydep
Acum 7 minute, floob a spus:
Buna seara,
As dori de la dvs. urmatoarele:
Dupa confirmare, va trimit MP.
O seara buna!
Buna seara,
Placa recuperata dintr-o boxa activa cu TDA2030 si cealalta placa cu  2 buc 4558 si 2 buc 4053,mi-au fost cerute mai devreme de un coleg in privat,cartile pe care le doriti sunt disponibile
Cele de mai jos valabile:
*Carti au mai ramas doar cele la care aveam dubluri,sau nu s-au dat:
*transformator cu sectiunea aprox. 15 cmp (2,5x6cm ,aprox 225W),dimensiuni exterioare 7x7,5 cm,inaltime pachet tole 6cm
-primar 230V
-secundar de forta 2x30V, restul 1x12V,1x12,6V ,2x2,5v
1.placa textolit cu grosime de4mm,dimensiuni 13cm X 32cm (poza 1)si placuța textolit cu cose sisuruburi,dimensiuni 11cm X 4,5cm (pozele 2 si 3),15 lei ambele:
 https://postimg.cc/bsdmqk6x
https://postimg.cc/KK7N0Nz2
https://postimg.cc/dkHGfScz
2.rezistente rusesti,40 bucati de 160kOhm si 120 bucati de 12kOhm (diametru 4mm,lungime 25 mm)-cred ca 2W,pret 15 lei toate (160 bucati)
https://postimg.cc/BjgrstgR
https://postimg.cc/XGy1Zvfj
3.variator de 800W,pret 10 lei
https://postimg.cc/hQWyVqs9
4.boxe active pc Serioux - pop251b  ,pret 30 lei
https://postimg.cc/SjRj3bzm
https://postimg.cc/NyXk1rBP
https://postimg.cc/zyKy7wHW
5.pistol lipit plastic,pret  15 lei
https://postimg.cc/QFN8tQ36
https://postimg.cc/75rzQQS5
https://postimg.cc/svTFTbkc
https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD
7.pereche difuzoare rusesti, 0,5W/8 ohm,pret 8 lei perechea
https://postimg.cc/CZzwy6vT
https://postimg.cc/CzSYMKv4
8.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 5 leiperechea
https://postimg.cc/bSNZtRyz
https://postimg.cc/23KkGYTd
https://postimg.cc/Lq22586S
9.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea
https://postimg.cc/qNQZcJx4
https://postimg.cc/yg3QzF48
https://postimg.cc/PNZ33zQ6
Componente noi:
-15nF/1600V,2 lei/buc,disponibil 5 buc
https://postimg.cc/Xr9DPPJ8
-TDA8177F (provenienta Cristronic),disponibil 3 buc,10 lei/buc
https://postimg.cc/S2n6BXdh
-BU508DF,disponibil 3 buc,pret 4 lei/buc
https://postimg.cc/KkCPxZpg
-led COB 20W,dimens. 52*56mm, 30-33V,pret 20 lei buc
https://postimg.cc/rRWSpv7Z
-STK463,20 lei buc
https://postimg.cc/z3Rwpg3w
-MC44608,(provenienta Pâncota),disponibil 2 buc,pret 10 lei/buc
https://postimg.cc/xNT2j2kn
-TDA3653B ,disponibil 10 buc,pret 5 lei/buc
https://postimg.cc/nCg6g71H
-punte KBPC3510,pret 10 lei
https://postimg.cc/5HdWYvHP
-TDA11145/PS/N1/3,pret 25 lei
https://postimg.cc/svxrt3dJ
-TDA8362,pret 20 lei/buc,disponibil 3 buc
https://postimg.cc/pppwskzG
-STTH30R03CG,(provenienta Pâncota)dioda invertoare sudura 300V,2x15A,pret 15 lei/buc,disponibil 4 buc
https://postimg.cc/VJbck4NVJbck4N
*Lot 5 curele diverse pentru magnetofon,una cu sectiune triunghiulara,una cu sectiune rotunda,trei cu sectiune patrata,pret 10 lei tot lotul
https://postimg.cc/bdNLrWn8
https://postimg.cc/zbwMNg4j
*Set suporti de perete pentru televizor (LCD,LED PLASMA) foarte rezistenti,reglabili,distanta de la perete aprox 8cm,lungime totala aprox. 28 cm,pret 20 lei
 https://postimg.cc/8f5bYfGs
https://postimg.cc/1nMHMcLL
*lot piese rusești compus din
     -2 potentiometre capsulate de 15Kohm/0,5W
     -2 potentiometre capsulate  de 22Kohm/0,5W
     -4 potentiometre 4,7Kohm
     -4 diode KD202K fixate pe suport metalic cu cilindrii izolatori si saibe de textolit
     -3 mufe stereo pentru jack cu piulita de plastic
     -2 mufe DIN cu 5 pini
     -2 intrerupatoare cu retinere si 6 pini
     -3 intrerupatoare de retea
     -un suport metalic cu intrerupator de retea,priza si soclu de siguranta
    -fire de legatura,cablu cu stecher
   pret 30 lei tot lotul
        https://postimg.cc/V0qPQKmY
       https://postimg.cc/V5n8CkM3
      https://postimg.cc/jLvdDjYR
      https://postimg.cc/gnx9yyxt
      https://postimg.cc/hhPRvRcB
     https://postimg.cc/LhCKZQ8Z
      https://postimg.cc/vgXRh37k
*tot ce se vede in urmatoarele 3 poze,20 lei
https://postimg.cc/7GsvSTh1  un rest de modul ce contine in principal 14 circuite integrate 555 de productie RDG
https://postimg.cc/14X1sM7v un modul descompletat din tv Philips,contine TDA3803A ,HEF4066BP,TBA120 x2
https://postimg.cc/nCQ8QrJ7 un rest de modul din tv Philips,contine TDA1524A,TDA3810,HEP4066BP
Editat de adydep
