Florinel TV Postat August 15, 2020 Partajează Postat August 15, 2020 Salutare , stie cineva cum se intra in service la acest tv , Nikkei NK16LD201 MB.HK-T.SP9100V03, am incercat cu mai multe coduri si nu vrea, cu input 0000 intra intr-un fel de service si de acolo pot selecta modul hotel on / of coduri incercate Menu+1147 Menu+1185 Menu+1183 Menu+2580 Menu+1187 Menu+7050 Menu+8202 Menu+7343 Menu+2008 Menu+1999 Menu+0000 Menu+1167 Menu+1199 Menu+1234 Menu+2387 Menu+8893 Menu+2383 Source+3138 Source+2580 Source+2585 Source+7342 Source+2583 Menu+4725 Source+2283 Source+2285 Source+3195 Source+3137 Source+0000 Daca stie cineva il rog sa spuna , multumesc Link spre comentariu
iuliantv Postat August 15, 2020 Partajează Postat August 15, 2020 menu 6483 clasic crt ? https://www.amwajsat.net/showthread.php?t=1118 Link spre comentariu
Florinel TV Postat August 15, 2020 Autor Partajează Postat August 15, 2020 Acum 4 ore, iuliantv a spus: menu 6483 clasic crt ? https://www.amwajsat.net/showthread.php?t=1118 Multumesc de raspuns, am incercat si de acolo toate codurile, dar nu vrea sa intre in service Link spre comentariu
Costica Tv Postat August 15, 2020 Partajează Postat August 15, 2020 (editat) 45 minutes ago, Florinel TV said: Multumesc de raspuns, am incercat si de acolo toate codurile, dar nu vrea sa intre in service E chinezaraia dracului tv-ul asta, am sapat si eu pe net vre-o 2 ore....nu am gasit nimic legat de menu service la acest sasiu HK-T.SP9100V03.. Editat August 15, 2020 de Costica Tv Link spre comentariu
sorintv Postat August 15, 2020 Partajează Postat August 15, 2020 Akai AKTV253LED are MB HK-T.SP9100V03 Link spre comentariu
Costica Tv Postat August 15, 2020 Partajează Postat August 15, 2020 13 minutes ago, sorintv said: Akai AKTV253LED are MB HK-T.SP9100V03 Am cautat si eu dupa toate "marcile" de tv care folosesc acest sasiu si nu am gasit nimic....probabil ca tu ai sapat mai mult...asta inseamna ajutor cu adevarat, adica pierzi timp ca sa ajuti pe cine merita si la randul tau vei primi si tu ajutor........ Link spre comentariu
Florinel TV Postat August 15, 2020 Autor Partajează Postat August 15, 2020 Acum 45 minute, sorintv a spus: Akai AKTV253LED are MB HK-T.SP9100V03 Nu merge cu nici o combinatie, nu merge nici cu meniu 1979 si nici cu meniu 8202, am incercat si asa , oprit tv apasat pornire de pe telecomanda apoi apasat meniu 8202 si tot nu intra in service Link spre comentariu
Costica Tv Postat August 15, 2020 Partajează Postat August 15, 2020 43 minutes ago, Florinel TV said: Nu merge cu nici o combinatie, nu merge nici cu meniu 1979 si nici cu meniu 8202, am incercat si asa , oprit tv apasat pornire de pe telecomanda apoi apasat meniu 8202 si tot nu intra in service Florine daca nu se poate intra in service....spune ce defect are tv-ul poate are cineva softul original, eu am cont la arabi si poate gasesc acolo softul care iti trebuie.... Link spre comentariu
iuliantv Postat August 15, 2020 Partajează Postat August 15, 2020 ps sa nu patesti ca mine,sa ai vreo telecomanda programata si sa faca alte cifre sau functii tastele 0.1.........9 ,eu mi-am dat seama repede ca stiam ca trebuia sa mearga cu menu 1147,bineanteles era alt tv si placa,deci verifica fiecare tasta in parte sa faca cifrele corect 1 Link spre comentariu
Florinel TV Postat August 15, 2020 Autor Partajează Postat August 15, 2020 Da am RCW programabila, toate tastele merg corect 0........9, poate din aceasta cauza nu vrea sa intre in service, ca defect am schimbat bareta de leduri si vreau sa scad tensiunea din service Link spre comentariu
Costica Tv Postat August 15, 2020 Partajează Postat August 15, 2020 (editat) 1 hour ago, Florinel TV said: Da am RCW programabila, toate tastele merg corect 0........9, poate din aceasta cauza nu vrea sa intre in service, ca defect am schimbat bareta de leduri si vreau sa scad tensiunea din service Florine pana la urma s-ar putea sa gasesti intrarea in service, dar nu se stie sigur daca are setari de backlight.....mai bine reduci curentul pe leduri cu metoda clasica din rezistentele tranzistorului driver led....cel mai bine dupa ce umbli la rezistentele de limitare, e sa ai un clampmetru sa masori curentul fara sa intrerupi circuitul....eu dupa ce am scos 4 rezistente din 6 la un LG, a scazut tensiunea de la 117v (max) la 105v ma gandeam in sinea mea ca am scazut putin din tensiune, dar spre surprinderea mea cand am pus clampmetru pe unul din firele care alimenteaza baretele, am vazut ca in loc de 250mA consum, am 150mA, adica asta inseamna ca am redus curentul mai mult decat suficient si ledurile luminau aproape la aceiasi intensitate..., clampmetru il mai imprumut cand si cand de la un coleg pana m-oi hotara sa sparg banca de NEAJUNSURI ca sa cumpar si eu unul.... Asta e clampmetru care masoara si curent continu.....https://www.okazii.ro/clampmetru-digital-100a-ut210e-uni-t-a201790315 Editat August 15, 2020 de Costica Tv Link spre comentariu
Florinel TV Postat August 15, 2020 Autor Partajează Postat August 15, 2020 Eu credeam ca imi dai codul de intrare in service Link spre comentariu
Costica Tv Postat August 15, 2020 Partajează Postat August 15, 2020 3 minutes ago, Florinel TV said: Eu credeam ca imi dai codul de intrare in service Daca stiam iti spune-am cu siguranta, daca tu nu vrei sa faci cum am spus eu mai sus, poate e util pentru alti....oricum in oricare din situati e foarte bun sa ai un cleste ampermetric...... Link spre comentariu
Florinel TV Postat August 15, 2020 Autor Partajează Postat August 15, 2020 In meniu nu pot sa setez lumina plus minus, pot doar sa schimb Dinamic , Standard etc. si din aceasta cauza vreau sa intru in service sa vad cei acolo Link spre comentariu
GOLOGAN Postat August 15, 2020 Partajează Postat August 15, 2020 S-a mai spus pe forum de nenumărate ori hard este sfânt. Software la un update , reinscriere de memorie curent-ul pe leduri va fi la fel. 2 Link spre comentariu
