Dan Morar Postat Octombrie 7, 2020 Partajează Postat Octombrie 7, 2020 (editat) Pentru un bun amic Tub ELL80 sau ECLL 800 Identical 6HU8 = ELL80 Interesat de aceste tuburi Multumesc QQE03/12 is indeed a popular substitute for ELL80, but socket connections are different and electrical parameters aren't the same. A perfect substitute on most instances is the ECLL800. It can be exchanged for the ELL80 with a single rewire of pin 1 at the socket or a tube adapter. Editat Octombrie 7, 2020 de Dan Morar Link spre comentariu
Усилитель Postat Octombrie 8, 2020 Partajează Postat Octombrie 8, 2020 ELL80 si ECLL800 nu sunt chiar la fel ,una are o trioda in plus ,si interesant ca are g1 comuna cu una din pentode.....pinul 1 are rol diferit la cele 2......pt diy ,no problem, sau atunci daca este loc se poate folosi si 2 buc EL95. Daca este bun QQE2/12 atunci se poate pune echivalentul rusesc GU17 , care se gaseste si este ieftin. The GU-17 beam-power double tetrode is used for generation of power amplification at frequencies up to 250mHz in RF equipment. Equivalent to the QQE03/12, CV2798. GENERAL Cathode: indirectly heated, oxide coated. Envelope: glass, miniature. Height: at most 80mm. Diameter: at most 22.5mm. Mass: at most 25g. OPERATING ENVIRONMENTAL CONDITIONS Vibration loads: frequencies 20-600Hz, acceleration 59m/s^2. Multiple impacts with acceleration: 118m/s^2. Single impacts with acceleration: 490m/s^2. Linear loads with acceleration: 294m/s^2. Relative humidity at up to +40C: 98%. BASIC DATA Electrical Parameters Heater voltage: 6.3V. Heater current: 0.72-0.88A. Mutual conductance (at anode and grid 2 voltages 200V, grid 1 voltage -16V of first tetrode, grid 1 voltage -100V of 2nd tetrode): 1.6-3.3mA/V. Anode current (at anode and grid 2 voltage 200V, grid 1 voltage -16V of 1 st tetrode, grid 1 voltage -100V of 2nd tetrode): 10-30mA. Interelectrode capacitance: input 5.2-7.8pF, output 2.2-3.2pF, transfer, at most 0.1s. Warm up time, at most 40s. Output power (at anode voltage 300V, grid 2 voltage 200V, voltage - 80V of grids 1), at least 11W. Output power over 400 h of service, at least 8.8W. Limit Operating Values Healer voltage: with parallel-connected heater 5.7-7V, with series-connected heater 11-14V. Anode voltage: 400V. Anode voltage at the instant of switching on: 450V. Voltage between cathode and heater: -150V to +150V. Cathode current: 100mA. Dissipation: anodes 12W, grid 2 3W, grid 1 0.5W. Operating frequency: 250mHz; Envelope temperature: 260C. Link spre comentariu
SHONELU Postat Octombrie 8, 2020 Partajează Postat Octombrie 8, 2020 Salut! Am un ELL80, este o lampa foarte rara, pretul este 260 de lei plata pe cont. Daca te intereseaza lasa-mi mesaj. Link spre comentariu
Dan Morar Postat Octombrie 8, 2020 Autor Partajează Postat Octombrie 8, 2020 Acum 22 minute, SHONELU a spus: Salut! Am un ELL80, este o lampa foarte rara, pretul este 260 de lei plata pe cont. Daca te intereseaza lasa-mi mesaj. Buna , multumesc, transmit mai departe partii interesate Link spre comentariu
