Electronice diverse
adydep
1.placa textolit cu grosime de 4 mm,dimensiuni 13cm X 32cm (poza 1)si placuța textolit cu cose si suruburi,dimensiuni 11cm X 4,5cm (pozele 2 si 3),15 lei ambele:
 https://postimg.cc/bsdmqk6x
https://postimg.cc/KK7N0Nz2
https://postimg.cc/dkHGfScz
2.rezistente rusesti,40 bucati de 160kOhm si 120 bucati de 12kOhm (diametru 4mm,lungime 25 mm)-cred ca 2W,pret 15 lei toate (160 bucati)
https://postimg.cc/BjgrstgR
https://postimg.cc/XGy1Zvfj
3.variator de 800W,pret 10 lei
https://postimg.cc/hQWyVqs9
4.boxe active pc Serioux - pop251b  ,pret 30 lei
https://postimg.cc/SjRj3bzm
https://postimg.cc/NyXk1rBP
https://postimg.cc/zyKy7wHW
5.pistol lipit plastic,pret  15 lei
https://postimg.cc/QFN8tQ36
https://postimg.cc/75rzQQS5
https://postimg.cc/svTFTbkc
https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD
6.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,30 lei ambele
https://postimg.cc/18DT6QZK
https://postimg.cc/wtZ0b4HB
https://postimg.cc/RqzjSq5Z
7.pereche difuzoare rusesti, 0,5W/8 ohm,pret 8 lei perechea
https://postimg.cc/CZzwy6vT
https://postimg.cc/CzSYMKv4
8.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 5 lei perechea
https://postimg.cc/bSNZtRyz
https://postimg.cc/23KkGYTd
https://postimg.cc/Lq22586S
9.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea
https://postimg.cc/qNQZcJx4
https://postimg.cc/yg3QzF48
https://postimg.cc/PNZ33zQ6
  • Răspunsuri 13
  • adydep
    13
  • imreberes
Au mai rămas:
1.placa textolit cu grosime de 4mm,dimensiuni 13cm X 32cm (poza 1)si placuța textolit cu cose si suruburi,dimensiuni 11cm X 4,5cm (pozele 2 si 3),15 lei ambele:
6.
8.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 5 leiperechea
Componente noi:
-15nF/1600V,2 lei/buc,disponibil 5 buc
https://postimg.cc/Xr9DPPJ8
-TDA8177F (provenienta Cristronic),disponibil 3 buc,10 lei/buc
https://postimg.cc/S2n6BXdh
-BU508DF,disponibil 3 buc,pret 4 lei/buc
https://postimg.cc/KkCPxZpg
-led COB 20W,dimens. 52*56mm, 30-33V,pret 20 lei buc
https://postimg.cc/rRWSpv7Z
-STK463,20 lei buc
https://postimg.cc/z3Rwpg3w
-MC44608,(provenienta Pâncota),disponibil 2 buc,pret 10 lei/buc
https://postimg.cc/xNT2j2kn
-TDA3653B ,disponibil 10 buc,pret 5 lei/buc
https://postimg.cc/nCg6g71H
-punte KBPC3510,pret 10 lei
https://postimg.cc/5HdWYvHP
-TDA11145/PS/N1/3,pret 25 lei
https://postimg.cc/svxrt3dJ
-TDA8362,pret 20 lei/buc,disponibil 3 buc
https://postimg.cc/pppwskzG
-STTH30R03CG,(provenienta Pâncota)dioda invertoare sudura 300V,2x15A,pret 15 lei/buc,disponibil 4 buc
https://postimg.cc/VJbck4Nr
*transformator cu sectiunea aprox. 15 cmp (2,5x6cm),dimensiuni exterioare 7x7,5 cm,inaltime pachet tole 6cm
-primar 230V
-secundar de forta 2x30V,1x12V,1x12,6V ,2x2,5v
greutate aprox.2,5kg,pret 60 lei
https://postimg.cc/dZBdLqYp
https://postimg.cc/FYnyysLQ
https://postimg.cc/GB8kqwFT
*modul final audio STK402-070S (stk original),grosime talpa radiator aprox. 6mm,dimensiuni radiator 10x17cm,pret 40 lei
https://postimg.cc/0M771YH8
https://postimg.cc/H8HXYrfb
https://postimg.cc/SXBcPTdT
Cele de mai jos valabile:
1.placa textolit cu grosime de4mm,dimensiuni 13cm X 32cm (poza 1)si placuța textolit cu cose sisuruburi,dimensiuni 11cm X 4,5cm (pozele 2 si 3),15 lei ambele:
Componente noi:
-STK463,20 lei buc
https://postimg.cc/VJbck4NVJbck4N
-primar 230V
*lot tranzistori originali,2 bucati D2061 si 3bucati B1370,se vand impreuna cu placa din poza recuperata dintr-o combina AIWA,pret 12 lei
https://postimg.cc/CdBmKVMD
*lot 9 difuzoare ,pret 15 lei tot lotul
https://postimg.cc/w7D2hcmj
https://postimg.cc/sBH4VTtw
