adydep Postat Septembrie 7, 2020 Autor Partajează Postat Septembrie 7, 2020 Negociabile,au mai ramas doar cele 8 repere de mai jos,100 lei pentru cine le cumpara pe toate ca sa inchid ”taraba”. 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 5.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 6.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 7.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 8.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 Link spre comentariu
adydep Postat Septembrie 8, 2020 Autor Partajează Postat Septembrie 8, 2020 Up,negociabile. Link spre comentariu
adydep Postat Septembrie 10, 2020 Autor Partajează Postat Septembrie 10, 2020 Negociabile,au mai ramas doar cele 8 repere de mai jos,100 lei pentru cine le cumpara pe toate ca sa inchid ”taraba”. 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 5.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 6.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 7.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 8.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 Link spre comentariu
adydep Postat Septembrie 11, 2020 Autor Partajează Postat Septembrie 11, 2020 Up,negociabile. Link spre comentariu
adydep Postat Septembrie 12, 2020 Autor Partajează Postat Septembrie 12, 2020 Up. Link spre comentariu
adydep Postat Septembrie 13, 2020 Autor Partajează Postat Septembrie 13, 2020 La 10.09.2020 la 20:30, adydep a spus: Negociabile,au mai ramas doar cele 8 repere de mai jos,100 lei pentru cine le cumpara pe toate ca sa inchid ”taraba”. 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 5.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 6.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 7.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 8.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 Link spre comentariu
adydep Postat Septembrie 14, 2020 Autor Partajează Postat Septembrie 14, 2020 Negociabile,au mai ramas doar cele 8 repere de mai jos,100 lei pentru cine le cumpara pe toate ca sa inchid ”taraba”. 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 5.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 6.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 7.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 8.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 Link spre comentariu
adydep Postat Septembrie 15, 2020 Autor Partajează Postat Septembrie 15, 2020 Up. Link spre comentariu
adydep Postat Septembrie 16, 2020 Autor Partajează Postat Septembrie 16, 2020 Up. Link spre comentariu
adydep Postat Septembrie 17, 2020 Autor Partajează Postat Septembrie 17, 2020 Negociabile,au mai ramas doar cele 8 repere de mai jos,100 lei pentru cine le cumpara pe toate ca sa inchid ”taraba”. 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 5.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 6.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 7.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 8.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 Link spre comentariu
adydep Postat Septembrie 18, 2020 Autor Partajează Postat Septembrie 18, 2020 Negociabile,au mai ramas doar cele 8 repere de mai jos,100 lei pentru cine le cumpara pe toate ca sa inchid ”taraba”. 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 5.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 6.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 7.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 8.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 Link spre comentariu
adydep Postat Septembrie 19, 2020 Autor Partajează Postat Septembrie 19, 2020 Up. Link spre comentariu
adydep Postat Septembrie 20, 2020 Autor Partajează Postat Septembrie 20, 2020 Up,foarte negociabile!!! 1.boxe active pc Serioux - pop251b ,pret 30 lei https://postimg.cc/SjRj3bzm https://postimg.cc/NyXk1rBP https://postimg.cc/zyKy7wHW 2.pistol lipit plastic,pret 25 lei https://postimg.cc/QFN8tQ36 https://postimg.cc/75rzQQS5 https://postimg.cc/svTFTbkc https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.dedeman.ro%2Fro%2Fpistol-de-lipit-cu-baghete-de-adeziv-steinel-gluematic-3002-333317-200-w%2Fp%2F1021211&psig=AOvVaw0gpYhx86qaYWs_uFx-Ey1K&ust=1594586618424000&source=images&cd=vfe&ved=0CA0QjhxqFwoTCMjVuZuIxuoCFQAAAAAdAAAAABAD 3.ondulator profesional Wella Pro Curl,pret 50 lei https://postimg.cc/5Q9HfQFL https://postimg.cc/jw4wV4CR https://postimg.cc/9zcwdKN0 https://postimg.cc/mt8Y1BLT https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiAzLSh7sDqAhWL4XcKHRQBDXAYABAEGgJlZg&ohost=www.google.com&cid=CAESQOD2QfX-_vFL-aahdTHY5K79XOMcvYdiIp2UHC2BUha4eSGBAB9Wk58Xg65RQFbbRkM3fAoR9mUJKtQZMMO5aQ8&sig=AOD64_1KbI4I8uUO2jEf7M2-w5UPDVgCxA&ctype=5&q=&ved=2ahUKEwjBvqyh7sDqAhULy6QKHcunDmUQ9aACegQICxA8&adurl= 4.doua multimetre functionale,la cel galben nu am testere,se dau fara baterii,40 lei ambele https://postimg.cc/18DT6QZK https://postimg.cc/wtZ0b4HB https://postimg.cc/RqzjSq5Z 5.pereche difuzoare rusesti, 0,5W/8 ohm,pret 15 lei perechea https://postimg.cc/CZzwy6vT https://postimg.cc/CzSYMKv4 6.pereche difuzoare cu diametrul 57mm si inaltime 20mm,0,25W/8ohm pret 8 lei perechea https://postimg.cc/bSNZtRyz https://postimg.cc/23KkGYTd https://postimg.cc/Lq22586S 7.motor pickup cu potentiometru reglare turatie,,pret 15 lei https://postimg.cc/phbtqdt6 https://postimg.cc/fJTkx8C0 8.pereche difuzoare cu dimensiunile de 82x82 mm si inaltimea de 53mm, 10W/8ohm,pret 30 lei perechea https://postimg.cc/qNQZcJx4 https://postimg.cc/yg3QzF48 https://postimg.cc/PNZ33zQ6 Link spre comentariu
adydep Postat Septembrie 21, 2020 Autor Partajează Postat Septembrie 21, 2020 Up. Link spre comentariu
